Question about HP LaserJet 5510 All-In-One Thermal Printer
Fax transfrring problem
I cannot move a fax that includes more than 1 page from the outer tray. sometimes the page doesnt go in well, and sometimes secondpage is moving in whire first is in middle of the action. TIA
    Scholar:
  • 124 Answers
In case of double page-feeding, turn of the unit, open it, and release the page. open the back entrance of the printer, clean all feeding wheels with a dry rag. make sure there's nothing stuck between those wheels. make sure feeding tray is well located.
Posted on Feb 22, 2006
My iphone 3g sim tray is broken and i wanna replace it. Please tell me tat will i get my imei number printed on iphone 3g new tray or not?? Can I change my iphone whole outer body??
No the IMEI is not on the new tray. You can change the back of the phone or it's "outer body" except changing the sim tray is very very easy. Changing the back/ outerbody of the phone is the most labor intensive part: It includes removing EVERY piece of the phone including all tiny buttons and clear lenses and even a few pieces attached with adhesive. Then placing each one of those pieces into the new iphone case, glue the pieces in and reassemble. Changing sim tray takes like 1 minute, Changing back of the iphone 3g takes 3+ hours of very careful tinkering.
May 05, 2011 | Apple iPhone 3G
Procedure of send fex in hp3050
You can get the detail information for setting up and using the fax from the following link. Pls read the article cerafully toknow how you can setup and use the fax.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=120&prodSeriesId=1140783&prodTypeId=18972&prodSeriesId=1140783&objectID=c00659224
Sep 07, 2009 | HP LaserJet 3050 All-In-One Printer
I have the same problem; every 2nd page is blank
sounds like the seperation roller in the paper tray is worn .. this roller is there to stop multiple feeds or it may have a pad in your tray open the paper tray up and look at the roller in the tray or the pad ; and give it a clean with a damp cloth.. also check the paper if it has been in the tray over the weekend when not used sometimes they pick up cold or dampness and so the paper sticks to the top sheet.. Im thinking more on the lines of the sepertion roller/pad area.. Goood luck A
Jul 20, 2009 | Sharp UX P200 Plain Paper Thermal transfer...
Explicit input tray for bizhub 250/350 fax.
to set the priority tray for fax reception you have to change software sw in administrator mode:
1 touch the utility/counter button
2 press administrator mode button on the touchscreen
3 enter the passwrod 12345678
4 press the admin. 2 button
5 touch software sw
6 touch mode selection then use the keypad to type 037
7 touch the bit selection button use the arrow keys to select the bit you want to change setting the bit to a 1 enables the tray and 0 disables the trayrefer to the chart below to pick a tray to print faxes from you cannot set all the bits to 0 at least one of them have to set to 1.
bit 7=1 for the 1rst tray
bit 6=1 for the 2nd tray
bit 5=1 for the 3rd tray
bit 4=1 for the 4th tray
bit 2=0 for the bypass
so lets just say you want to put yellow paper in tray 1 to have all the faxes print on yellow paper. you would set bit 7 to a 1 and set bits 6,5,4,2,all to 0
Mar 25, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
I need to get a copy of a document that I faxed.
No, the JOURNALS will only tell you the fax number it was sent to.
Feb 13, 2009 | HP LaserJet 3330 All-In-One Printer
AR-M207 default paper tray for fax
push"special function" button, then select "key op prg", then "ok", then enter pin (default is 00000), then select "fax", then "ok", then select "rcv function", then "ok", then "tray selection", then "ok". The rest you should be able to follow your nose.
Feb 06, 2009 | Sharp AR-M207 All-In-One Laser Printer
Canon b640 problem
By cleaning the feed rollers you the fax will feed beter.Remove the dockfeeder and the paper tray.you will find the feed rollers in the bottom of the paper tray.Take a cloth and a stong soap selution and clean the 2 feed rubbers.
Jan 06, 2009 | Canon FAXPHONE B640 Plain Paper Bubblejet
Lexmark x5320
When you load the document feeder, simply place all of the sheets, up to I believe 25 sheets at a time in the document feeder. The doc feeder, if working correctly will load them one at a time and then exit them to the receiving shelf or tray on your printer.
If you do not have a document feeder, or must use the manual scan function for some reason, there is also a FAX multiple pages function from the sub menu.
ZBob
Jul 28, 2008 | Lexmark C752FN Printer
HP LaserJet 5510 All-In-One Thermal Printer Logo
26 people viewed this question
Clive
Clive
