Question about Intel D865GBF Motherboard
My computer keeps saying driver software was not sucessfully installed contact manufacturer for help my serial no for this external drive is K6XB-TA94-HHFS_4DD9 HELP!!!!
  • 320 Answers
To download the drivers, Please click on the below link or copy the URL and paste it in your web browser. Select the operating system you are using and click on the download to download the driver.
Thank you....
Posted on Sep 16, 2008
When I start my dane-Elec external hard drive, the blue light first turns on, then goes off. I can feel that the drive is on, but the light is not. And it's not detected on any laptop I connect it to.
When a Universal Serial Bus [USB] drive doesn't show up in your computer, it can be an urgent problem, especially when you need to access files or data stored on the drive.
It is not easy to troubleshoot this issue, compared to other computer problems, because there are a few probable causes for the problem.
On a positive note, USB problems generally require one simple step to resolve.Name Conflicts
This problem generally occurs on computers with an exceptional number of attached drives, whether they are networked, or hard-wired.
Computers with multi-format card readers can have this issue.
USB drives don't always find an available drive name that is compatible with their naming conventions.
For example, if the USB drive is named "G:," and your computer has a networked drive "G:," or additional hard or optical drives named "G:," your USB drive will not show up.
This problem can be resolved by remapping a drive to a different name; this can either be a temporary name change, or permanent.
One thing to keep in mind, is that drive remapping is not something that a computer novice should attempt.
Consult a technician for help with remapping/renaming a drive.
Software Conflicts
With newer computers, it is much more unlikely, but there could be a chance that your USB drivers are not installed.
Checking your USB drivers is a simple as right-clicking "My Computer," and selecting "Properties."
From the Properties menu, select the "Hardware" tab, and click the "Device Manager" button.
A list of your computer's hardware will open, and you will find "Universal Serial Bus" on the list. If you see a red "X" or yellow exclamation point, your drivers are not installed.
Drivers vary by computer; if you cannot find the driver disk that came with your computer, you will need to go to the website of your computer's manufacturer to locate and download the driver.
If you are not comfortable downloading and installing software, contact a computer technician.
Drive Malfunction USB drives are more durable than floppy disks and their predecessors, but they are not indestructible.
If your computer does not detect your drive and it has before, test the drive in other computers.
If the drive does not show up in several computers, there's a good chance that it has gone bad. Repeated rough handling of a USB drive can damage the memory chip on the drive.
Removing the drive without "stopping" it can corrupt the drive, as well.
USB Port Malfunction
Most USB drives have a small led that will light up when the drive is inserted into the USB port.
If the LED does not light, it could indicate a problem with the drive, but there could also be a problem with the computer's USB ports.
If the drive does not light up, and is not detected, plug it into another computer.
If the drive is detected by the other computer, there is a problem with the original computer's USB ports.
Follow the steps in the Software Problems section of this article to check if your USB drivers are installed. If they are, you may need to contact a technician to check your USB port connections.
The USB ports on the computer may have been connected when the computer was manufactured or recently serviced.
If you are not comfortable working on your computer, contact a technician.
Failure to take certain precautions could result in damage to your computer's motherboard.
Expert Insight
Whether your drive is new or you've had it for a while, do not be over-reliant on its durability. Keep at least one additional copy of your data in another location to avoid catastrophic data loss.
USB drives are not indestructible, and it is not always possible to recover data from them, even under favorable circumstances.
Aug 06, 2013 | Dane-Elec Computers & Internet
My computer recognizes my wd external hardrive but says it cant fin the necessary software
Right-click My Computer and go to Manage Computer. Then, click Disk Management. You will see the different partitions of the disk labeled by alphabet characters. Click on the partition associated with your external drive and then just change the character to any alphabet character that's aren't used as labels.
If you need further help, contact 1.877.787.8749 and use promo code SYNAFFMRKT2012 to avail of discounts.
Sep 06, 2012 | Western Digital My Book Essential Edition...
Windows did not open sucessfully
You most likely need to re-install Windows using a Dell Recovery CD to get your computer operating again. This process will delete your data unless the data is stored on another partition on the hard drive.
To recover your data before re-installing Windows, remove the hard drive from the computer and attach the hard drive to an USB hard drive adapter and connect it to a working computer's USB port. This computer will see this as an external haed drive, you can then open the various folders and files to copy and back them up. After you have completed this task, return the hard drive to the Dell computer and try to fix the computer.
Jul 22, 2010 | Dell Inspiron 1525 Notebook
Same problem
Check with your computer manufacturers website for any driver updates for the motherboard and also be sure to check with microsoft's optional driver and software update section which may hold a driver update for your computer.
Aug 21, 2009 | SimpleTech 1TB External USB 2.0 Hard Drive...
The external is on but my computer say unknown device so cant use it and most of my data are in there. Even if i keep it cd to install does nothing but give instruction which doesnt help me at all.
What Operating System is on your computer? Windows 98 and Windows 2000 sometimes will need the drivers for the external USB drive. Check with the drive's manufacturer to see if drivers are available for your Operating System. I know the Western Digital Passport will not work with Windows 98 and Western Digital has no intentions of writing drivers for the Operating System.
Jul 28, 2009 | Computers & Internet
Cannot install driver (code 10 )
don't use the camera to load the pictures. see if your printer or computer have an SD card reader or buy one for $10 plug it into your USB drive and access the pictures that way...
Once you plug in your SD card Via SD card reader go to my computer and open the drive with the SD card on it... Shouldn't be difficult to figure out. Cut or Copy all your pics and paste them into your My Pics folder or any other folder of your choosing. Enjoy your pics...
Jun 25, 2009 | Kodak EASYSHARE M1063 Digital Camera
Com.port failed
Download and install the latest proper driver for the TU-S9 cable.
Also, are yo sure that this mysterious "external serial device" is working properly, or is even compatible with the computer?
Last but not least, you could buy and install a PCI serial port card...
Mar 23, 2009 | Dell Dimension 2400 PC Desktop
Installed new operating system now external drive don't work
It sounds obvious but jot down any manufacturer serial numbers etc, go to their website and try to get drivers from there. Hopefully a quick driver install will get you up and going.
Mar 07, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Disconnect while online
The driver download is the software download.
May 14, 2017 | Averatec (70-822301-00TRI) (7082230100TRI)...
I bought the Full retail Version (Platinum which included DVD X Rescue) in Nov 2003.
Hello. Some softaware used some unique datafrom your computer to generate licence key for the software (like HARD DRIVE serial number or motherboard serial number) and if your licence is generated by this algorhytm then your licence will be not valid anymore. You will need to contact software manufacturer and ask them about that. I hope this will help you :)
Aug 16, 2007 | 321studios DVD X Copy Platinum (200000)...
Intel D865GBF Motherboard Logo
21 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
