I have a lg monitor hooked up to my hp pavalion. After being on for some time the monitor will black out and i have to reboot. how can i fix this problem?
Your screen resolution or refresh rate is set out of limits for the monitor. Check your monitor documentation to determine the correct resolution and refresh rates for the monitor. Then reboot the PC, go into SAFE mode, then re-adjust the display resolution there. Once you reboot after that, the monitor should be fine.
If the computer is attached properly and you get the flashing lights it is due to switch mode power supply being faulty, too expensive to fix I think you will find, never seems to be anything like just a fuse I'm afraid, modern worlds tells you its time for you next monitor..... do try to ensure it aint the pc by hooking laptop or something else to this unit, or hooking another monitor to your pc to be sure but I find power supply failure is normally how monitors leave this world...
I solved the problem myself by disconnecting the monitor from the computer and then I unplugged the computer. I restarted the computer in position fail safe (F8) and tried to change the monitors resolution back to origin, failed to do so and rebooted instead. When Windows loaded up the problem was gone! Yipeyiiiii!
