Question about Maytag MGR6772 Gemini Gas Kitchen Range
Oven lights will not turn off, Maytag gas double oven range Prec. touch 750
After cooking in the upper oven today, my wife noticed that both oven lights were on. I tried to turn them off but the oven light button just beeps when activated. I individaually tried the plunger switches on both doors but that did not work either. I also unpluged the stove with the hope it would cancel the lights but they came right back on when i plugged it back in. I assume it is something in the touch pad since both lower and upper lights are affected.
  • 750 Answers
Hello bohlke75,
Welcome
You said, After cooking in the upper oven today, my wife noticed that both oven lights were on. I tried to turn them off but the oven light button just beeps when activated. I individually tried the plunger switches on both doors but that did not work either. You also unplugged the stove with the hope it would cancel the lights but they came right back on when i plugged it back in. You assume it is something in the touch pad since both lower and upper lights are affected.
Did you leave the plug out for 5 minutes or just do it quickly?
if it only happens on one door then the plunger switch is bad!
if it's both doors then you have a button or control problem. Service can give you a true diagnoses with out the cost of swapping parts randomly!
If it was the plunger you may have been able to get away with a do it your self repair!
Let me know how you do
Thank You,
Huuum
Please remember to leave a rating!
Posted on Oct 16, 2008
When using oven it beeps twice and oven light comes on and oven shuts off
[PDF]Bosch Hbl8650uc Use And Care Manual - Cloudfront.net
https://d1vofmza27mmhi.cloudfront.net/.../bosch-hbl8650uc-use-and-ca...
foods with the appropriate oven mode, temperature, rack position and bake time. This section also ..... Preheat. Light. Lower. On/Off. Upper. True. Convection. Speed. Convection. Broil. Bake. Roast .... Cook Time: Turns off beep for the end of cooking time. •. Timer: Turns off ... Press Timer twice to exit the timer menu. Note: •.
PDF]Use and Care Manual for Bosch Electric Built-in Single ...
pdfstream.manualsonline.com/.../9d658fa3-efaf-44a3-beb6-bc5f9c80d5...
realize the full potential of your new Bosch oven as well as protect it from damage ..... On/Off light. • Heat light. • Door lock light. • Timer/Manual selector knob .... the display will come on showing all the call-outs, .... Electronic Control of Oven. Immediate. Start/Automatic. Shut-Off. To use the .... Depress Cook Time button twice.
Dec 02, 2015 | Bosch HDI7152 Stainless Steel Dual Fuel...
Model GE JE2160CF02 microwave - control panel lights up and you hear the beeping sound when you press the buttons, displays count down but the oven/microwave does not turn on when you touch start
If - when you enter a cook time and press "Start" to begin cooking - the inside light, internal cooling fan, and turntable _all_ come on, then you have a failed cook relay that needs to be be replaced (details here) or an open magnetron thermostat (part number WB27X10567 from the Pros here).
If those are not coming on, then you have a defective upper door switch, or that switch's mount is broken or loose. Our help file on door switches is here.
You can find helpful exploded view diagrams and order other GE parts here.
Before proceeding, see these links:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
Sep 07, 2013 | Electrical Supplies
My whirlpool double oven accubake GBD307PDS09 display went blank!!!! HELP!
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty. GBD RBD Whirlpool Oven Problems Causes and Solutions
May 03, 2017 | Whirlpool GBD307PD Electric Double Oven
Whirlpool Range RF385PXG tripped circuit and now red lights r out
A wild guess is that one of the oven or cooktop Calrod elements MAY have shorted. Sometimes there is evidence by color of the element at a pint or a hole blown out near where it shorted.
Oct 19, 2009 | Kitchen Ranges
Emerson MW8997B desktop microwave beeping
Hi, probably something happened with the PCB due to an abnormal current fluctuation.
You should go to a service center.
Nov 13, 2017 | Emerson Microwave Ovens
Whirlpool Accubake System Mod.# RBD275PB10 front panel blank
Hello Edward!
May 13, 2017 | Whirlpool RBD305PD Electric Double Oven
Beeping with 'f2' & 'f3' message when cleaning but did not finish cleaning. Oven now cooled but still locked.
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$@#
May 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Night Light
Replace the touch panel. One or more buttons are failing.
Feb 03, 2009 | Frigidaire PLMV168 Microwave Oven
Oven won't pre-heat
you have either a bad touch panel or a bad control board. try reseating the ribbon cables on the control before replacing. just remember to turn the power off before opening the unit
Dec 02, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
Sharp carosel R310FK-keeps going
control panel is hung up - replace panel and keypad.
Dec 28, 2007 | Sharp R-510HW Microwave Oven
Open Questions:
Maytag MGR6772 Gemini Gas Kitchen Range Logo
1,011 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
