Question about Proview PL576Ws 15.4" Widescreen LCD Display
Unclear picture in the last couple of days, colors got crazy on the screen, it looks like some kind of a drift of blue and green, and the whole thing looks like colorful fog, which is nice and all, but makes it impossible to work on.
    Scholar:
  • 124 Answers
1. try using "degauss" on the screen menu. 2. move away all other electronic devices from the screen. 3. if this doesnt help, you can try the following, but only if you know your way in electronics, and have experiance with welding, otherwise, this is very risky: unplug screen from all cables for a couple of days, then open it and check all weldings, if there are cracked ones, reweld them. again, do it only if you know your way around this, otherwize you will ruin the screen, and worse.
Posted on Feb 22, 2006
SOURCE:
Screen is going crazy
Okay, it could be two things, 1.) Your graphics card is either overheated or going out. 2.) it's possible you have a messed up display screen. I'd try looking at your computer display settings and see if you can calibrate the color on your screen to see if it helps or not.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/erik_3934b541f17c4e99
Jun 05, 2012 | ASUS K52F Notebook
My Coby LEDTV 1926 blinks red, green, blue, white, and black. Is there anyway to fix this?
Sorry I can't help, but mine does the same thing sometimes. It'll work fine for awhile, then no picture, but goes crazy and flashes one color at a time across the whole display, very brightly. I have it connected to RCA inputs, so I don't know if it would happen using the antenna input, but based on your experience, I suspect it would. I never got around to calling tech support, and my return period ends in two days, so it's going back to the store tomorrow.
Oct 30, 2011 | Coby Televison & Video
My picture is messed up. Its kind of unclear with
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 04, 2010 | Hitachi 50GX30B 50". Rear Projection...
I own a KP-57HW40 set that has a color and shut off issue. Started as a green tinge problem to the screen after watching for a few hours. Started becoming more and more frequent a couple months ago....
IF YOU HAVE A RA 6 CHASSI THE TUBES RUN HOT ANOID CATHOD SHORT IF YOU TAP ON THE NECK OF THE TUBES AND GOES TO SOLID COLOR THEN SHUTS OFF YOU HAVE TO REPLACE THAT TUBE ALL 3 TUBES WILL HAVE THIS PROBLEM
Feb 09, 2010 | Sony KP-57HW40 57" Rear Projection...
Reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
Dec 21, 2008 | LG Studioworks 700S 17" CRT Monitor
Blue color is now green and oranges are pink
Most likely a CRT coolant leak onto signal pcb.Look for wet
evidence........T.
Oct 25, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Problem in Screen display
Hi, J ! You didn't say how old you set is, but to me it sounds like you may have a warped shadow mask in you picture tube. A shadow mask could be compared to a piece of screen wire. It's function is to make the electron "beams" from the three electron guns strike the proper phosphor dot to produce the proper color- red-green-or blue. If this is the case the picture tube would requie replacement. Stargazer
Jan 09, 2007 | Sony KV-21CT1 21" TV
Proview PL576Ws 15.4" Widescreen LCD Display Logo
47 people viewed this question
Top Proview Computers & Internet Experts
 Mike M
Mike M
Siul Oyaratgam
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
