Question about Husqvarna Sewing Machines
Correct tension I have recently bought this overlocker second hand and without a manual. Could you lease tell me where I could get one from as I am having trouble getting the tension right. Thank you Dell
I bought a manual and fixed it myself with patience.
Thanks for your email.
Posted on Sep 09, 2008
Difficulty to do needle threading on S4D overlocker
Sergers are absolute "bears" when threading compared to sewing machines. If/when you get frustrated, walk away. It took me the majority of one day before successfully getting my first serger threaded properly. Using four different color threads is also helpful when learning the serger--especially when it comes to adjusting the tension.
It is very important to pay attention to the order the threads are threaded, as well as making sure the thread path for each is correct. (Consult your owner's manual as different brands will look different.) Most machines require that the upper looper be threaded BEFORE the lower looper because the lower looper thread will cross OVER the upper looper thread as the final step before going under the presser foot.
ALWAYS RAISE the presser foot when threading!!! This releases the tension disks.
Also, when threading through the tension disk, be sure to give the thread an extra little tug to make sure the thread seats firmly in the tension disk. (Grasp the thread just below the thread stand with one hand and then grasp the thread below the tension disk with the other hand and give a little tug--sometimes it will make a little popping noise when it seats.)
Start out with the tensions set at the midway point. From that point, you can test your machine to make sure it is serging properly. Then you can adjust the tensions to suit you or the project you are making.
If the either looper thread breaks or pulls out, remove BOTH looper threads and rethread from the beginning!!! Trying to finagle threading of only one thread will most often result in a machine that will not operate correctly. Just bite the bullet and rethread both threads (in the order specified in the manual).
I seem to have trouble using the tweezers to thread the looper eyes, so I use dental floss threaders instead.
floss threaders Google Search
One more hint: NEVER pull the thread out of the machine by pulling it UP through the machine. This could damage or wear the tension disks. Always clip the threads just below the thread stand, RAISE the presser foot, and then pull the clipped threads DOWN through the looper eyes and needles.
Be sure to clean and oil your serger frequently. This is very important to get the best performance from your machine. Use only fresh oil recommended by the manufacturer and apply only a couple drops each spot.
How to Thread Serger Overlock Machine How to Thread Serger Overlock Machine
Empisal Overlocker S4D User manual
Jun 14, 2016 | Sewing Machines
Brother overlocker
Hi there
Please can you help. I bought a second-hand brother M14-B551 overlocker. The needle broke and i am now battling to thread . Where can i get some help.
Jan 13, 2014 | Sewing Machines
Cannot get tension on overlocker correct
I put a different color on each spool for a better understanding of where the issue is.
Dec 05, 2013 | Sewing Machines
I dont know how to set the correct tension on my Empisal mercury model 404 overlocker
try checking with these sites and call or email them and ask
them if they know where to get a manual
sewvacdoctor.com
a1sewingmachines.com
Feb 23, 2013 | Sewing Machines
I have an elna overlock Pro 5DC, which I bought new years ago. The dealer went out of business, and with her the repairman who knew Elnas. When mine developed a problem, I had it serviced by an all-brand...
If you google elna overlock pro 5dc, I found this site and you can download your manual for $10, hopefully it will help you.http://www.tradebit.com/filedetail.php/30251842-elna-pro-5-dcde-sewing-machine-owner
It is so frustrating to have a great machine and no one can help you. Good luck
Sep 21, 2010 | Elna Sewing Machines
Hi, I am unable to do a overlock stitch , elna l1
Check with sewusa for a threading guide and manual.
Look inside the font door of the machine to see if there is a threading guide.
Feb 28, 2010 | Sewing Machines
THREADING FOR JUKI MO 357
Put new needles in it.
Following the colors, thread the upper looper first, then the lower looper. Next thread the needles. Always thread in this order.
Jun 27, 2009 | Juki MO-644D Mechanical Sewing Machine
Starting overlocking
hi there,
check & correct the FF:
  • Correct thread tension.
  • Replace needle.
  • Replace needle with correct size.
  • Use proper thread or needle.
  • Check threading order.
  • Increase pressure on presser foot.
  • Reset needle.
Jun 01, 2009 | Bernina Sewing Machines
Bernina overlocker 203 locking thread is not sewing on fabric
You need to adjust the tension for your threads. Use scraps to test sew as you adjust the individual threads to bring them into proper balance. Your manual will tell you how to do this.
May 12, 2009 | Bernina Bernette 75
Janome 184D - thread tension
You may need to purchase a Gathering Attachment
Part No. 200 217 101
BUT be sure it is suitable for your model first
(I am unsure which one you have)
Thread tensions are set at manufacture to all = 3 for standard work, your manual is generally helpful for many answers.
The "Janome Overlocker Sewing Guide" is a very detailed publication and has this to say about Gathering without any additional attachment.
Oct 30, 2007 | Janome MyLock 634D Mechanical Sewing...
Sewing Machines Logo
117 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Bargain Box
Bargain Box
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
