Question about Sony RM-Y135 Remote Control
Sony RM-YDO10 quit working
This remote was working just fine. I have replaced the batteries and have pressed the TV button. I have several Sony devices & the Sony DVD remote will turn the TV off & on in TV mode. I am currently using my Direct TV remote for the Hughes DVR receiver & it will turn the TV off & on.
No light comes out of the remote when buttons are pressed. I wonder if those bulbs can go bad??
I got this remote with the TV which is almost 2 yrs old.
Sony KDS 55A2000.
  • teitelynn Jan 25, 2009
    I have the same problem with the Sony SLV-D-100. It appears the light at the end of the remote is not lighting up to send the signal.
  • white mutt Mar 01, 2009
    Despite putting in new batteries the remote keys have to be pushed hard 3 or 4 times to get the tv to respond. The problem is slowly but continuously getting worse. Can the dealer repair this or is a new ( and hopefully more reliable ) remote necessary.
SOURCE: REMOTE CONTROLER RM-YDO10
remote controler car that uses gas
Posted on Apr 10, 2009
SOURCE: Sony RM-ASP001 for 400 disk changer stopped working
Try the command code switch. I recently had a similar problem when my remote suddenly stopped working. It worked fine one time but nothing the next time I tried it.
I checked the emitter with a digital camera and found it was not working. I did the remote reset (remove batteries and push all the buttons twice, reinsert batteries) and the emitter was now working. However, the remote would still not control the base unit. I did the remote base code reset (push power, volume and TV/DVD buttons together) but this did not help. I then checked the command code switch. This is a small three position slide switch located in the battery compartment on the remote. I slid the switch back and forth several times returning to the default number one setting where it was before. I did not change anything on the base unit but the remote now worked.
Hope this helps.
Posted on Dec 26, 2008
Mykel_N
  • 315 Answers
SOURCE: RCA D771 universal remote won't work on Direct TV receiver
This might help:
http://uk.youtube.com/watch?v=5YHGdPOy5dc
Or you could try this:
http://www.thompsontv.com/rcarc.html -
The paragraph about code search may help.
Sorry if it doesn't help
Posted on Jan 27, 2009
SOURCE: The Sony TV remote doesn't work (with good batteries).
NSE urc22b-12 please pin code forTV SONY model KV-A2921D
Posted on Sep 28, 2009
dcramer531
  • 1654 Answers
SOURCE: 1) The remote is not communicating with any of the
I can give you several tips to try and see if we can get it going. First make sure you have the correct devise selected with the remote. For example if you are using it for the tv, make sure you have pushed the tv button on the remote first, and so on for all the other functions for your reciever. If this is not the problem try changing the batteries and make sure they are in correctly. Weak batteries will allow the red light to light up on the remote but it doesn't have the power to send the signal to the reciever. the other option is that the remote is simply wearing out, or has some type of dirt insde it not allowing the buttons to make contact with the metal strips inside the remote. You can sometimes find a store like Radio Shack that will be able to check and see if the remote is acdtually sending a signal, try calling around and see if someone has one of these detectors. If none of these help, try getting one of the universal remotes from a department store, they work with just about any brand of electronics and are much cheaper that a new remote. Here are a few links to sites that carry almost all brands of remotes in case you need a new one.
I hope this helped.
MrRemoteControls.com
Remotes.com
Posted on Nov 17, 2010
Sony Remote RM-YD035 does not change channels or turn off TV
You have worn those buttons on your remote out. Those are you most used buttons. You can have you remote repaired by pros here. You can buy a new Sony RM-YD035 here. Or you can purchase the keypad repair kit here and fix it yourself.
Oct 05, 2012 | Sony Rm-yd035 Remote Control
What are the remote codes for Sony RM-EZ4 / Haier TV, Comcast Xfinity cable box?
Follow these steps to program the remote control.
  1. Turn on the component to be programmed.
  2. Press the SET button.
  3. On the remote control, press the appropriate component button.
  4. Using the number pad, enter the component's manufacturer code.
  5. NOTE: If more than one code number is listed for the manufacturer, repeat the procedure, entering one code at a time until you find one that works.
  6. Press the ENT button.
  7. Point the remote control at the component.
  8. Press the POWER button to verify operation.
Comcast offers several remote controls. The type of remote you get depends on the device you're using. Some Comcast remote controls are multi-device or universal remotes, while others only control the set top box and TV.
May 06, 2012 | Sony RM-EZ4 Universal Remote Control
I have a lcd sansui SV-3255LCD tv but the remote had quit on me. can you people help by supplying me with the code for my LCD? And will the code for my LCD work on my sony universal remote RM-AAP013?...
Sansui is built by Japan firm Orion try 135 or 136 four digit try 0135 or 0310
On the remote control, press and hold the RM SET UP button.
  1. While holding down the RM SET UP button, press and release the A/V I/O button.
  2. Release the RM SET UP button.
  3. Press the input (component) button to be controlled. NOTE: To program a television press the TV I/O button.
  4. Press the number buttons to enter the numeric code corresponding to the component and the make of the component to be controlled. NOTE: If more than one code number is listed for the manufacturer, enter one code at a time until you find one that works.
  5. Press the ENTER button.
hope this helps
Mar 28, 2011 | Televison & Video
I have an sony rm-ez2 and i want it to work with my orion Model #tv1934 whats the code or will it work
As far as I can tell, Sony doesn't have any codes for Orion TVs. You can try searching through all of the codes in the remote. Turn on the TV, press and hold the Set button and then press the Power button. Release the buttons. Then press TV button (component button). Press the CH+ button followed by the Power button. Repeat the CH+ and Power combination until the TV responds (powers off, changes channel). Then press ENT. Check if the TV responds to the remote on other functions. If it doesn't repeat the steps from press and hold the Set button.
This can take up to 70 tries.
Alternatively, try a replacement remote for the TV or a USB programmable universal remote. http://www.remotes.com/store/orion/tv1934.html is a substitute remote that should handle all of the functions.
I hope this helps.
Sep 06, 2010 | Sony RM-EZ2 Remote Control
My sony kv-36xbr450 quit responding to the remote (rm-y184). I put new batteries and the remote lights work when pushing buttons. Is there a way to reset or check the remote ?
it is most likely the remote receiver inside the tv. you can verify this by using a universal remote. if you cant get it to work the receiver is bad.
Dec 27, 2009 | Sony KV-36XBR450 36" TV
Lost Instruction Manual Paper for Sony RM-V401 Remote Control
You must press "set" button (with a pen), then press "tv" followed by the code you have and finally "enter". Regards
Jul 13, 2008 | Sony RM-V401 Remote Control
Nov 15, 2007 | Sony Televison & Video
Sony RM-Y135 Remote Control Logo
399 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
