Monitor going out
My monitor only works for a while before going black.
  • itsgonedark Sep 09, 2008
    The backlight inverter has gone pop. Does anyone know where you can get a new board. Syncmaster 152V
  • rowkid Apr 15, 2009
     I have the same problem and would like to fix it. Seems do-able. Have you found the solution? I read that it could be capacitors. I would like to know what you did to resolve this problem. Thanks
  • 225 Answers
I got the same problem. There was two capacitors (1000uF/10V and 220uF/25V) on the power module which was dead and a blown 3A fuse. After careful check I found one of the transistors on the inverter circuit was short. There are 4 transistors each in 8 pin SD (SOP-8) packaging with marking 4600 on the 1st line and BD3Z4P on the second. After some searching in internet I realized they are ELM34600AA-S complementary MOSFETs and still can't find a delivery to my town. I believe after MOSFET replacement the monitor will go well.
The transistor was shorted between 3 and 5+6.
Here is the datasheet: http://pdf1.alldatasheet.com/datasheet-pdf/view/308736/ELM-TECH/ELM34600AA-S.html
Posted on Jan 21, 2010
Desktop computer monitor goes black but works on other computers
It sounds like the resolution is set wrong. Go to the minimum and see if that solves the problem. If so keep working up.
Nov 25, 2012 | AOC V22 22" Monitor
My sony vaio d screen sometimes go black
Sounds like the Monitor or Video Card might be going bad. Try plugging another monitor on the computer to isolate the problem. Borrow a monitor from a neighbor, friend, relative or co-worker and plug it into the computer. If the Borrowed monitor works without going black, then your original monitor is bad. If the Borrowed monitor goes black like your original monitor, then your video card is going bad.
May 15, 2012 | Sony VAIO VGC-LS30E 1.73GHz Pentium Dual...
My monitor won't stay on it will go black after a sec. If you turn it off then on the monitor will work for a second the it goes off again. I have unplugged cords and it still does it. I have a hp f2105
It is "normal" for a monitor to "go black" when it is NOT connected to a computer.
Connect it to a different computer, to see if the video-card on your computer has failed, and to see if the LCD monitor works at all.
Dec 15, 2010 | HP f2105 21" LCD Monitor
Monitor black but power light blink green
The 470uF 25 Volts capacitors on the power supply board are probably bad. Replace them all and tell us the result !
Feb 24, 2010 | Hannstar I-Inc TW-191D Monitor
Monitor receiving signal, but no image
Hello!
I see many monitor with that trouble.
When you turn on comp., you can have a picture on monitor about 10-30 min. and that go in black screen, or If you change resolution again go in black screen.
You must repair monitor or bay another.
Nov 02, 2009 | Acer AL2416W Monitor
Monitor goes black
I also have a hp w1907 monitor which also powered on for a second and then go blank with the power light still on.. it was out of warranty so I had no loss so I took it apart..I found one of the wires broken at one of the backlight bulbs { becarefull they are fragile and there is four of them, two on the top and two on the bottom... and the lcd screen is very fragile } I soldered the wire back on and it all work fine... just remember where all the screen parts go.
Oct 24, 2009 | HP w1907 LCD Monitor
Computer monitor screen stays black
please check the signal cable..... sometimes the signal cable gets faulty and it would be best if you replace it..
Jun 02, 2009 | LG Flatron L1710S 17" LCD Monitor
Monitor goes black and won't come back
Hi! Trish,
It's seems your Acer monitor backlight inverter are burnt out. Need to replaced a new inverter. Since is a company monitor asked your boss to get you a new one.;) Hehehe...
Oct 03, 2008 | Computers & Internet
Monitor black screen
Your first step in troubleshooting this problem is to plug in another monitor to your computer. If you are having the same problem it is related to your computer. If the second monitor works fine then your original monitor is shot.
May 11, 2008 | Mag Innovision LT776s 17" LCD Monitor
Monitor goes black
Sorry to have to tell you this, but this is common in LCD monitors. The reason that it is going black when it boots is for one of two reasons. You either have a bad power supply that powers your LCD or your LCD's backlight is blown. These can be repaired or you can purchase a new one. But if it goes black 9 times out of 10 is because the backlight is bad. These can be repaired!
Nov 26, 2007 | Acer AL1711 17" Flat Panel LCD Monitor
Computers & Internet Logo
937 people viewed this question
David Payne
David Payne
