Question about Sony FD Trinitron WEGA KV-36XBR800 36" TV
Wega XBR My TV will not turn on. I have unplugged it for several hours. When I plug back in and turn TV on, it makes the sound like it is going to go on, but does not. I get a blinking like by the power button that indicates it is in stand by mode.
  • kevinnj66 Sep 09, 2008
    I have the same problem on my Sony Trinitron Model KV-36XBR800. It clicks like it wants to turn on and then clicks off and I get the red blinking light. Mine blinks 6 times. This has been ongoing for over 2 weeks where sometimes it works and most of the time it doesn't. The TV is super heavy and taking it to a shop would be brutal. Is there an easy fix (I'm not very good with electronics) or have a repairman come fix it?
  • 4,234 Answers
The set is detecting a problem and shutting down to prevent further damage. The standbyu light on the front should blink a repeated count with a slight pause. Post that count here as it indicates the circuit in which the problem was detected. Armed with that info, we should be able to provide you with the likely defective parts and cost to repair.
Thanks,
Dan
Posted on Sep 09, 2008
HDMI connection off and on
it`s better to bring it to nearest electronic workshop in your area,qualified technicians can solder and knows how to fix it better.
Jan 01, 2014 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Here's my suggestion , unhook all the external components to the TV and leave the TV unplugged for more than a few minutes (a day/overnight). The next day plug the TV into the wall outlet (not the powerstrip) without anything hooked up to it, and turn it on. See if it comes on. Sometimes unplugging for a few minutes/hours is not long enough for it to reset itself.
Dec 28, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
No picture, but has sound
What make and model of tv, and what do you have plugged into it normally?
Dec 09, 2013 | Sharp 27F541 TV
My sony trinitron is blinking red and won't turn on
THIS IS NORMALY CAPACITORS IN THE POWER SUPPLY THAT NEED REPLACING
Jun 25, 2013 | Sony FD Trinitron WEGA KV-34HS510 34" TV
I have the Sony XBR 40in Trinitron and it won't
sounds like you have some cold solder or bad joints,power section, inspect it ,with the back off, but be carefull.........i had one that did that...bad connection in solder joint...had to resolder,if you have to resolder,make sure it is unpluged.hope this helped....
Feb 23, 2010 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
No picture and buzzing sound on Sony XBR Wega
Is the bulb light flashing ? - Sony's bulb light is very accurate in telling you if the bulb is bad. The buzzing sound could be from the balist trying to strike the lamp. You also may want to open the lamp door and see if the bulb is shattered.
Aug 01, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
FD Triniton Wega XBR KV-30XBR910 TV WON'T TURN ON, LIGHT FLASHES 6 TIMES RIGHT NOW, SOMETIMES IF I KEEP TRYING USUALLY SEVERAL WEEKS AFTER TURNING OFF IT WILL TURN ON, BUT WILL EVENTUALLY TURN ITSELF OFF...
If you are handy with TV repair then replace IC6501 and IC8002 on D board of TV or ask local TV repair shop to replace it. Both ICs have same number MCZ3001D
Thanks.
Jul 12, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-24FS100 24" TV On/Off problems
check your lamp cover and make sure it is not loose. of so take a philips screwdriver an tighten the cover screw.
Oct 01, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron WEGA KV-36XBR800 36" TV Logo
80 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
