Question about Kitchen Ranges
Hi, I have a Baumatic oven which has a broken back element. The rest of the oven works fine but i was wondering where I could get a new element for it? The grill still works it is just the element set in the back by the fan. Any suggestions? I live in Auckland, New Zealand
  • angfrench Sep 09, 2008
    Stove would be about 5 year old, but don't have model number on me!!
    President:
  • 1,462 Answers
Your best bet is to take element out and take it to a domestic appliance spares stockist. many of these elements are standard across several makes or can be adapted
Posted on Sep 09, 2008
Why has baumatic B501SS oven covered in light gray coating inside when heated, now not working
It sound like the heating element burned out. Check the element and see if there is a burned spot or blister somewhere along the element. If so the element will need replacing.
May 03, 2014 | Baumatic B180 Electric Single Oven
Floor element not working have got new element need instructions on fitting
Hi
Please check this video for element replacement:
Hope this helps...please post back for further assistance.
Daniel
Mar 06, 2011 | Baumatic B205SS Stainless Steel Electric...
I have a baumatic cooker gas hob with an electric double oven model bt2730ss and i'd like to know how to remove the fan element? I took the plate off and undid the nut that holds the element in. Could...
hi if u have taken out the two screws then the element should be just sat there. make sure its turnt off at mains b4 going any further..... now pull element towards you slowly u should see the wires take one off at a time and swap over to new element ... when done put back together ... if u loose a wire down back just pull oven out and take back cover off to get access...
Feb 27, 2011 | Baumatic Ovens
Hi, I only just installed Baumatic single built in fan oven (B0616SS). I did as instructed and left on for 39 - 40 minutes at max 250 temp. I noticed that the oven door was very hot to touch, too hot! This...
Hello- This is a brand new model, but it works the same as the rest. Heat is produced by the elements. The fan has an element that glows when heating the air. --Convection oven glass gets hotter than normal fanless models.-- This is all normal operation of the oven.  To ensure full life of oven, avoid using the 'self-clean' feature. Techs call this the 'self-destruct' cycle. Please reply to this post if info is helpful- have more if needed- Thanks- Ed
Mar 19, 2010 | Baumatic B604SS Stainless Steel Gas Single...
Baumatic oven not heating up. Grill and fan fine.
if it is the b180, the answer (having just fixed this) is really simple.
The coily bit is the oven element - it will have gone. A new one from eBay cost me about 6 quid.
[WHEN IT ARRIVES !]
Turn the power off.
Inside the oven use a philips screwdriver to remove the 4 screws (KEEP THEM !)
You will see a coily thing and a fan.
You unscrew 3 more screws (2 on the left and 1 on the right).
(KEEP THESE TOO!)
now ... bit tricky, have the new one inside the oven and take each wire off one at a time and put it on the new element.
Screw it back on but DONT put the last panel back in.
Turn the oven on maximum for about 2 minutes and see it glow red.
Turn the oven off. Make a cup of tea and have a couple of biscuits while admiring how good you are and waiting for the element to cool down!!!
Put the final panel back in place. Whole thing (including a cup of tea) takes about half an hour.
Jan 27, 2010 | Baumatic B180 Electric Single Oven
Oven does not heat up in fan oven mode but fan runs. works fine in convection mode. Baumatic B723SS-A
whilst the fan is running the heating element which is usually in parallel with it should heat.. This usually means a faulty element..
Dec 17, 2009 | Baumatic Ovens
I have a baumatic bc3510ss double oven. everything works fine except the large oven. you can turn on the grill or oven but when you turn on the temperature the rcb blows on the fuse box.
Tthere are a couple of possibilities for your prob, the thermostat, or the oven element is faulty.
Disconnect the oven element, and try it again, if it does not trip, replace the element, if it still trips, replace the stat.
Please rate my solution.
Thanks.
Nov 01, 2009 | Baumatic Ovens
Baumatic fan assisted oven not heating up
The oven element has failed, you need to fit a new element.
It is a straight forward repair to do.
Remove inner rear panel of oven, you will see the round element at rear.
Unfasten element, detach wires, and fit new element.
Refit rear panel, and test.
Plz rate my solution.
Thanks.
Jan 24, 2009 | Baumatic B180 Electric Single Oven
Fan Oven blows Fuse over 175 Celcius -Baumatic BT2760SS
Hi, I was cooking and my oven jut went off, looked in fuse mains box and had tripped. So put back on and now the fan works but no heat...Can you give me some idea what it mite be.
Sep 18, 2007 | Ovens
No heat in oven
the element may be open circuit, test it by a continuity test. the actual element is inside the metal outer surrounded by a ceramic compound -you will not be able to see any breaks hence the electrical test.
Jun 05, 2007 | Baumatic B180SS And B60SS (Bundle)...
Kitchen Ranges Logo
65 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
