Question about MTX Thunder 81000D Car Audio Amplifier
I LIKE TO HAVE SOME ONE TO FIX MY AMP.
Any recommendation to send and fix my amp.which is MTX THUNDER 8 1000 D don't work ..Need to be fix it.
    Problem Solver:
  • 5 Answers
You have to send it to mtx. Most repair shops wont touch it. You can call mtx i had the same amp. It cost about 85 bucks plus shipping. the 85 bucks covered return shipping also.go to there web site it has the info for tech support and repair issue there. hope this helps
Posted on Sep 17, 2009
How do I Bridge MTX Thunder 404 400 watts into one channel
The mtx thunder is a 4 channel amp. 4 channels can't be bridged to 1 speaker. You can only use one side of that amp to bridge your speaker. Unfortunately your now only using half your amp.
Nov 25, 2016 | MTX Car Audio & Video
My mtx ts5510 stopped working while driving. Was hooked to an mtx thunder 81000 class d and its still working. ????
Inspect speaker for loose wires/broken wires. Check inside box for loose connection. Blown fuse on amp. Ive literally pulled the wires out of the speaker. The little mesh ones from the terminal to the cone. Look for that. If you do find something broken or bad. remember you can call MTX and fix for a flat rate on most evrything they carry. Ive sent several amps there. normally around $100
Mar 25, 2011 | MTX TS551022 Car Speaker
I installed a MTX Thunder 3401 with a PA sub. after turning the car oh every things works great. After about 2 mins of play, the thermal light begins flashing red and it will shut off the amp. After the...
You are def overheating, If the ohms rating of the subwoofer is too low it will cause this same thermal over heat. If you have 2ohms in sub and a 4 ohms stable amp, you will overheat. Check the ohms rating of the sub to make sure this is not the problem
Jan 31, 2011 | MTX Thunder 3401 Car Audio Amplifier
I have a mtx thunder 421d. I've had it about 5 years,about a week ago it started going out from time to time. I checked my hot wire and fuses,they are ok.Now the amp stop working, and dont light up. Will...
If you have proof of purchase(invoice or receipt) showing the purchase date and you are still within the warranty period then yes it would be repaired by MTX under the warranty guidlines, and by the way MTX is great at customer service and they are great to work with(very fair)!!!!
Keep in mind that the seal on the bottom of the amp cannot be broken or that will void warranty coverage.
Give them a call, you will be glad you did!
800 225 5689 - MTX Customer Service & Amplifier Service Center
Good luck !
Jan 31, 2010 | MTX Thunder 421D Car Audio Amplifier
Sub not working and red light on amp stays on?
the amp is under to much pressure get a bigger 1
Nov 18, 2009 | MTX Thunder 421D Car Audio Amplifier
Has mtx stop selling the mtx ta81001?
Hello t3h_b,
The MTX web site shows the amp as a current product.
http://www.hifisoundconnection.com/ sells the amp and claims to have it in stock. However, MTX lists only 2 authorized online resellers:
www.crutchfield.com and www.sonicelectronix.com
Crutchfield doesn't list the amp at all and SonicElectronix shows it as "discontinued". I'd recommend going to MTX's contact page and ask them directly. They'll usually respond within a day or two.
Hope this helps.
Oct 06, 2009 | MTX Thunder Class D Mono Amp (TA81001) Car...
I have one mtx t4510-04..what amp do you
Hello jandytaala,
The recommended power range for you T4510-04 is 112.5 to 225 watts RMS. So you need a monoblock amp within that range. You could go up to about 300 watts RMS, but watch the gain and don't try to get too much from a single 10" sub.
The Orion Cobalt shown here would be a good match and is only $139.99. For another $60, the Alpine MRP-M500 will output 300 watts into 4 ohms.
Hope this helps.
Aug 28, 2009 | MTX Thunder 4500 T4510-04 Car Subwoofer
Mtx ta7801 amp not working
Depending on where you live, Car Tunes is a good place to fix it but it might cost a good amount. I have a mtx 1501XD and the same problem, lights but no sound i saw no marks inside mine however. They told me i was better off buying a new one bc it was going to cost so much to fix most likely. That was coming from a guy I know so they were just trying to **** money out of me either, he does sound for a living.
Feb 25, 2008 | MTX Thunder 8302 Car Audio Amplifier
Amp works fine i think??? but Prsim efx not working at all
You need to contact MTX tech support before the warranty runs out. You'll probably have to get an RA number to send it back.
http://www.mtx.com/caraudio/contactMTX.cfm
Oct 18, 2007 | MTX TA4501 Thunder 4501 MonoBlock Car...
MTX Thunder 81000D Car Audio Amplifier Logo
169 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
Mark Skinner
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
