Question about Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum
Bissell Proheat 7901 8910 Series Problem
I have a Bissell Proheat that needs to be cleaned in the floor nozzle area. I need to know how to take it apart to clean it. Any ideas. I don't really want to start unscrewing things.
Linda
Zigmolio@hotmail.com
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
yoi
Posted on Sep 30, 2010
The heated solutions only sprays out to the floor in a 3 inch area. It takes a long time to clean the floor with only 3 inches available. Are there some nozzles somewhere on the machine that I need to...
There are two nozzles (either red or white) on the unit located behind brush. Use an old toothbrush to clean them off and that should resolve the spray issue.
Nov 22, 2010 | Bissell 1699 ProHeat Clear View Upright...
I have a ProHeat Bissell 8910 Series. Won't release or pick up
heatman101
yoi
Mar 20, 2010 | Bissell 8910 ProHeat Clear View Upright...
I have a bissell proheat plus x2 and its not
did you try turning it off for a minute? let it reprime/ if that doesn't work, check the spray nozzles on the bottom. you may have to blow them out!
Mar 16, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Fllor nozzle window blockage
take the 2 screws out near the front outside edges then just lift it off
Jun 30, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell proheat 2x will not send out fluids in hose or floor area
heatman101
tulty
Feb 02, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell ProHeat Clearview Steam Cleaner - need steps to clean the clear input area. I have removed the four screws and need to know how to finish the removal of the clear plastic input area.
For the clear outer nozzle, there are 2 screws holding it in place. Remove those, then from the bottom lift it up. Sometimes the seal holds it really tight and you may have to carefully pry on the sides until it loosens up. Then when you put it back on, at the top are 2 tabs, make sure they snap into place then lower the nozzle and put the 2 screws back in.
Jun 22, 2008 | Bissell Vacuums
How to clean
I have found this so i think this answers my question.
Question         How do I remove the clear floor nozzle window on my machine?     shim.gif     Answer         Before starting, please be sure the machine is not plugged in and the machine handle is reclined.
To remove the clear floor nozzle, first detach the phillips head screws located at the base of the clear floor nozzle. Then, remove the tank in tank assembly. Next, remove the rectangular gasket at the top of the nozzle, and pull the clear floor nozzle forward to remove the tabs from the notches. This clear floor nozzle is removable so you may be able to access this area and clean.
When putting the clear floor nozzle back in place, please be sure the tabs at the TOP of the nozzle are properly inserted into the notches provided. If you do not have the tabs in place properly, you may have a problem with the machine's suction.
Rotate the window down into place, replace the screws, and replace the rectangular gasket.
If you would like additional assistance, please contact BISSELL Consumer Services at 1-800-237-7691, Monday - Friday 8 a.m. to 10 p.m., or Saturday 9 a.m. to 8 p.m., ET or email us by clicking on the Email BISSELL tab at the top of this page.
Reminder: When you have completed the deep cleaning process, it is recommended to return the SmartMix dial to "Water Only" prior to storing the machine.     shim.gif     How well did this
Oct 10, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum Logo
157 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
