Question about GE JGRP17 Gas Single Oven
GE Glowbar You had helped another person replace a Glowbar in a oven that the pilot light would not light. How can I tell that is the Glowbar and not the saftey shutoff valve or the front knob on the main panel? Thank you delsol_driver@yahoo.com
  • 5,911 Answers
The following link explains how to replace a glowbar and how to measure them:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
The first thing you need to do is determine which type of glowbar igniter you have. The current tolerances are different on each one. If you take a current reading and it is not within the prescribed range, replace the igniter (even if it is glowing). The easiest and preferred method measurement is to use an amprobe type multimeter and clip it to a single wire from the igniter.
Most commonly, the igniter, rather than a gas valve, goes bad after periods of use. In particular, the bake igniter because it gets used more often. In addition, your range should have a separate igniter for the broil manifold as well. Since most home owner's do not own an amprobe meter, you can swap broil and bake igniters to see if the symptoms change. If the symptom moves to the broil manifold, then you know you have a bad igniter. If the symptoms stay the same and then you need to consider the option that you may have a gas safety valve issue. Let me know what you find. I hope you find this information helpful.
PS I'm only assuming this is a bake manifold problem, as you did not say which one you were having problems with. This is the more common failed component, however, because it gets used more frequently.
Posted on Sep 09, 2008
My oven isnt getting any gas?
All gas ovens have safety features to prevent raw gas from escaping into the home. On older models the pilot light sometimes lows out and the oven thermocoupler cools down. this closes the gas safety valve. On newer stove they have a glowbar that opens the gas valve when it gets glowing wide open.
If ya see a glowbar type and it is dim orange, it is worn out and in need of replacement. Post yer model number for a more precise answer.
Aug 23, 2011 | Whirlpool Ovens
GLow tubes lights up on the oven but the oven will not heat (no gas)] Range model XL44
You have power to the circuit so the control and valve are ok. That leaves the glowbar. It has to pull a certain amount of amps to open the valve. Sometimes bumping the stove makes it light up . The glowbar should be so bright you cannot look at it but sometimes you cannot tell a bad one from a good one...
XL-44
Aug 07, 2011 | Ovens
The broiler and the burners all light but the oven doesn't.
If the glowbar is light up then you have a circuit and all components are working. So Houston why don't we have ignition? Today's new fangled ovens use silicone carbide ignition. The oven safety valve has a bi-metal inside it. In order for it to open and allow gas to flow the resistance in the circuit must change. As that glowbar heats up it changes the resistance in the circuit. If it can pull 3.5 amps or better then that bi-metal will open allow gas to hit the burner. That is yall's built in safety feature. If a glowbar looks real dim and takes a while to come on if at all then it is weak. Whirlpool also has another type of oven that uses a safety valve with a thermocouple attached to it. A pilot light is on all the time on these and no power is needed to operate this stove. Over time the thermocouples cooper-nickel tip will wear out and won't hold the oven safety valve open. Other variations of this is a standby pilot and electronic spark pilot and a flame switch added onto a safety valve. Newer models use a computer board along with AC power to fire the igniters and DC power to open the distribution valve. Your broiler is working so I am sure your stove ain't got the DSI ignition system and you have not mentioned anything about a pilot light so I am assuming you simply have a weak glowbar.
Video:
More here
Oven codes and other stuff HERE
Feb 02, 2011 | Whirlpool Ovens
Does the lyric 50 gx oparkinson cowan cycloneheat gas oven have an automatic flame safety device that shuts off the gas if it is not ignited?
Most gas ovens using glowbar technology have a failsafe to not allow gas flow without glowbar pilot ignition.
If you are asking this question it is most likely that your glowbar needs replacement. This is fairly easy to do yourself. I recommend researching your glowbar part thoroughly and purchasing the part off ebay. It will save you a bunch. I did this a month ago.
Funny thing is when I called my local parts guy he told me that 6 glowbars for my model were sold that day, but very few prior, and he was out of them. Looks to me like the oven manufacturers are working with planned obsolescence to get you to buy a new oven every 10 years if you are not savvy enough to fix yours.
This coensides with the building boom 10 years ago in my area. Coincidence? Not likely.
