Kenwood vr5700 standby blinking light
Getting the standby blinking light. I noticed the rt. channel speaker wire disconnected and crossed (3yr old son). I unplugged all wires, and tried resetting but no luck. Checked internal fuses and all ok. What do I check next? Thanks
  • 1,512 Answers
Hi kerrijon
Oh dear, your budding lil electrician may have gotten out of his depth:).
Shorted speaker wires often result in damage to the amps output stages. The blinking light tells us that the unit has gone into protection mode, preventing damage to the speakers from the amp. It will have what is termed a DC offset condition being generated by the channel; that got shorted. There is no easy fix for this and you have checked the obvious with fuses and removing all speaker wires and checking operation. The unit will have a blown output transistor/array, possibly driver transistors, and fusible resistors, and diodes to that channel. The bias current will also need to be set up again once repairs are completed.
There are no user serviceable parts in a unit like this. With good knowledge of electronics, a multi meter, soldering iron and experience at using all, you could fault find the channel, replace the parts yourself. I should warn you that if descrete components are used, they can be difficult to repair because of the nature of DC coupled linear stages employed. The best option is to take it to a repair man for a quote.
I am happy to try and talk someone through a repair process, but there is a degree of difficulty ascociated with not being able actually work on the amp.
The best solution for you is to get a tech to look at it. This sort of repair work can range from $80-150 depending on the parts used and the time taken to fault find and replace parts. I hope that this helps you. Your appreciation for my time spent to give you this advice is best rewarded with a FixYa.
Cheers
regards
robotek
Posted on Sep 10, 2008
Got in car this morning and radio was blinking protect
Hi.
Protect mode is a special condition that kicks in when an internal fault has been detected. In protect mode all the unit function are disabled to prevent the stereo getting more damage in consequence of the fault. The state is a forced standby condition that starts when a wrong voltage or a short is detected.
Try disconnecting the battery terminal, pulling the radio out of the dash and checking the wiring at the back of the stereo. Most of the time protect mode is triggered by a wiring contact. If possible check also speaker wiring. A contact in wiring to speakers will trigger protect.
Regards.
Ginko
Sep 14, 2011 | Kenwood KDC-MP235 CD Player
My kenwood vr-414 receiver shuts on then off standby is blinking
The most common problem found on FixYa for Audio Video2_bing.gif Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
May 31, 2010 | Kenwood VR-414 5.1 Channels Receiver
Kenwood Amp blinking Standby indicator light
Hi fuxsiloh.
It sounds like you have eliminated all the things that could generate this symptom that are external to the amp. It is most likely that there is an internal problem that is causing the amp to go to protection mode. A power supply failure(maybe a fuse) is the only really user serviceable part inside the amp. Perhaps check for failed fuses, replacing any that may have blown with exactly the same type. BE SURE TO UNPLUG AT THE WALL FIRST:)
Is the amp still under warranty? If so, then returning it to a Kenwood service center is the shot. If you want to have a go at repairing it, I can talk you through it, but some experience with this sort of thing is very necessary. Good luck
regards
Graeme
Apr 06, 2008 | Audio Players & Recorders
Kenwood VR-405
Hi changeman5 Have you tried to do a full reset on the unit. Disconnect from the wall for 24 hrs. Then try again. If the problem persists, it may have power supply issues, or a DC offset problem shutting it down. If you are game, I could talk you through some more diagnostics...
regards
Graeme
Apr 01, 2008 | Kenwood VR-405 Receiver
Kenwood VR 208
It works sometimes, mostly the volume bottem
Nov 26, 2007 | Kenwood VR-506 Receiver
Kenwood VR-307 Receiver standby light blinking
Hello, sorry to say this, but there is a hardware error. Possibbly something is wrong at the output stage. Please send it to tech for a repair. But first disconnect the speakers and then try to turn it on. If there is no change the error is still present. Best regards. Arpi
Jul 17, 2007 | Kenwood VR-307 Receiver
On and off switch
This is the thermal overload for the amplifier section. unplug unit and check all speaker connections for a crossed wire. After all connections are checked and are in good condition, plug the amp back in and power up. Note: the polarity of the speakers when the wires are plugged in. Use the painted line on the speaker wire as a guide for which one is positive(+) and negative (-). If an amplifier is operated out of phase for too long ( positive and negative reversed), you can damage the amp. A bad speaker coil can cause the overload as well. If it still does it, disconnect all speakers and power it up. If these remedies do not solve it, you amplifier IC is shorted and needs replaced.
Apr 10, 2007 | Kenwood AR-304
299 people viewed this question
 Grubhead
Grubhead
