Question about Dell E207WFP LCD Monitor
Monitor Problems We have a Dell PC that supports 2 monitors. Since July of last year, we've been successfully running one 20" LCD via a DVI cable and one CRT monitor using its integrated cable. Out of the blue, the LCD went dark. The green light turned to amber and nothing. I ended up removing the DVI cable from the LCD and using a regular monitor cable instead and it worked fine. The only trouble now is that I can only use one monitor instead of two. Do you think it's a bad DVI cable (do they just go from good to bad?) or perhaps a video card issue? Thanks TQ
  • Dell Master
  • 19,396 Answers
Borrow a DVI cable from some friend and test it, just in case.
If you want to use multiple monitors, ensure you are using the right settings. Go to control panel>> Display,
open the Display properties box, click the last tab at the top right hand corner, and chose advanced see here for XP, Vista is similar:
Windows XP: Learn how to expand your workspace with multiple monitors
Posted on Sep 09, 2008
Auto detect analog
Hi Jessica,
Dell E228WFPC/E228WFP does support displays with 1920x1080 set resolution via DVI connection while it is restricted to validated Dell brand displays:
  • The restriction applies to resolution higher than 1680x1050 via DVI connection.
  • No restriction with VGA connection, which supports up to 1920x1200.
If you use a DVI connection set your computer's resolution to 1680x1050.
http://downloads.dell.com/Manuals/all-products/esuprt_electronics/esuprt_Display/dell-e228wfp_User's%20Guide_en-us.pdf
Feb 19, 2014 | Dell Computers & Internet
Unclear lettering & numerics
1: Resolving Laptop LCD Lines,
Fuzzy, Color, or Blurry Issues
Verify that the BIOS and Video drivers are the latest available from Support.Dell.Com Website, for more information refer to Dell Knowledge Base article, "How to Use the Drivers and Downloads Website"
Test the LCD in the System Setup (BIOS).
To enter the computer BIOS Setup Screen perform the following steps:
At the first text on the screen or when the Dell logo appears, tap <F2> until the message Entering Setup appears.
Note:
Some older Dell computers use an alternate key sequence instead of to enter System Setup. These key sequences include:
<Ctrl>+<Alt>+<Enter>
<Delete>
<Fn>+<F1> (laptop computers only)
<Fn>+<Esc> (laptop computers only)
If you observe the same issue on the setup screen, it is not an issue with the Operating System, it is a hardware issue, Contact Technical Support/font>.
Run the Laptop Built-In Self-Test (BIST).
To run the Built-In Self-Test perform the following:
Turn the computer off.
Press and hold the D key while pressing the power button. This will start the BIST.
The screen will display multiple flashing colors. Look for lines, distortion, or any other video issues you have observed.
The laptop will restart when the test is finished.
Click the following link to see an English-only video of this test How to Run LCD BIST Video .
If the LCD BIST passes, proceed to Step 4, otherwise Contact Technical Support.
For information on Beep Codes/Error Codes refer to Dell Knowledge Base article, Pre-Boot System Assessment (PSA) Diagnostics and Error Codes For Dell Computers
Connect to an external monitor (if available), for the different types of external monitor ports that may be available on your computer refer to (Figure 1).
Display Port
Display Port is a new digital standard for connecting monitors to computers and has the capability to provide a scalable digital display interface with optional audio and high-definition content protection (HDCP) capability. Display Ports usually resemble USB Ports with one side angled.
A Display Port cable should be used if Display Port connectors are available on both the computer and the monitor.
DVI
Digital Video Interface (DVI) is the digital standard for connecting monitors to computers. DVI connections are usually color-coded with white plastic and labels.
DVI cables provide a higher quality signal than VGA cables. A DVI cable should be used if DVI connectors are available on both the computer and the monitor.
VGA
Video Graphics Array (VGA) is the analog standard for connecting monitors to computers. VGA connections are commonly color-coded with blue plastic and labels.
A VGA cable should be used if DVI connectors are not available on either the monitor or the computer.
Once it's connected, press and hold down the FN and press F8, this should display the screen on the external monitor.
When the external monitor does not work or you did not have one to test with, Contact Technical Support.
When the external monitor does work it may be an issue with the Operating System. Verify that all the drivers are the latest available from Support.Dell.Com Website, for more information refer to Dell Knowledge Base article, "How to Use the Drivers and Downloads Website". When that does not fix the issue the Operating System may need to be reinstalled, for more information refer to Dell Knowledge Base article, "How To Restore or Reinstall Microsoft Windows on a Dell Computer".
