Question about HP OfficeJet D135 All-In-One InkJet Printer
Cannot send more than 1 page
When trying to send more than one page at the same time, last page gets stuck, fax remains on "sanding".
    Scholar:
  • 124 Answers
In case of double page-feeding, turn of the unit, open it, and release the page. open the back entrance of the printer, clean all feeding wheels with a dry rag. make sure there's nothing stuck between those wheels. make sure feeding tray is well located.
Posted on Feb 22, 2006
Fax problem with mx432, I get an alarm sound on the last page i am sending and it tells me to eject the page
it might be a laser printer, these are thermal printer, they sometime overheat and flash false error messages
for the noise you can check the condition of the paper rollers
Dec 07, 2013 | Canon PIXMA MX432 Wireless Office...
Why can't I fax more than one page at a time?
IF IT JAMS OR TAKE ALL THE DOC AT THE SAME TIME CLEAN OR REPLACE ADFRollers and separation pad. TEMPORARY SOLUTION IS use sanded paper gently to give surface of roller and adf pad, moer grip
Apr 23, 2013 | HEWLETT-PACKARD HP 2140 Fax
How to fax?
This section describes dialing and sending faxes directly using the Numeric buttons.
note:
  • A PBX (Private Branch Exchange) is an on-site telephone switchboard. If your machine is connected through a PBX or other telephone switching systems, you have to dial the outside line access number first, and then the number of the party you are calling.
Sending a Fax with the Numeric Buttons .
Click here for other useful sending methods.
1. Preparing for sending a fax.(1) Make sure that the power is turned on.
(2) Load a document on the Platen Glass or in the ADF.
important:
  • When sending a double-sided document, set the document on the Platen Glass. You cannot scan double-sided documents from the ADF.
(3) Press the FAX button.
The fax standby screen will appear.
(4) Adjust the density (scan contrast) or image quality (fax resolution) as necessary.
See "Adjusting the Sending Quality"
2. Sending the fax.
  • When the document was loaded on the Platen Glass:
(1) Use the Numeric buttons to dial the recipient's number.
(2) Press the Color button for color sending, or the Black button for black & white sending.
important:
  • Color sending requires that the recipient's fax machine supports color faxing.
(3) Press the OK button.
The machine starts sending the fax.
note: When loading two or more documents
  • Load the next page, and press the same button as you pressed in (2) of step 2. Repeat the same procedure to scan all pages of the document, and press the OK button.
  • When you have sent the first page with the Black button, the following pages will be sent in black and white.
When the document was loaded in the ADF:
The machine scans the document automatically and starts sending the fax.
important:
note:
  • To cancel sending a fax, press the Stop button, and follow the instructions on the LCD.
  • If documents remain in the ADF after pressing the Stop button during scanning, "Close the feeder cover [OK]Eject the document" will appear on the LCD. Press the OK button so that the remaining document is automatically fed out.
Automatic redialing
  • When sending a fax and the recipient's line is busy, the machine will redial the number after a specified interval. Auto redial is enabled by default. Auto redial can be enabled or disabled by selecting ON or OFF. Select ON to specify the number of redialing in Redial times and redialing interval in Redial interval.
Redialing the Number Dialed with the Numeric Buttons
1.Prepare for sending a fax.
(4) Adjust the image density (scan contrast) or quality (fax resolution) as necessary.
2. Select the telephone number recently dialed.
(1) Press the Redial/Pause button.
Most recently dialed fax number using the Numeric buttons will appear.
(2) Use the g0016984.png (-) or g0008875.png (+) button to select the number to redial.
The selected number will appear in the fax standby screen.
3. Send the fax.
important:
Jun 03, 2011 | Canon PIXMA MX340 Wireless Office...
