Question about Toshiba 42HP95 Television
Blinking RED power Light 42hp95 Toshiba
Has a solution been made for thr red blinking light for the toshiba 42hp95
Thanks
  • yaddowA Nov 12, 2008
    Same problem it don't turn on, just blinks red
  • Anonymous Dec 02, 2008
    I also have the same problem. Blinking red light and will not boot up.
    Problem Solver:
  • 5 Answers
I turned the 42HP95 TV off one night and it didn't come back on. Had the red LED flashing etc. Found the solution posted by CheapTech: http://www.fixya.com/support/t101749-tv_turned_itself_off_turn_back but didn't take it seriously because these things never work, others were mocking the answer blah blah. Well, just before kicking the damn thing to the curb, I grabbed a screwdriver, took off the back cover, unplugged the little do-hicky sugested in the Solution, and the idiot box came right back on. Go figure. Been working ever since. SO, you might want to try this before busting out the electrical schematics and dropping $$ on repair. Cheers.
Posted on Feb 20, 2009
I have done some research because I have the same problem and this is what I have found. Hope this helps.
These sets are assembled using the wave soldering process they are known for having cold solder connections. The safety circuitry shuts the TV set down or will keep it from turning on when it detects a problem. This is why the power light blinks. This model of TV has over 2,000 parts which includes millions of transistors inside the integrated circuits. The capacitors will change value, leak and become defective. Resistors will change value and burn. Diodes and IC can go bad. This may have a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again if the parts that caused the failure to begin with are not replaced. The only way to know for sure which parts that are no longer within factory specs and for a proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment specifically designed for TV service and the skills to use the test equipment. I wish I could tell you there was a quick fix or button to push that would fix the TV but that is not the case or the solution needed to get the TV operating correctly.
I will expect the repair will be $250 to $350. A small TV shop will often charge less than a large repair facility. I believe the TV will be worth having repaired even though a LCD TV will cost less to operate.
Posted on Oct 19, 2008
    Habit-Forming:
  • 146 Answers
Thank you Fixya this solution worked in my tv shop on this model tv. I removed the cover and disconnected the four line cable connected to the cable card module. The 15 volt source I had been missing is now restored. FYI Time warner has issued a statement from August 2009 that their system will not work properly any longer using the Scientific Atlanta Cable Card.. Putiing the module out of it's misery is much cheaper than replaceing the piece and all the other inputs including antenna in still function
Posted on Mar 05, 2010
    Scholar:
  • 65 Answers
Hi to all im a technician since 1990 and i come across many LCD and Plasma T.V's I have a Main Power Board off a Toshiba 42hp95 Pulled from a working TV $75 the customer brought in to replace the screen but it was,nt worth it to them so the set was left to us and now we are selling the parts all tested and in working conditions.
Anyone that may need this board please email me at computertech1990@gmail.com or call me 646-737-6425 Need to see Pics call me or email me for your request
Posted on Feb 23, 2010
The power supply is toast. You have to replace it. Parts and labor range from $500.00 to $600.00 + buy a surge protector = buy a new TV. Sorry, it happened to me.
Posted on Dec 19, 2008
Well This is what I did , Got electrical print outs.
checked volts, Missing 15 volts off of the power supply?
Solution may not be for everyone! But, IT worked for me.
Get a car battery 12V Neg to ground and Positive to one of the 15V outlets!!!
WaLAAA the IC is back BABY!!!! It works AGAIN, without leaving the battery plugged in!!!!
Must have needed a JUMP!!! It worked for me But BE VERY CAREFUL!! Lots of VOLTS!!!!
Posted on Oct 20, 2008
Will not start. screen black as the red light continues to blink. must be unplugged to get the blinking red light to stop. alive but dead.
The reason your television does not come on and you only have blinking red light is because there is a problem inside the unit.
The problem mainly is either from the main panel or the power panel of the television. There is a burnt capacitor on the main panel or the power panel that is why it is not powering up.
Unplug the television for a while, about an hour or two, so the high voltage on it will dissipate, then you unscrew the screws at the back. You will have access to the main panel and the power panel, assess it and you will find a burnt capacitor, have it replaced by turning the panel to the other side and melting it off with a soldering iron and replacing it with a new one. Then couple the television back together.
Take care
Oct 14, 2010 | Toshiba 42HP95 Television
42hp95 won't power up it clicks twice but red light just keeps blinking
This Toshiba unit must have been a "lemon", as the power unit was replaced about a year ago. It is only 3+ years old & we paid $1600+ for it in 3/96. Too bad. I'll never buy another Toshibaproduct.
Oct 22, 2009 | Televison & Video
TOSHIBA MODEL #42HP95-BLINKING RED POWER LIGHT WONT STOP
Ur power inverter board is dead.
U need a new board.
Sep 07, 2009 | Toshiba 42HP95 Television
Toshiba 42HP95 TV turned itself off, red light blinking
has overheating issue try vacuming out the top and rear of tv. fan could be dead
Jun 02, 2009 | Toshiba 42HP95 Television
Toshiba 42HP95 Plasma tv
Worked for me, was ez, and I am a huge skeptic and not very "TV technical."
Dec 23, 2008 | Toshiba 42HP95 Television
Toshiba dlp 46 inch red light keeps blinking
42 inch Toshiba DLP. Was watching a movie and the screen went dark. The red light started to flash and kept flashing. any ideas
Jun 26, 2008 | Toshiba 46H84 46" Rear Projection...
Televison & Video Logo
3,443 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