Check for visible damage to the LCD. To identify any damage not visible to the ***** eye, ensure you run LCD BIST on the system (refer to Step 3).
If the LCD has damages which is not covered by any applicable statutory warranty, limited hardware warranty and/or Dell-branded service, including Complete Care / Accidental Damage service, there may be a cost incurred by you for the replacement of parts.
Oct 04, 2012 | Dell Computers & Internet
Hi I BOUGHT NEW Samsung SyncMaster P2070 20" LCD Flat Screen Monitor , AND I HAVE HP COMPAQ AND THE MONITOR NOT COMMUNICATE WITH PC
http://support.dell.com/support/edocs/video/p56135/en/connect.htmhttp://support.dell.com/support/edocs/video/p56135/en/connect.htm
you Monitor uses the DVI-I Port this link will show you what it is. you will need a adapter that can connect to VGA port on your PC. unless your HP has a DVI port. You need a DVI-I to DVI-I connection to work if it has one
this link will explain the difference of the DVI ports...
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=120&prodSeriesId=51555&prodTypeId=329290&objectID=c01525281
the adapter you need is a DVI-I to vga ...
opensources_1.jpgcheck the pins on both the pc and the adapter and monitor
Sep 14, 2011 | Samsung SyncMaster P2070 20 inch LCD...
Have A Samsung 940Bw connected via DVI connection and has worked fine for last 3 years. Monitor was on and working fine went out of room and came back to black screen and the blue light flashing on the...
First thing I would try will beusing this monitor with another PC using the same the same setup to see if it works OK. We need to narrow down the cause of the problem first since you have three parts that can be bad; Monitor, DVI cable, PC Video card/PC. It is just a process of elimination to locate the problem.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 14, 2011 | Samsung Syncmaster 940BW LCD Monitor
Monitor is blank. Green power light is on steady.
Self test failed means Monitor is bad.
Check input settings, whether DVI mode is selected.
Dell Monitor has 3 year warranty by default, Contact Dell Techncial support
Jan 13, 2010 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
DVI output problems with Acer Veriton M464
If you are comfortable with opening the case, you can try this: Unplug the power supply, make sure are constantly grounded (touching metal)remove add-in video card. Locate the "Clear CMOS" jumper (usually 3 pins in a row with two shorted via a plastic jumper). Remove the jumper and short the other 2 pins (if originally pins 1-2 with 3 open, short 2-3 with 1 open) for a few seconds. Then replace on original pins. Plug monitor into motherboard video port and power on. If it works, you can leave as is or try to re-install your video card following the same precautions when opening the case and probably changing BIOS settings to utilize the add-on card.
Sep 12, 2009 | Acer Computers & Internet
I have a 20 sceptre widescreen lcd monitor
Have you tried any other monitor connected to your computer since your current problem? Check your connections, make sure your VGA cable/DVI cable are in good condition. If none of that works try to RMA it to sceptre if your still within the 1 year period.
Apr 07, 2009 | Sceptre X20g-Naga III 20.1" LCD Monitor
Computer won't recognize monitor driver
Its the usb, if u connect the monitor via the standard port, the vga port, it will work. If your monitor only have an dvi cable you can fix that by an adapter. That adapter should be an DVI to VGA.
Good luck to you
Dec 11, 2008 | Acer AL2016W 20" LCD Monitor
Inoperative monitor
Here are a couple things to try.
1. try the input select button on the monitor (The minnus button) without pressing the OSD menu button 1st, see if it changes to analog.
http://support.us.dell.com/support/edocs/monitors/1703fps/en/controls.htm
When the DVI self-test screen is up, it is indicating monitor is in DVI mode.
2. If that doesn't work, try a DVI to analog converter on the DVI port on the monitor and connect the analog cable to the converter. See if you get any video that way.
3. If you can access the On-Screen Display (OSD Menu) perform a factory reset.
Sep 29, 2008 | Dell UltraSharp 1703FP Flat panel TFT 17"...
Dell 410XPs + Dell 3007WFP monitor issues
Vinod,
That's quite strange as during system startup you should see the Dell POST logo as at that point the card is only running at VGA, and the monitor will support display at this resolution. If you connect with a normal single DVI cable the monitor should display at 1280x800 also.
Have you tried this? Also have you had this monitor working on another computer at all? What happens if you power up the 3007 with no video cable connected? It should cycle through the pixel test screens. If you are not getting that, and you are not getting the pre POST logo during powerup i suspect that it is a screen failure.
Aug 03, 2008 | Dell Dimension XPS PC Desktop
Dell E207WFP LCD Monitor Logo
106 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