Can't send faxes. Dials Ok but no connection to send fax
If you are unable to send the faxes, please try decreasing the modem speed and disabling the "Error Correction Mode." To decrease the modem speed, please follow the steps given below:
1. Press the "Fax" button.
2. Press the "Options" button 15 times till it reads "Advanced Fax" on the display.
3. Press the "Select" button.
4. Then press the "Options" button 10 times till it reads "Max Send Speed."
5. Now press the "Right Arrow" button and choose "9600 bps."
6. Press the "Select" button.
To disable "Error Correction," please follow the steps given below:
1. Please press the "Fax" button.
4. Then press the "Options" button 11 times till it reads "Error Correction."
5. Now press the "Right Arrow" button and choose "NO."
May 19, 2009 | Lexmark X4270 All-in-One Multifunction...
Pages aren't being sent properly
BUILD UP OF INK ON THE POLLERS AND SOME MACHINE HAVE WHERE YOU CAN SETUP INTERMITTING TIME DELAY INBETWEEN FAXING LETTING THE MACHINE COOL DOWN BETWEEN FAXING AND I HAVE ANOTHER PROGRAM THAT MAY HELP IN THIS MATTER CALL GREENPRINT WORLD.COM
ROD
Feb 04, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
I HAVE A PANASONIC FAX kx-FPG376 IT WONT SEND FAX MAKES COPIES AND RECIEVES FAXES
I dont know how we got disconnected but here is the instructions
Adjust the width of the document guides (1)
to fit the actual size of the document.
2 Insert the document (up to 10 pages) FACE
DOWN (2) until a single beep is heard and
the unit grasps the document.
L If the document guides are not adjusted
to fit the document, re-adjust them.
3 If necessary, press {A} or {B} repeatedly to
select the desired resolution.
4 Press {DIGITAL SP-PHONE}.
5 Dial the fax number.
6 When a fax tone is heard:
Press {FAX/START}.
When the other party answers your call:
Ask them to press their start button. When
the fax tone is heard, press {FAX/START
To redial the last number
1. Press {REDIAL/PAUSE}.
2. Press {SET}.
L If the line is busy, the unit will automatically
redial the number up to 2 times.
L To cancel redialing, press {STOP}.
To send more than 10 pages at a time
Insert the first 10 pages of the document. Add
the other pages (up to 10 at a time) before the
last page feeds into the unit.
Pre-dialing a fax number
You can dial the fax number first before inserting
the document. This is convenient if you need to
refer to the document for the other party’s fax
number.
1. Enter the fax number.
2. Insert the document.
3. Press {FAX/START}.
Sending from memory (Quick scan feature)
You can scan the document into memory before
sending it. To use this feature, activate feature
#34 (page 62).
1. Insert the document.
2. Enter the fax number.
L The document will be fed into the unit and
scanned into memory. The unit will then
transmit the data. If the document exceeds
the memory capacity, transmission will be
canceled and this feature will be turned OFF
automatically. You must transmit the entire
document manually.
L This feature cannot be used if {DIGITAL SPPHONE},
{TALK} or {SP-PHONE} is
pressed.
To stop transmission
Press {STOP}.
Aug 27, 2008 | Panasonic Office Equipment & Supplies
FAX doesn't go through
re-install the unit. What operating system are you using. More detail needed. Perhaps its the modem that is not functioning.
Jun 26, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Sending Faxes
When the last page of your document has been sent successfully, the machine beeps and returns to Standby mode. When something goes wrong while sending your fax, an error message appears on the display. If you receive an error message, press Stop/Clear to clear the message and try to send the document again. You can set your machine to print a confirmation report automatically each time sending a fax is completed. If you get the error message write it down it should always supply an error message if the fax did not go through.
Jul 25, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Fax sending problem
It sounds like you have a few problems. First, the comm error usually means there was a problem communicating with the other fax. This maybe caused by a phone line issue, or a bad connection. You will have to replace you ink but that does not have anything to do with your sending issues. As far as the pages getting stuck, the separation pad under the top cover should be cleaned. If you lift up the cover where you load your pages to be sent, and look in there(on the backside of the keyboard)you will see a flat square rubber piece. Clean it thoroughly with a rag and some rubbing alcohol. Also clean the rubber rollers as well. Good luck John
Jul 03, 2007 | Brother IntelliFAX 1840C Plain Paper...
HP OfficeJet D135 All-In-One InkJet Printer Logo
37 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
