Question about Canon PowerShot A530 Digital Camera
CANON POWERSHOT A530 LOW BATTERY READING
I have recently bought a Canon A530 and it keeps on blinking red Low Battery signal after less than 10 photos, even with brand new rechargeable 2500 NiMH batteries. My serial number starts with "27". Can you help me.
Thanks
Alicia
  • Anonymous Sep 29, 2008
    my a530 also flashes low battery after about 15 pictures and I am always exchanging the batteries. my camera is about 1yr old and serial number starts with 29
  • t_ran Apr 26, 2009
    t00nz: Original Alicias quostion is about camera with serial begins "27" Look the quote from canons page you linked
    "Affected Cameras
    PowerShot A530, PowerShot A540 Digital Cameras
    Please check the first two numbers from the left in the serial number listed on the bottom of the camera.
    The serial number: Cameras with "21", "22", "23", "24", as the first two numbers from the left.
    I have same problem and my serial begins "25"
  • Canon Master
  • 4,738 Answers
Alicia,
Mentioned on my blog that the last paragraph of the advisory states:
""PowerShot A530 and A540 digital cameras affected by this phenomenon will be repaired free of charge, regardless of warranty status. Accordingly, if the opening/closing spring on the inside of the battery cover of your PowerShot A530 or A540 digital camera sticks out, please do not use the camera. Instead, please contact a Canon call center (1-800-OK-CANON) at your earliest convenience."
But also mentioned that if they don't help, a temporary fix is to insulate the spring from the battery contact plate. Merely place a small piece of tape between the portion of spring that's sticking out and the metal battery contact plate.
Posted on Sep 09, 2008
We had the same problem and it was so very frustrating. We sent the Camera back for assesment and repair only to be told there was nothing wrong with it. The solution was so simple we felt like real dummies.
All you have to do is use Energizer Lithium Batteries, since we started using them we have not had a problem with Batteries going flat or that annoying Battery indicator flashing.
Regards
John
Posted on Oct 15, 2008
I have a Canon PowerShot A530 camera which is around 4 years old. till recently it was working great but from last 3 months, it is giving false indication of low batteries and shuts down. Even after full...
if you are using this camera for 4 yrs with the same lithium battery then you might need to try a new battery
any lithium battery cell's capacity diminishes after long use. it reduces the cell's ability to deliver current. the older batteries do not charge as much as new one.
when you charge your battery it irreversibly loses approximately 20% capacity per year.
hope this help
Sep 08, 2010 | Cameras
I bought the best rechargable batteries and it still has low batt
Some of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mention that your batteries aren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info:
Apr 25, 2010 | Canon PowerShot A530 Digital Camera
Low battery warning
What type of batteries did you buy?
For digital cameras, you want to use batteries with high milliamp hour (mah) rating: "2500 mah" if they are rechargeable.
If you bought regular batteries, you want to use good quality. Look for the "e2" or "better for digital equipment" type.
Does the camera have a DC power plug option? Try taking pictures with it plugged in if it does. If it still malfunctions with power right from the wall, then you bought a bad camera.
May 10, 2008 | Canon EOS Rebel T2 with 28-90 lens 35mm...
Battery low light
Some of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mention that your batteries aren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
http://camerarepair.blogspot.com/2007/12/canon-a530-a540-with-short-battery-life.html
Jan 27, 2008 | Canon PowerShot A540 Digital Camera
Change Battery
Finally, make sure you're using rechargeable NiMH batteries rated 2500 mah or better. Digital cameras just use too much power for standard alkaline batteries.
Jan 18, 2008 | Canon PowerShot A530 Digital Camera
Short battery life
Dec 31, 2007 | Canon PowerShot A530 Digital Camera
Canon
You need to power it with rechargable batteries. with the MAH being no less than 2000. I bought a charger which came with 2batteries for less than a tenner
Dec 23, 2007 | Cameras
Camera Powershot A530 won't flash
EZ Fix for non working flash on Canon A530:
Remove batteries
Remove memory card
Remove date/time battery (tiny door next to battery hole)
Wait a minute.
Replace the items
Rest the date/time
Shoot!
Dec 12, 2007 | Canon PowerShot A530 Digital Camera
Canon a530 powershot won't snap a picture
sounds like the flash isn't charging, as the flash icon flashes while the flash is charging before letting you take the photo. Put it in "P" and disable the flash and see if it'll let you take a photo. G>
Sep 03, 2007 | Canon PowerShot A530 Digital Camera
Canon PowerShot A530 Digital Camera Logo
1,051 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
