Tv has snow screen but plays movies fine, just no cable channels come in clear, some one has said maybe tuner. Sanyo DS24425
  • 374 Answers
It may very well be the tuner. If it has another means of connecting to the tv try composite or component cable. If that isn't possible try replacing the coax from the wall plate to tuner and from tuner to tv. This is if you have a cable box also called an STB in your home. If you do not have an STB try changing the coax from wall plate to tv. You may even want to replace the barrel on the wallplate as well. If the cable runs through the VCR disconnect it and run it straight to the tv and this will determine if the problem is in the VCR.
Hope this helps you out.
Posted on Sep 09, 2008
My tv sanyo cm21kf81A, chassis number FC3-G221 has snow noise on all tv channels, but AV1 and AV2 play good sound
First check cable wire or whatever is connected to set for channels--the leads are connected and wiggle them with set on to see if it clears up--could be a connection where cable wire is connected at end--loose connection there etc.
If tuner is bad causing this and you use a box for signal--most have rear audio/video outputs you can connect to a unused video/audio input on rear of set---bypass the tuner in the set and operate set that way changing channels on box instead of set.
let me know if you have questions or have more information.
Mar 21, 2012 | Televison & Video
Scheduled a timer recording of a program on a DVD+R and when I went to play it back all I got on the screen was noise and snow. I now realize that I used the wrong disc (should have used only DVD-R). ...
Hi,During timer recording adjustment you must have selected what ever you want to record..i.e: Tuner Channel , or ,Video1 input ,or Video 2 input etc..This problem is related with Source selection but not with - + type Disc..wrong disc will refuse to record at the beginning..
The noise and snow shows that your recorder was Recorded an unadjusted RF channel..thus no TV signal was available during recording ..
I assume that your DVD recorder has built in TV tuner in...To correct the problem,first you make an automatic Ch set up ,search the available channels either on the Cable (if you have ) or RF local channels thru Arial Antenna..
than you try to record again by carefully selecting ..you will record TV RF channels successfully. Or you can attach another video source to your Recorder thru the RCA cables on the back panel and by selecting the respective SOURCE in accordance withe cabling you have made than you will record the AV signals available on your Receiver..
If you need more help pls let me know for further advise.
Aug 10, 2011 | Toshiba DVD Recorder
Can I get more channels?
go to the menu and navigate to auto-prog(ram)
Feb 24, 2008 | Sanyo DS31520 31" TV
Sanyo TV has no picture or sound
better to take this tv to service shop,possibiliy defective or cracked tuner,broken pc board,cold or intermittent solder in power supply or in main board..
Dec 16, 2007 | Sanyo DS24425 24" TV
TV. dpops channes
Bill, your set has a bad tuner, only fix for that is to R & R the tuner, 2nd option would be to use your vcrs tuner input and then RCA out cables from vct to input on back of tv, If you have never done this re-post and I`ll walk you through it, let me know, BMW Rider
Dec 04, 2007 | Sanyo AVM-3258S 32" TV
Sanyo tv # DS35580
you need a new tuner
Dec 04, 2007 | Televison & Video
Stuck on Channel searching!!!
the problem is we have no cable-none at all. The tv is used only for playing DVD's. solution check dvd to tv wire or socket if it is ok then play dvd in another tv if it works fine then problem in tv. for that check tv tuner & its circuit for loose. check tuner itself
Sep 11, 2007 | Sanyo DS20930 20" TV
Sanyo DS24425 24" TV has great sound and no picture(black screen)
if tv have black screen,increse screen control to see vert ic is defective,and if screen is white with lots of line acrose ,you can find open resister,on pic tube board,or in main board near transformer.
May 20, 2007 | Sanyo DS24425 24" TV
Tv channels are not coming in
it seems that there is a problem with your tuner. check inside if there are cold solder especially the rf connector jack of the unit.
Jan 08, 2007 | Philips CCC130AT 13 in. TV/VCR Combo
Snow on screen/wiggle the coax
SOUNDS LIKE BAD SOLDER CONNECTIONS IN SIDE THE TUNER. TAKE THE BACK OFF AND TRY TAPPING AROUND WITH YOUR DRIVER HANDLE THIS WILL LEAD YOU TO WERE THE PROBLEM IS. THEN WE TAKE THE TUNERS APART AND RE SOLDER THE CONNECTIONS,BUT YOU HAVE TO BE VERY GOOD OR YOU WILL MAKE MATTERS WORSE.
Apr 11, 2006 | RCA P52830BL 52" Rear Projection...
Televison & Video Logo
101 people viewed this question
Top Televison & Video Experts
