Question about Dell Inspiron 6000 Notebook
S Video cable
I've been trying to hook my laptop up to my TV with an adapter system (its an old tv) and for some reason I cant get a picture. Even when I tried a straight cable to flatscreen it didnt work at all. Is there some sort of software I need for this to work? Its been two different cables on two different tvs, but Im beginning to think its my laptop...please help!
  • 56 Answers
You need to toggle the display on your laptop. be sure that when you connect the tv or external monitor the laptop should be turned off. to toggle the display kindly press Fn followed by F8. for old tv's you need to have an S-video cable. for LCD monitors, either VGA or DVI cable will help.
i hope this info helps you.
Posted on Sep 17, 2008
No video signal using HDMI cable.
This sounds similar to my Vizio's second HDMI port; they sometimes become finicky after a while. You may have to just adjust and wiggle the end of the cable inserted into the TV; if it works, then make sure you don't even slightly touch it or else it'll lose signal again. If you have any other ports, try them instead; otherwise the problem may eventually get to an unusable point. You will have to have the port repaired or the TV replaced.
Jan 30, 2018 | Toshiba 47ZV650U TV
My hdmi connection for dvd & cable have both stopped working. The receiver is flashing
Unless you've been pulling it in and out, it shouldn't go bad. I assume you've checked to be sure it's properly connected.
HDMI cables should cost less than $20. If you were talked into a $100 cable, you were taken advantage of.
HDMI has a function called HDCP. The TV source and TV have a conversation over it to make sure that only an approved device (your TV) is connected to the cable. This is for copyright protection reasons.
Have you recently connected a new source (cable box, DVD player, whatever)?
Your problem can be in the TV, the cable or the source.
Try substituting for each to determine what's failed.
If you have your TV now hooked-up with component, you may have discovered that there's little or no difference in the picture
Aug 04, 2012 | Sherwood NEWCASTLE R-774 7.1 RECEIVER WITH...
When I hook up my SNES there is no picture - what do I do?
Well onlhy use the old consoles on CRT tv styles then.
Apr 08, 2012 | Nintendo Super NES Console
Can connect iPad and Mac Powerbook laptop to my Sony 36
Hi Jim
It's not on a channel, it's the RGB or VGA inputs. (check your "Source" menu on the TV). Works fine here. When the units are talking to the TV the screen on the unit will go blank. One thing. When using your iPad, tghe battery will go down faster than normal.
Feb 20, 2012 | Computers & Internet
How to connect dish tv to my laptop? It has inbuilt tv tuner.
Your Lenovo laptop can be hooked up your TV if you have a model that is capable of TV output. Newer models with HDMI ports can easily connect to newer TVs that have HDMI input jacks. For older laptops or TVs, you will need other adapters or cables. The most common of these is an S-video jack, which has a small round connector with several pins arranged in a circle. For S-video connections, you will need to hook up the audio from your laptop to your TV separately.
Things You'll Need
HDMI cable
USB-to-HDMI adapter
S-video cable
Audio cables
HDMI Connection
Turn on your Lenovo laptop and HDMI-enabled TV.
Connect one end of your HDMI cable to the HDMI port on your laptop. Lenovo's IdeaPad series has these ports. If you have a ThinkPad or other Lenovo model, connect a USB-to-HDMI adapter to your HDMI cable, then plug the USB end of the adapter into any USB port.
Press the "FN" and "F7" keys on your keyboard. This will switch the laptop's display to the TV. You can then use your TV screen as a monitor or use the laptop's DVD drive to watch movies on your TV.
S-Video Connection
Turn off your laptop and TV. Connect your S-video cable to the laptop on one end and the TV on the other.
Plug audio cables into your audio out jacks on the laptop. If you do not have stereo audio output, you can use the headphone/speaker jack. Add a splitter adapter to split the sound into stereo instead of mono (single speaker). Plug the other ends of the audio cables into your TV.
Turn on the laptop and let it boot up. Then turn on the TV. Right-click on your desktop screen, then select "Properties."
Click the "Settings" tab, the "Advanced" button, then "ATI displays" or "Display device" or the similarly worded option, depending on your system. It is not the "On screen displays" option in any version.
Click on the option that suits your system, such as "TV" or "LCD." Click "Apply," then "Yes" to confirm, if necessary. Click "OK" to exit. Your display should be visible on the TV screen. If not, try pressing "FN" and "F7" to toggle the display to the external screen.
Sep 13, 2011 | Lenovo IdeaPad Y560 Laptop
My RCA XL100 is hooked up to cable and works perfectly fine. We've had it for ages and the picture is clear, sound is beautiful, and it gets along fine with my universal remote. There's just one...
Some of their very old sets the video input was located on channels in the 90's; Try scrolling down from 99 to 90 to see if you locate the video input; this is just the way they did things in the older sets.
Before you rate this solution let me know what you find first.
Jul 08, 2011 | RCA Televison & Video
Hi. I've just hooked up my 3500S to a new Samsung
  • Make sure your SCART cable is fully cabled...for IN and OUT connections..
some SCART plugs works one way..I recommend to replace it with another one at least for testing..
  • Second option,buy an SCART to RCA/S-video adapter and use that one for "s" connection..
here is an example of SCART TO COMPONENT & S-VIDEO adapter on the URL below..
Hope this helps!
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 12, 2011 | Philips HTS3500S System
How can I connect my notebook to my TV
In order to display PC video on a TV the PC must have a TV-OUT function and interface, or you need a VGA to TV converter box.
If your PC has TV-OUT functionality, your user manual will tell you this. If you have, Google "Display PC on TV" and you should find some good articles on how to connect the PC to the TV, and how to change the settings on the PC. NB. even if your PC supports TV-OUT, you may still need to buy a converter cable (but not a box).
If no TV-OUT functionality, E-Bay lists some converter boxes from about £15. NB. the much cheaper cables only work on PCs with TV-OUT functionality.
Oct 03, 2009 | Advent 4211c Notebook
How and what do I need to hook up my laptop to the tv
You have many options but probably the easiest is to use an S-VIDEO cable.
If your laptop has HDMI you could also use that method but the cables do tend to cost a little more (worth it though for quality picture)
If you TV has a VGA connector then that is probably the cheapest and quickest way to get a quality picture.
If your laptop came with an S-video to composite (phono) type adapter you can also use that but the picture quality is not as good.
Your TV has DVI and S-video so one of those would be a good bet. dont cheap out on the cables though !
In my experience many cheap S-video cables are useless when it comes to hooking up computers to a TV
Aug 09, 2009 | Mitsubishi WS-65413 65" Rear Projection...
HDMI for PS3 Doesnt work
do you get picture on tube tv if so hook up to tube tv go to settings and set for hdmi then turn off and take to hd tv hook up with hdmi cable and should work you need to set hdmi in settings as it will be set for s-video at 480p I do believe
Dec 26, 2008 | Sony Playstation 3 (PS3) Console
Dell Inspiron 6000 Notebook Logo
105 people viewed this question
Alun Cox
