Question about PC Chips Computers & Internet
Max size sata drive for pcchips a31g
Can you please tell me the max size SATA HDD i can use with a pcchips A13G motherboard using the 2 SATA ports im not sure if its v1.0 or v1.1
thanks
  • jason_UK Sep 09, 2008
    sorry i made a mistake the motherborad is a pcchips A31G when i looked on the pcchips website it says that some motherboards only accept upto 400GB on the onboard SATA ports but the A31G wasnt listed i want to put 2x 500GB SATA drives on there but i dont want to waste my money on 500s if it will only take 400s
    many thanks if you can help
    President:
  • 2,351 Answers
Hi Jason_UK, the motherboard revision does not matter in regards to the SATA size. (The board does support SATA).
2TB is a limit imposed by the MBR partition table. Assuming the disk uses 512 sectors.
If the sector size is increased to 4KB, the limit becomes 16TB. Suggest you setup your serial ATA SATA disk drives by downloading the manufactures bootable floppy disk setup software. Most SATA manufactures also provide bootable CD software if you do not have a floppy drive in your system. You will be able to change the size of the clusters allowing you to have access to the entire drive. The floppy software will also allow you to format the disk & there are other features that can be turned on or off. Neither windows nor the bios can make these changes.
Good luck Jason!
Mike
Posted on Sep 09, 2008
  • Mike Peluso
    Mike Peluso Sep 09, 2008
  • Mike Peluso
    Hi Jason, I read through the manual & I did not find any mention of limitations for the serial ATA SATA 2.0 hard disk drives on the A31G v1.0 motherboard. I did not find any reference to the A31G (No reversion number while at PCChips). Feel free to post the link from PCChips so I can read what you read. (This will be the first time I have ever heard of something like this).
    The motherboard bios, does not show the total drive’s size. Only windows will show the total drive’s size. Do not forget to set the correct SATA drive in Advanced BIOS Features, Page 22.
    Hard Disk Boot Priority.
    Think about it, why would a motherboard manufacture set a size limit on a supported SATA 2.0 port? I have come across many people who have asked a similar question. (Will windows see my total drive size)? Some times windows does not see the total drive size. These people buy from the net OEM & do not receive floppy setup software for their drive. Whether it be an IDE or SATA drive. The trick is to use the software from the manufacture for the SATA drive. If the bios see's the drive in the Standard CMOS Setup, Page 21 in manual & you will be using Windows 32 bit software OS or 64 bit. There is no reason for windows not to see the entire drive size. Windows XP home edition may need SP1 before it will see some drive’s total size. This can be adjusted through windows disk management. (diskmgmt.msc). after updating windows.
    Again, please post the link that mentions a limit of 400GB.
    Mike
Hi my friend: please help me for select HDD. 945GCM-S2L Max HDD Support? 945GCM-S2L <- this mainboard supported 2TR Byte?
This motherboard suports SATA (Serial ATA 3Gbps) meaning that it is compatible with any SATA hard drive. A 2TB (Tera Byte) hard drive is the highest capacity available on the market. This motherboard has 4 SATA connections so you can put up to 4 SATA hard drives into it.
Mar 15, 2011 | Gigabyte GA-945GCM-s2C socket LGA775...
Can i use a sata hard drive with my ga 7vklm mobo
The Gigabyte GA-7VKMP motherboard does not support serial ATA SATA drives. Open the link provided; http://tw2005.giga-byte.com/Motherboard/Products/Products_GA-7VKMP.htm
2 x ATA 66/100/133 bus master IDE ports
1 x FDD, 2 x HDD and 1 x CD audio input
IrDA(1x5) and COM2 on board
GBT standard front panel
2 x USB2.0 connectors (support 4 ports by cable)
You can connect the adapter below to an opened IDE port and connect a SATA 1.5 drive to your system.
http://www.satagear.com/SATA-MM-A1_SATA_Adapter.html
This should allow you're SATA drive to transfer data faster than the 133MHz standard IDE speed.
Cheers'
Mike
Aug 10, 2010 | Gigabyte GA-7VKMP Motherboard
MSI RC410 - cannot detect Sata HDD
i think the problem is with ur SATA HDD. To confirm, try another SATA HDD on ur mother board and see if the problem persists
Sep 20, 2009 | ASUS P5RD1-VM Motherboard
Mother board cant detect my Sata HDD, please advise me urgenly...
I will advice you to exchange the HDD with someone or with brand new one as it seems to be problem with drivers of the sata.
Sep 20, 2009 | MSI RC410M-L Motherboard
SATA 2 HDD
I think, one possible way is to manually force sata 2 (there is no such thing as sata 2) to sata 1 by using a jumper for the hard drive. For exact details, please consult the sticker on the hdd or contact the hdd manufacturer for firmware updates. And please report back, especially if it's a success. (Damn, the VT8237)
Jun 05, 2009 | MSI K8MM-V (MS7142-010) Socket 754 Micro...
2 Sata Hdd not supported
Hi rafiqbrush, let me go over a few things for the P5B MB.
There is a total of 5 serial ATA SATA drive ports on the board & one ATA IDE/PATA port.
The 4 main SATA ports are numbered, 1 - 4. Your primary SATA drive must be connected to SATA port 1. Your second SATA drive must be connected to SATA port 3. See page 2-26 in your manual.
All SATA drives are seen as master drives. Once the two SATA drives are connected (As per manual), boot to the bios main menu.
At the main bios menu make sure your bios shows both SATA drives. Than go to the bios title "Boot". Make sure your primary SATA drive 1 is listed in the boot order. Save & exit the bios. (SATA drive 1 must have windows installed on it).
Link to Asus P5B web site;
http://support.asus.com/download/download.aspx?modelname=P5B&SLanguage=en-us
Good luck rafiqbrush!
Thank you for using fixya.
Mike
Dec 10, 2008 | ASUS P5RD1-VM Motherboard
K8V-MX motherboard+HDD size limit
yes the mother board supports SATA However if you connect large Disks to the SATA connectors they are recognized correctly with full size. So leave your 500g and less HDs on the IDE and the big ones on the SATA. you can check this link for the manual for more information ftp://ftp.chiligreen.com/Desktop/Manuals/manual_a_k8v-mx.pdf hope this helps .thanks and Godbless pls appreciate by rating as fixyaa
Oct 03, 2008 | ASUS K8V-MX Motherboard
Computers & Internet Logo
609 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
