Question about Sharp FO 2950M Plain Paper Laser Fax
Computer insists on installing a vaild hardware over and over
My printer is well installed and works fine. despite this fact, every time i turn computer on it activated the "new hardware installation" whiz, and askes me for installation disc. when i insert it, installation never gets finished, even though, as mantioned before, there's nothing wrong with printer. suggestions?
    Scholar:
  • 124 Answers
Uninstall, restart, and when whiz appears choose to install manually. only then insert the CD and install. should work fine now.
Posted on Feb 22, 2006
SOURCE:
I recently picked up an older game, Heroes of Might and Magic IV get home and install. Install wizard runs fine except for one thing despite the fact it correctly identifies all my hardware, it tells me...
I have Heroes of Might and Magic 5 Running on Win 7. There were many patches to install before this title worked(on my computer). Have you installed all the available updates for it?
Here are 2 sites that have the compatibility options:
http://techpaul.wordpress.com/2009/06/28/compatibility-tricks-for-old-programs-new-machines/
http://www.sevenforums.com/tutorials/316-compatibility-mode.html
If that does not work, you can also try to set up XP mode in Win 7: (Note: you need to have Win 7 Pro, Enterprise, or Ultimate for this one) Win 7 Home Premium does not support XP Mode.
http://arstechnica.com/microsoft/reviews/2010/01/windows-xp-mode.ars/
Jan 29, 2011 | 3DO Heroes of Might and Magic 4 for...
Printer not found when installing
i thing this is usb wire proplem ,or connect the usb to on board usb jack
Dec 31, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Scanner "not installed"
Try it again after you get Vista Service pack1 installed. My obsoleted HP4200C scanjet started to work again.
Aug 03, 2009 | HP Office Equipment & Supplies
Pictures are printed with stripes and poor color
make sure your printer printed an initialisation or alignment sheet once you installed the new cartridge.
you can try a partial reset of the printer and check if the printer prints fine,also there is an option of cartridge calibration in the printer properties or the printer software installed in your computer
Jun 13, 2009 | Canon PIXMA MP780 All-In-One InkJet...
1700 printer
How did you install the printer?
I have found that if you just let your computer recognise new hardware, it really has a hard time with the USB printing to the 1700's.
Originally there was a disk that came with the 1700 printer. You do want to use that.
During the install, you run the software, and then turn on the printer. (You can have the printer on during the install, but ignore the Windows Wizards that come up).
If you don't have the original 1700 install disk, you can download it from Dell.
The problem is with USB port configuration. These little 1700's are just a pain sometimes if not installed the way they were originally designed.
Jul 31, 2008 | Dell 1700n Laser Printer
My new printer (HP Deskjet D 2360) will not install despite the fact that it should install under the 2300 series.
  1. FIRST TRY TO CANCEL ALL THE PENDING DOCUMENTS WHICH YOU HAVE GIVEN BEFORE THEN TRY TO PRINT IF THIS DOES NOT WORK THEN TRY OTHER OPTION GIVEN BELOW.
  2. CHANGE THE USB WIRE (THE CONNECTION BETWEEN PRINTER AND YOUR PC )IF IT IS TOO OLD.
  3. THERE MAY BE THE PROBLEM WITH USB DRIVERS IN UR PC .
  4. TO RECTIFY --- RIGHT CLICK THE MY COMPUTER ICON
  5. CLICK PROPERTIES AND THEN CLICK HARDWARE N GO TO DEVICE MANAGER
  6. UNINSTALL ALL USB PORTS AND THEN SCAN FOR HARD WARE CHANGES
  7. UR PC WILL DETECT UR PRINTER N ASK FOR PRINTER DRIVERS
  8. RELOAD DRIVERS N UR PC WILL COMMNICATE WITH UR PRINTER.
  9. FOR FURTHER ASSISTANCE FEEL FREE TO ASK AND WISH U SUCCESS -BYE.
  10. please do not connect your usb wire before you install the driver cd connect it when the message comes on the screen "now connect your usb wire to the printer" it will now automatically detecet your printer.
rate this solution as fixya if this helps u to encourage us to solve more and more
Jun 14, 2008 | HP Office Equipment & Supplies
Printer will not communicate with computers
Whenever I have seen this problem it has usually turned out to be one of the solder points on the USB connection in the printer. Of course it could be a logic board problem as well. Well done for testing your problem so thoroughly (eg trying different cables and machines) but I think it needs a repair agent now unless it is under warranty (or you can solder well). Mind you it's probably cheaper to purchase a new one then to pay to have it repaired.
Feb 05, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Would not turn off
What printer exactly?? 7200 hp???
Jan 18, 2008 | HP Photosmart D7160 InkJet Printer
No video on boot up!!
have you tried to uninstall the vedio driver and reinstall it then let me know.go to my computer icon right click it > go to properties >hardware tab > device manager and check if there is any yellow mark showing.kindly do this in starting your computer in safe mode.
Oct 09, 2007 | Gateway 500XL PC Desktop
Problem communicating with the printer
Ok Guys! I found the solution to the nasty "Problem communicating with the printer" AT LAAAST !
I have a lexmark 2480 and I recently upgraded to windows 7 ( I had the same problem with Vista earlier as well) so this problem has nothing to do with your operating system. The mistake I was making was that I first connected the cable and then began installing the setup.exe file. I never got the printer to work after that though strangely the scanner seems to work. I even enabled bidirectional port but it was no help. I tried unchecking the check box that said "save power...." in the usb port device I accessed using the device manger. No. Nothing works.
Finally I found the answer. I uninstalled lemxark. I disabled the firewall. Then Disconnected the cable. Guys this is important you have to disconnect the cable and then only hit setup.exe. You must connect the cable only when the setup asks you to. And it works. I used the setup in my CD which I got when I bought the printer. Despite the fact that my OS is windows 7, 64 bit all works fine!
take care, hope this helps people like me who had to tear my hair apart for 3 hours+.
VJ Koganti
Jul 08, 2007 | Lexmark X1270 All-In-One InkJet Printer
Sharp FO 2950M Plain Paper Laser Fax Logo
54 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
