You should be able to hear the pump run inside the fuel tank. on the firewall there is a relay under the black cover on the passengers side, thats the fuel pump relay. the ORANGE wire should have 12V, The wire going to the pump is GRAY and should have power when cranking. . theres also a 20 amp fuse there, make sure its good. If the gray wire has power, most likely the pump is bad. At the pump there is a BLACK wire that attaches to the frame near the left rear wheel, thats the ground for the pump make sure its good and tight.