Feb 01, 2011 | Ovens
Oven pilot went out due to power outage. I don't know where the pilot oven light is. where is the pilot light to light the oven?Ge XL44
pilot over lights do not require power to stay light or should it go out in a power outage! do you have to normally light pilot with a match? if not you have a glow coil and its a electronic ignition range and power will affect it. once power is restored you should just be able to turn on over and everything would be ok.if it is a pilot light you need to remove the bottom door stick arm in to back and you'll see the pilot assembly at back if you look up! hopethis helps...
Feb 06, 2010 | GE Ovens
SF 3000 EWWO how to light pilot
You can raise the top lid of the stove to light the pilot lights for the top burners.
The oven is controlled by a electric glowbar ignitor.
Make sure the cord is plugged into a electrical outlet.
If it is and the oven does not work the glowbar ignitor must be replaced.
Jan 16, 2010 | Ovens
Hello when i put my temp for my gas stove on say 350, the pilot is glowing but it doesnt seem to flame/heat up, and i get a somewhat odor of gas, could the therometer need replacing or maybe the ignition...
Your glowbar ignitor part must be replaced, Unplug the range and turn off the gas. Remove yje oven racks, The oven base pan. Then remove the flame spreader. You will see the glowbar ignitor attached to the side of the bake burner. Remove it and replace it with a new ignitor. Replace all the range parts.Turn on the power and turn on the gas supply.
Copy and paste this site for the location of the ignitor you can also purchase the part from them.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=111359&diagram_id=362260#d362260
Jan 01, 2010 | Frigidaire FGB24T3A Gas Single Oven
The oven burner will not ignite.
Because the glowbar is glowing does not necessarily make it good.
Turn off the gas to the stove. Remove the oven racks. Remove the bottom oven pan. Remove the flame spreader. This gives you access to the glow bar and gas valve.
Put a clamp on amp meter around one wire of the glowbar. Turn the oven control on to BAKE.
If the glowbar reads 3 amps or less,replace the glowbar ignitor.
If the glowbar reads good,check the burner tube for a white ash buildup. It can be cleaned with a wire brush. Look closely near the glowbar section of the burner.
Check all the wire connections for the gas valve.
If the glowbar is good and the ash deposits are gone and the oven still will not ignite,the next step is to replace the gas safety valve.
Dec 01, 2009 | Amana Ovens
How do I light the oven on a gas stove
If this is a newer stove (that does not have a pilot light...and most newer stoves don't), you shouldn't have to light the oven manually (if you think you need to, you have a faulty stove). Manual ignition of a stove is also potentially dangerous as larger amounts of gas in the oven can cause small explosions. Most modern gas stoves use a very hot glowbar to both regulate the amount of gas entering the oven and igniting that gas. If you have a faulty glowbar, it will not allow enough gas to enter the oven and may not be hot enough to ignite the little gas that does enter (that is why you may smell gas). It sound like you may need to replace the glowbar (or visually inspect the glowbar to see if it gets red hot. If it does, it may still be faulty (not drawing enough power). The only way to test this is to use a clamp-on ampmeter and test the current flow through the wires feeding the glowbar. They should read between 3.1 and 3.7 amps. Anything lower means the glowbar should be replace. If you cannot see the glowbar get red hot, you have an electrical problem or a circuit board problem.
Jul 11, 2009 | Maytag CWG3600A Gas Single Oven
Lighting pilot of GE gas stove
According to the model number you supplied it looks like your oven use a glow bar ignitor not a pilot light. In that case there is no place to hold a fire. what happens with these when you turn the oven on 120 volts goes to the ignitor causing it to heat up ,the amp draw across the ignitor causes the gas safety valve to open, and then lights the gas. So if you turn your oven on you should see a bright red glow if not probably the the ignitor, to check it you would have to verify you actually have power going to it. If the ignitor glows but the gas valve does not open you will still need to replace the ignitor has to pull about 3.2 amps across ignitor to open safety valve. Your broil burner works the same way. And most of the ovens the floor of the oven comes out to allow easier acess to the ignitor. also if you have to change the ignitor put just a dab of dish detergent on the screws to help from stripping them
Nov 27, 2007 | GE JGRP17 Gas Single Oven
GE JGRP17 Gas Single Oven Logo
535 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
