HP Deskjet F4140 tantruming
My Deskjet F4140 was working fine until I pulled a piece of paper out from the feeder. It stopped, turned itself off, and nothing I've tried will make it come back on ... I tried rebooting by unplugging and plugging it back in, but I'm wondering whether this is strictly a one-way feeder and once it's started it can't tolerate reverse mode. Any thoughts on how I can get it to work again? I just replaced both ink cartridges. HELP!!
Mahalo,
Beth
  • MakBeth19 Oct 02, 2008
    That worked!!! Mahalo nui =D
  • 33 Answers
Hello!
Try unplugging your printer from the wall outlet and leaving it that way for ~30min.
If this does no help then it means that a fuse has burnt out somwhere in the device.
Sadly there is no manual on how to disasemble a F4140, plus it would void your waranty.
I suggest you try to return it under waranty, just don't say you don't know why it stopped working ;]
Hope this helps!
Posted on Oct 02, 2008
  • Masterrer
    Masterrer Oct 02, 2008
    Glad to help!
Hp deskjet D1660 Pulls papers non-stop and output is blank. New tricolor cartridge just put in. Pulls papers uncontrollably. please help
first check it right side feeder assay latch is ok or not if it is broken then only continues paper pulls out ...
Apr 22, 2014 | HP Deskjet D1660
The paper you scan is stuck
There is debris blocking the paper path in the document feeder. This could be a staple or a shard of torn paper blocking the path wedged into a tooth of the diverter arm or a sensor flag. I would suggest that if there is a small wheel or knob closest to you when you raise the document feed lid, put a piece of #28 lbs card-stock into the document feeder guides, turn the wheel/knob to pull the paper/cardstock into the ADF and continue until it either pushes the shard/debris out or stops moving the paper no matter how much you turn the wheel/knob. This will tell you where in the ADF (Automatic Document Feeder) the blockage is located.
Nov 06, 2013 | HP OfficeJet Pro K8600 Printer
Paper feeder pulls multiple sheets of paper
PULL ALL PAPER OUT OF MACHINE EVEN THE SUPPLY, UNPLUG OR TURN OFF THE POWER TO THE UNIT, PUT A STACK OF PAPER IN THE SUPPLY TRAY & GENTLY PUSH FORWARD NOT FORCING IT UNTIL IT STOPS. TURN POWER BACK ON & TRY AGAIN. YOU MAY HAVE TO REPEAT THIS 2-4 TIMES BUT IT WORKED FOR MY HP DESKJET F4180 ALL IN ONE.
Dec 28, 2012 | Canon PIXMA MP460 All-In-One InkJet...
My hp deskjet f4140 will only scan and coy. It will not print anything from my computer. I used it last night and it worked fine , then it just stopped. Ive checked my devices and printers under my control...
is it giving any error while giving print command? goto start settings printer & faxes open the printer icon by double click .any job is pending in the queue? try remove the usb cable and check t below the pinter icon whether it shows off line?
Aug 04, 2011 | HP Deskjet F4140 All-In-One InkJet Printer
Paper jamming problems with HP DeskJet F380 All-In-One Printer . The paper feeds into the paper feeder but then it seems to get off line and the paper get stuck and actually tears in the feeder. The...
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
Thanks
Newton
Aug 29, 2009 | HP DeskJet F380 All-In-One Printer
Information on how to use rear feed
1. Prepare your doc/file for printing.
2. Insert card stock with narrow side of stock in slot in back of printer until it hits rollers and stops. Don't force in any card stock thicker than max. rated.
3. Change printer setup to feed from rear.
4. Print.
Depending on what software you print from, you may need to change this each time you print if you intend to keep printing from that "tray."
Mar 09, 2009 | HP Deskjet 1120c InkJet Printer
Hp deskjet f4140 not operating
Goto start>Run>type services.msc>try to stop and then start print spooler service
Dec 24, 2008 | HP DESKJET PRINTER, HP OR COMPATIBLE
HP deskjet F4140 Error light on & I can"t print
please reset your printer. turn off your printer, leave it for 30 sec and turn it on again....
If you still have problem try to re install the catridges again, follow below instruction
http://etech.maiila.com/hp-deskjet-f4140-all-in-one-printer-catridges-installation
Good Luck
Nov 01, 2008 | HP DeskJet F380 All-In-One Printer
My HP Deskjet F4140 was working fine until I got a piece of paper stuck. I removed and now it wont print. States printer off line and can not print a test page. IT will copy however.
Turn it off. Unplug the power cord from the printer & usb wait a minute. Plug USB in & than the power cable & turn it on. Next
Open the Printers folder.
Right-click the icon of the printer in use, and then click Open .
Click Printer on the menu, and then ensure that there are no checkmarks next to Pause Printing or Use Printer Offline . If a checkmark is present on either, click the menu option to remove it. If the menu shows Use Printer Online , click that option.
Jan 31, 2008 | Computers & Internet
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
