Visionquest 40 inch lcd tv
Will change channels all by its self and say invalid output
  • 3 more comments
  • sheri500 Nov 10, 2008
    I have the same problem how do we fix it?
  • crc_jandme Nov 17, 2008
    same here.. just started 3 days ago
  • georginaport Mar 02, 2009
    im looking for a code for my tv
  • Anonymous Apr 01, 2009
    same problem...
  • noquest Apr 07, 2009
    Same problem as indicated by andrewcabot.
    Model LVQ40HLS bought 14th May 2007. Of course client
    relation center in Mississauga On , L4W 4X1 at
    1-800-892-6393 said the warranty was expired ( I did not buy
    extended warranty) But from what I gather now, this is a
    manufacturing problem. Anybody ready to do something
    about this I am ready to join in.
SOURCE: 3 year old Samsung 40 inch LCD TV will not turn on
The problem is 4 capacitors on the power supply board. Just had mine done under warranty. They (Sears) replaced the whole power board but you can get larger capacitors and just replace those for alot cheaper if not under warranty.
Posted on Jan 30, 2010
  • 15 Answers
SOURCE: hdtv lcd 40 in. broken screen face
There is no glass or plastic screen infront of the LCD panel.
If the screen is damaged you will need to replaced the entire LCD panel.
Posted on Dec 15, 2007
SOURCE: Samsung LE40R73BD DTV freezing, wont chnage channel
i've just some digging around and found that you can access a service menu and perform a reset which sorted the issue for me.
Access the service menu by pressing, in order, whilst the tv is in stand-by mode:
info
menu
mute
power
when the tv comes back on you will have a service menu; select option 12 (reset) the tv will then switch off.
this will reset your TV back to factory defaults.
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK (it did for me)
HTH
Posted on Apr 30, 2008
SOURCE: 40 inch lcd blue line vertical
Have just purchased Samsung LA32R81BD have thin blue vertical line a third into the left hand side of the screen. A pity no support on a sunday or public holiday! Tried the squeeze theory without joy. Will attempt swap and see what excuses the dealer has? Thanx for advice fixya!
Posted on May 03, 2008
xCAUSALITYx
  • 210 Answers
SOURCE: My SOny Bravia 40 inch LCD TV has a vertical line
It could be 1 of 4 things:
1. One of the ribbon cables has worked itself loose (Simple Fix)
2. One of the assembly boards maybe faulty
3. The driver board which feeds the panel maybe faulty
4. The panel is faulty
The driver board in the UK costs approx £70 and approx £35-70 to fit it if this is the fault.
All other parts are between £80-160 and approx £35-70 to fit it if this is the fault.
The panel will cost approx 50-75% of what the TV was worth when you bought it - "Repair versus Replacement"
Thanks
Posted on Oct 01, 2009
How do i give my tv an hdmi channel? Do i have to buy a hdmi cable? and if I do which cable? I want to use an xbox one but It won't show due to me not having an Hdmi channel so I was wondering howican
HDMI is a data protocol and includes the associated ports and cables it is not a channel. If Your TV Does not have an HDMI port you can use a converter to change it To a connection your TV Does support. Be aware a cable with the appropriate ends is not the same as a converter...a converter changes the language to something the tv can understand.
Jul 30, 2016 | Sony Bravia KDL-40S4100 40 in. LCD TV
VISIONQUEST FLAT SCREEN TV
Check and replace the main system control memory IC. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
May 29, 2016 | Televison & Video
My visionquest 47 inch Rembrandt tv keeps displaying "lost database" when turned on
Contact the authorized service center. It sounds like a corrupted firmware. Firmware update might be necessary. Gopakumar Gopalan Google
Feb 03, 2015 | Televison & Video
Visionquest tv needs to be reset without a remote
You don't say what model it is but usually there are power, volume, channel, etc, buttons on the side or the top of the tv. Look well. They try to hide them. This link might help.....
http://www.nokia.com/us-en/support/product/c6-00/userguide/?action=onlineuserguidepagechange&pFile=GUID-7774D2C2-534C-4EAB-9970-BC847B9DB674_FILE001.html
Sep 11, 2012 | Televison & Video
3D tv issues with HD channels on Dish Network
check screen resolution of your lcd tv & receiver too
Aug 24, 2012 | Dynex DX-L42-10A 42 in. LCD TV
Whats the process to change RF to channel 4?
1 Press POWER to turn the power off.
2 Press TV/VCR, current VCR Output Channel will appear on the LCD display.
3 Each time TV/VCR is pressed for 2 seconds, the LCD display changes as follow
clock press tv/vcr RF3 2 secondes later RF4.
• VCR Output Channel is automatically set during EZ Set Up.
1. If Channel 3 (or 4) is an active broadcast channel in your area, the Channel 4 (or 3) will be set.
2. If both channel are the active channel or none active channel, the VCR Output Channel will be set to Channel 3.
• Cancelled the EZ Set Up by pressing POWER during EZ Set Up before setting the Output Channel.
• VCR Output Channel will not change to previous VCR Output Channel if TV/VCR is pressed continuosly for more than 2
seconds.
May 27, 2010 | Sharp VC-H965U VHS VCR
Samsung 40in tv
either the control panel board or the main board has a problem.probably channel change botton on control panel is stuck or shorted.
Dec 28, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
New samsung 40 inch LCD. When in the wide mode
if you are watching cable or satelite, you need to change the screen format output from the source to make sure it matches with the TV
Jun 14, 2009 | Samsung LN40A550 LCD TV
I have a 42 inch lg plasma,and everytime i hook up my ps3 it says invalid format
ok, have you tried hooking up your PS3 to a different tv and it work? if so, you may have to change the settings in the PS3 to fit the LG tv. or, it may be in the menu options of the tv for a specific channel or setting. reading directions for hookup is a big help too:P
Apr 04, 2009 | LG 42LC2D 42 in. LCD HDTV
Set up a channel ( 2,7,8,9,10,sbs ) on TV sony LCD
If you want to set up tv channels in your tv, connect antenna cable in RF Input at rear of tv, go to tv menu and select preset, then press auto-preset and rest will do tv itself.
Sep 18, 2008 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Televison & Video Logo
566 people viewed this question
Top Televison & Video Experts
Electro Med Services...
