Question about Xerox WorkCentre PE16 All-In-One Laser Printer
Inner fan is it normal that the inner fan is working non-stop all the time?
  • 55 Answers
The PE16 has this specific problem, set up the power-save to on and to the lowest period
Posted on Oct 26, 2007
    Scholar:
  • 124 Answers
Inner fan is working all the time in order to cool off the electronic units, but you may wanna try checking for overheating. this can resault of: - air hole too close to the wall, or jammed by something. - working enviroment is too hot. room temperature and so. - dust and dirt accumulated on the fan, or heatsinc. you can clean it with a vacum cleaner or compressed air.
Posted on Feb 22, 2006
2007 VW Jetta, A/C fan under the hood running non stop
hav air system checked--compressor cud be failn or fan motor bearings wearing out--make sure u hav enuf freon in the unit
Jul 02, 2013 | Cars & Trucks
Beko fan noisey
It can be worn out or dusty fan motor, or its time to replace fan motor.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
2000 durango cooling system fan running non-stop
Many engine control system faults can cause the radiator cooling fan to come on and run non-stop. Also, if your A/C is on or if you have your heating and cooling controls in DEFROST mode, this can cause the radiator cooling fan to come on (normal operation). Or there could be a cooling fan circuit malfunction (like a stuck relay) causing this to happen.
Check to see what mode your climate controls are in. If the climate controls are not in A/C or DEFROST modes, then you should have your engine control system properly diagnosed to determine the cause of the radiator fan being on continuously.
Also, if the Check Engine light is on, this is a clue that the engine control system is malfunctioning.
Nov 24, 2011 | 2000 Dodge Durango
License plate light not working.
check your light fitting units the normally corrode also the wires some times snap on the of side rear inner-wing normally due to a slight bump they break the wires check wires from both side and if one side dosn,t have power just run feeds from that to your non working lights but becarefull for any shorting from the wires when you connect you new wiring
Oct 20, 2009 | 1998 Lexus ES 300
My 1998 buick regal non turbo 3800 radiator cooling fans will not work when the car gets to operating temp. The fan motors will work whtn the AC is on. I think it could be the temp sensor that turns on the...
the electric cooling fan for the radiator will not turn on when the engine reaches normal operating temp, its only supposed to come on if the engine temp goes over the normal temp. (around 220 degrees)
it is normal for the fan to come on any time the a/c or defroster is turned on.
Oct 12, 2009 | 1998 Buick Regal
98 Civic with non-functioning cooling fan
bad thermostat or worse a plugged heater core or bad summer/winter diverter valve. look for bad thermostat.
Dec 08, 2008 | 1998 Honda Civic
Fan
Mine started do this recently as well. I think my belts need replacing. I believe this is what needs to be changed in order for the fan to stop over working.
Aug 12, 2008 | 2003 Mitsubishi Lancer
Fan stopped
If the fan has stopped, then the processor will overheat. Most vendors have protection so that a non-working fan is detected and the unit will not power up with detecting its rotation. Seems like a repair shop job I'm afraid.
Nov 25, 2007 | Toshiba Satellite A135-S2276 Notebook
Oven switches 'itself' off without the timer
I sorted it it is a simple solution, if you take the top of your oven you should see the problem...it will be big and black..dont spend a ortune getting it sorted i brought the part off ebay for less than a fiver.. just cant remember what it was called..very simple to fix though.  Mike
Dec 19, 2006 | Electrolux EOB6632 Electric Single Oven
Xerox WorkCentre PE16 All-In-One Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
quennie732
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
