Question about Panasonic NN-S254WF Microwave Oven
Venting Does this microwave vent out through the roof?
  • Panasonic Master
  • 9,098 Answers
The owner's manual should tell you.
If you don't still have it, you can download it here.
Posted on Sep 09, 2008
How do I change the front exhaust to top exhaust on a Kenmore microwave/hood
In order to change the venting on the microhood you need to uninstall the unit and at the top of the microwave is the blower unit. Remove the cover, flip the blower and you should then see the fins on the motor, reinstall the unit under the cabinet and your good to go. I hope this helps, good luck
Mar 15, 2015 | Kenmore Microwave Ovens
Whirlpool microwave fan not working
I would unplug the oven for 2 minutes to do a hard reset and try it again, just in cause there was a glitch.
Without knowing your full model number from the tag on the oven, I would wonder if it has a separate internal cooling fan from the hood vent exhaust fan. It could be an unrelated issue.
For more free DIY and other help & advice, feel free to contact me with your full model number and FCC ID number from the tag on your oven.
William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 11, 2017 | Microwave Ovens
We have an above stove mounted Tappan microwave model # FMV151FS that vents into the kitchen; Is it made so I can make it vent outside the house, by adding ductwork to the roof?
Refer to the installation instructions for that answer.
If for some reason you don't still have yours, download it here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Nov 16, 2012 | Microwave Ovens
Screw/nail in microwave housing loud rattle when exhaust fan is on.
A screw that falls into it from the top should be in the vent fan in the top rear of unit. I think you will have to take the unit down from the wall, at that point, either remove the vent blower fan and shake it out, or turn the whole microwave upside down and it may fall out.
Oct 17, 2017 | Whirlpool GH7208XRS Stainless Steel 1200...
My whirlpool microwave was hooked up but doesn't seem to be venting out the roof. It has a vent running from the top of it through a cabinet and out the roof. What might be blocking the venting process?
the fan motor needs tobe turned around take screws out of top front remove front fan grill pull out fan assibliy and turn around. this will pull air out of your house
Sep 21, 2009 | Whirlpool MH7140XF Microwave Oven
Can the lg lmv2083st microwave be vented to an outside vent? not clear from the installation manual.
On page 8 of the installation manual I found, it shows that the oven can be vented to the outside. You can view it at this link:
http://www.managemyhome.com/mmh/lis_pdf/INSTL/L0707162.pdf
If the link does not work, you can go to managemyhome.com and type in your model number under the "Manuals" link.
In the manual it describes three methods of venting: Room, Roof, and Wall. It also gives guidance on how to properly install the duct work.
If you have questions, please let me know. I hope this helps you.
Aug 21, 2009 | LG LMV2083SW Microwave Oven
Where is the charcoal filter?
There is no charcoal filter unless you replaced the standard filter with a carcoal filter. Also, it may have m=been changed to a charcoal filter if the unit was alterd during installation as a re-circulating vent, not vented to the outside via the roof or wall.
The filter (Charcoal or not) is on the bottom of the unit. Put your head under the microwave and look up, there it is.
Apr 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool microwave oven mh7155xmb0 not venting
Possibly a bird built a nest (swallows) in or on the roof vent. Make sure the fan turns freely when off. Check the vent tube that goes up to the roof--if flex-tubing, it may have collapsed and pinched off the air flow (it may be too long). Make sure that a one-way valve which should be near the exit of the hood is free to move when air flow pushes on it. This valve is supposed to prevent back-flow of air into the house. Hope this helps!
Mar 09, 2009 | Whirlpool MH7155XM Microwave Oven
Over Stop Microwave Vent Blower doesn't remove steam
Whirlpool customer service is here and you can also enter your model number on that page to download your owner's manual, installation instructions, etc..
The installation instructions are what you need.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 13, 2008 | Microwave Ovens
How does the vent work?
Under cabinet microwaves generally have two configurations for venting.
1) There is a vent cover plate on the top or rear (sometimes both) of the unit that can be removed and connected to a duct that vents up to the roof. If you do not have such a duct installed then that cover plate should be left on the unit so that it vents in configuration 2.
2) With the external venting ports sealed with the cover plate(s) the microwave simple draws air from the bottom (usually through 1 or 2 grease capture screens) and vents it out thought the front/top of the unit. This configuration isn't very useful as it just blows the air back into the kitchen. Many people don't both using the microwaves blower in this configuration.
Feb 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Panasonic NN-S254WF Microwave Oven Logo
89 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
