Printer i850 flashing orange light 7 times indicates printer head needing to be removed and checked for dirt, how do I remove it?
  • cktamblyn Sep 09, 2008
    thanks!
  • Anonymous Sep 12, 2008
    my printer wont print and flashes orange light 7 times... this happened after i changed the catridge of black ink
  • 550 Answers
Http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=232&modelid=8047
type in
'reseat / remove the print head i550 / i560 / i850'
, in the search box for a detailed step by step video and text
Posted on Sep 09, 2008
I have a Cannon i560 printer and the light on printer flashes five times orange then flashes green, what is the problem and how can I fix it.
5 flashes indicates a faulty printhead or possibly a problem with the p/head contacts. Try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt.
If that doesn't work it may be that the waste ink tank is full. Try this ...
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
May 18, 2011 | Canon BubbleJet i560 InkJet Printer
When i switch on the canon ip4300 printer orange light flashing 5 times
1. Turn off printer
Feb 28, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Reset. Orange light blinks several times. Then Green. Then orange several times, then... on and on. Cannot reset. All ink cartridges have ink.
count the number of orange flashes in between the green light. two flashes = out of paper, 3=paper jam, 4=empty ink tank, 6=print head not installed, 7=print head defective, 8=waste ink tank is almost full
Jun 08, 2010 | Canon i850 InkJet Photo Printer
Canon i850 light is green then flashes orange 7 times then goes green and repeats orange flashing. Printer never gets ready
This is a very bad error. It means that the printhead needs servicing and may need to be repaired. There is no easy fix. Sorry.
Jan 21, 2010 | Canon i850 InkJet Photo Printer
I have a Canon Bubble Jet i850. It is approximately 7 years old with no problems until now. I am getting 7 orange flashes, which according to the manual indicates possible defective printer head. I removed...
The problem does indeed seem to be a print head fault. Remove it and take it to your local printer re-inking firm. Get them to do a thorough clean of the print head (they have the equipment that us mere mortals don't) and test it (should cost you nothing or very little). If it works, great! If not then get a new printer. The cost of replacing the print head would be the same or more than replacing the entire unit.
Sep 14, 2009 | Canon Office Equipment & Supplies
Do I need a new print head?
1. Turn off printer
Sep 13, 2009 | Canon BubbleJet i560 InkJet Printer
Blank pages coming out of i850 with new printhead
Alarm / Power light flashes orange 7 times consecutively is a Print head error so it sounds like you did the right thing.
I would reseat the printhead along with each one of the ink cartridges. Make sure that you removed the tape from the bottom of each of the ink cartridges and try it again. After installing the new printhead, you should have run a printhead cleaning cycle immediately after installing.
Issue: Certain colors are missing or no ink prints on the paper
Solution: Install / replace the recommended ink tanks correctly i550 / i850
Untitled Document How to install / replace the ink tanks
The ink tanks suitable for the printer are as follows;
Black Ink Tank BCI-3eBK
Cyan Ink Tank BCI-3eC
Magenta Ink Tank BCI-3eM
Yellow Ink Tank BCI-3eY
Note: There are two ink tank label designs.
Operation procedures are shown with label design A.
labelsa.jpg Replacement Procedure
1. Check that the printer is powered on, and open the front cover. Wait until the print head moves to the center.
2. Remove the empty ink tank by pushing the tab on the ink tank.
Note: When doing this, do not remove the print head. When replacing multiple ink tanks, it is recommended to replace one at a time to avoid inserting them into the wrong slots.
(The image is an example using i850.)
3. Remove the new ink tank from its package. Pull the orange tape in the direction of the arrow to remove it completely, and remove the shrink-wrap film.
Note: Remove the orange tape completely. If the tape remains, printing may not be performed properly.
Confirm that the orange tape is completely removed from the ink tank, as shown in image 1. If the tape is similar to the sample in image 2, remove the remaining portion of the tape so that it looks like the sample shown in image 1.
(1): Correct
(2): Incorrect (where the arrow indicates)
4. Slowly twist the orange protective cap in the direction that the arrow indicates, and remove it. To avoid ink adhering to your fingers, brace the orange protective cap while removing it.
5. Insert the new ink tank to the print head by holding it at a slight angle.
Note: Confirm that the ink tanks are installed in the right order according to the labels on the print head.
6. Press down on the top of the ink tank until a click sound is made.
7. Close the front cover. The next time the printer performs printing, it will automatically start print head cleaning. The power lamp will flash while cleaning is performed. Until cleaning completes, do not perform other operations.
May 07, 2008 | Canon i850 InkJet Photo Printer
Will not print
Remove and re-seat the print head. If need be the print head can be cleaned with hot water. YMMV but I've submerged my i850 print head for minutes at a time. Dry it off, blow it out, and it goes right back to work. Common problem if you're using non-Canon inks.
Nov 07, 2007 | Canon i850 InkJet Photo Printer
149 people viewed this question
k24674
jasbo
jasbo
