Question about Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2)
Port forwarding how do i forward a port from my router to a specific application?
  • 2,794 Answers
Go into the admin program, select Applications and Gaming, type in any name to reference it with in the first column. Type in your start and ending ports. Keep the protocol at both. Type in the last set of numbers that the IP address needs for the computer that you are forwarding to. Select enable. Select the save setting button.
Posted on Sep 09, 2008
Where do i find the port forwarding?
To access the Port Forwarding option of your router, you will need to access the router setup page and from there you will find Application and Gaming tab and there you will see the sub tab port forwarding that is where you can open the port that you need to work behind the router.
Aug 12, 2011 | Linksys WRT54G2 Wireless Router
I want to allow port forwarding for remote desktop use, or enable the upnp? Any ideas?
You will need to enter the router setup menu and allow port forwarding there. This requires some knowledge of how the router works. An easier way of doing what you want is to install teamviewer on both computers and then you will be able to do what you want without any configuration. download onto both computers from here www.teamviewer.com
If you found this info useful please vote for me
Mar 16, 2011 | 2wire (1000-400108-001) Router
I am trying to portforward azareus ip adress 192.168.0.1 dlink dir 165
Port-forwarding allows connections from the network, i.e., to TCP port #80 at the IP-address assigned to your router, to be "forwarded" (much like a switchboard operator at a university)
to any specific TCP port (but usually the identical port-number) on a SPECIFIC computer "inside" your network.
If your router is '192.168.0.1', then it probably will give-out IP-addresses like '192.168.0.100'
and '192.168.0.101', and '192.168.0.102' to the first 3 computers on your network.
So, "port-forwarding" is used to designate one of those 3 IP-addresses as the one to receive/process all the 'TCP port #80' traffic.
On the router's web-interface, on the "port-forwarding" page, just add an entry for 'TCP port #80'.
Dec 22, 2010 | Computers & Internet
I want to know how to open my ports and forward them pls
Its simple to open or forward a port. Please go to this website, www.portforward.com and look for Common Ports tab. That will tell how to open the ports.
Oct 22, 2009 | Zyxel P660HW-D1 Router
I cant get a port to open an it needs to be forwarded how can i do this i have a linsys router B i have tryd to forward it like it said but it still says its closed i already turnd the firewall off an...
You should set static IP address on the device first before doing the port forwarding. And the port needs to be specific for certain applications. Go to www.portforward.com for helpful tips about the exact ports to be opened.
Jun 29, 2009 | Computers & Internet
Dont know how to set nat type to open
For you to be able to open the NAT on the router you have to open or forward the application port on it. This router has a graphical interface where you can configure port forwarding, access http://192.168.1.1 (default) username blank and password is admin. Now look for port forwarding and open the port for your application.
Jun 29, 2009 | Linksys Wireless-N WRT150N Router
Open port on router for peer to peer downloading
The port you need to open depends on the specific application you're using.
Go to the website of the application you're using and search their support area for port settings or firewall configuration settings.
Some applications have a user forum where you can find the answer as to what ports are required to be open.
Here's an example of the ports that would need to be open for Limewire: (this does not mean these are the ports that need to be open in your case)
In LW tools > options > advanced > firewall config. Change LW's listening port to 65000 (or try any ports in the range of 49152 - 65535) > apply > ok. If you have port forwarding set up for a modem/router, you'll need to change the port forwarded to match LW's new listening port. If you have a specific port number allowed thru a software firewall, make sure that you allow LW's new port number.
How to configure DI-704P router using port forwarding
Check the reversion number on the bottom of your router.
General instructions for port forwarding are here.
If you need more specific details for a certain application, go from here. (You will have to scroll way down to find the D-Link section)
Dec 19, 2008 | D-Link DI-704P Router
Port forwarding
hi there,
this is a basic step used to forward ports to your system.
Port Forwarding Steps for Routers 1. Log into your router. Usually the URL is http://192.168.1.1/, and enter the username , and the password . If you have never set a password, the password (which you should change) is admin. Consult the manual if you have never set up your router before or need to reset the password. 2. Click on the "Applications & Gaming" tab or Under Advanced, click Port Forwarding.
3. Click on the "Port Range Forward" tab .
4. In the "application" field, type "web" (if you are forwarding wb traffic on port 80) or "torrent" (if you are forwarding bittorrent traffic on port 40156). This is just a "nickname" so that you can recognize what you were trying to do when you come back to it.
5. In the "Start" field, enter: 80
6. In the "End" field, also enter: 80
7. Set "Protocol" to TCP. Web and Bittorrent servers use only TCP, so there's no reason fo forward UDP traffic too and create an unnecessary security risk.
8. In the "IP Address" field, enter: 192.168.1.11 or your system IP address.
9. Click "Save Settings." Forwarding should begin immediately.
Apr 15, 2008 | Computers & Internet
Port fordwording is not working for Radmin port 4899
when you do port forwarding you must know or have a static ip of the device for the application. For example, if you want to forward port 3074 for your xbox live, you need to enter also the xbox ip address on the port forwarding page. Port forwarding is like opening a port on your firewall for that specific application. Make sure also that you have the latest firmware of the router.
Regards
Mar 07, 2008 | Linksys WRT300N Wireless Router
Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2) Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
