Question about Frigidaire GLTR1670A Front Load Washer
My Frigidaire front load washer won't start
"Door Lock" Button comes on when i try to select a cycle, then the machine simply doesn't start. Any suggestions greatly appreciated!
  • brinraeven Oct 12, 2008
    Mine is a GLTF2070 series, but I have the same problem. The door simply will not unlock and I can't get it to do anything. It was in storage for 2 years, but I don't think that should affect anything.
A year later! I experienced the same problem this morning - exactly as you, Bessie24, stated. I could hear a faint humming sound and thought the lock mechanism was still trying to complete its locking function. It would know the lock function was completed when the lock trips the wee (micro) switch. I reckoned if the female portion (with switch) were a tiny bit loose, the switch might not trip, so I loosened then tightened the two screws attaching it to the carcass of the washer (as opposed to the door part) while pushing upward on the same part. This fixed my problem and i hope many others find this procedure useful.
Posted on Oct 11, 2009
Usually, the door lock button should come on when you have the door open. Make sure it's fully shut before you try to start a cycle. Or, if you're talking about cancelling the spin cycle when you have about 2 minutes left, and then not being able to get the door open. You have to wait about 3 minutes. It even says in the manual, it will take about 3 minutes for the door to unlock. Just walk away and come back. Do not yank on the door for 5 minutes, as I used to do.
Posted on Nov 24, 2008
Door won't lock / cycle won't start
Check if the lock is binding or the door switch is not being operated.
May 19, 2013 | Asko W6221 Front Load Washer
HOW TO CLEAR THE LOC CODE ON MY FRIGIDAIRE WASHER
This means that the child lock (control lock) feature is active. There will be a button (or pair of buttons) depending on the model that you need to press and hold to toggle off the feature. If it is a single button, there will be a tiny padlock icon on the button. If you need to press and hold two buttons, the padlock symbol will be in a line indicating both buttons.
A likely combination is the Select and Option buttons. These should be held together for 10+ seconds. (This is the combination for some Affinity washers.)
If this doesn't work and you can't see a lock icon, please add a comment with the model number of your washer. I'll be glad to check what the combination is for your washer. The model number is usually on a plaque on the rim of the door for front loading washers or at the back at the top of the drum for a top loading washer.
I hope this helps.
(the control lock prevents someone from accidentally changing the cycle or a child starting a wash cycle with the cat or another child in the unit)
Nov 23, 2011 | Frigidaire 14 Cycle Tumble Action Washer
My frigidaire front load washer will not start. anytime I push a button on the front panel the "LOL" sign flashes. on the front of the washer panel d wash rinse final spin control lights are...
Is the message "LOL" or "LOC"? I suspect the child lock "LOC" has been activated. To toggle this off, press and hold Options and Select for 10+ seconds. This feature prevents someone from accidently starting or changing a cycle selection.
There is a small padlock icon in the middle of lines linking the two buttons that let you toggle the child lock on and off.
There are two Frigidaire washers with the model ATF6000ES (the S is followed by a 0 or a 1). The manuals for both are available here: http://www.frigidaire.com/manuals?model=ATF6000ES . The child lock feature is described in the Operating Instructions. For the ATF6000ES0, the direct link to the appropriate manual is http://manuals.frigidaire.com/prodinfo_pdf/Webster/134604400.pdf . See page 2 under Washer Features.
I hope this helps.
Sep 21, 2011 | Frigidaire ATF6000ES Front Load Washer
Fridgaire FTF530fs3 door lock buzzing and not locking, washer won't start
fit a new door lock as if it doesnt engage it wont allow the machine to start the washing cycle
May 31, 2011 | Frigidaire FTF530FS Front Load Washer
My Affinity Front load washer, Model #ATF7000ES1
I am having this same exact issue, have you figured out what the was?
May 13, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire affinity washer doesn't start
Try holding the 'options' & 'select' buttons together till the door lock button comes on. This is the child lock function. You can do it again for the lock to come off. Hold down for over 3 seconds
Please reply or rate.
Dec 01, 2008 | Frigidaire Affinity ATF7000ES Front Load...
My Frigidaire affinity washer doesn't start: the "door locked" button doesn't come on though the door is closed properly
If the washer fills with water, but will not start the wash cycle or spin, it is 1 of to things. the most common for frigidaire front load affinitys is the door lock assembly. I have had to replace numerous of these. if the door lock indicator is not on when it tries to wash, you need to replace the door lock assembly. if the door lock indicator is on, but wont wash, it is likly that you have a bad motor control board.
Frigidaire GLTR1670A Front Load Washer Logo
2,811 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
