Question about Maytag 24 in. MDB8600AW Jetclean II Built-in Dishwasher
Kenmore portable dishwasher making loud grinding noise
I bought a Kenmore portable dishwasher used. I have no idea how old it is or where to find the model number on it. It recently started making a loud grinding noise after the top wash arm fell off during a cycle. We reattatched the arm and cleaned out the filter. We tried getting to the pump to check and see if anything is caught in it but we can't figure out how to get to it and what it looks like. The motor appears to be working properly, it spins easily by hand. Other than the noise it seems to be working right. What do you think the problem is, can we fix it ourselves, and how much will it cost if we have to replace anything?
  • Anonymous Jan 08, 2009
    I also have a portable kenmore that is making the same noise. It will let the water in and pump it out, but does not pump the water to wash.
SOURCE: Diswasher motor making noise during wash cycle
It could be the impeller on the motor. The impeller fits over the shaft of the motor and might have split/broken up. That funny noise is probably the shaft spinning inside the damage impeller. Fortunately the impeler is fairly inexpensive and easy to replace. I believe there are one or two parts/covers to remove that are held in by a roughly half dozen torx screws.
Posted on Jan 10, 2008
SOURCE: MDC4650AWW Portable Dishwasher
We've had a similar problem. A banshee screaming noise that's makes the skin crawl. Since our machine is well out of warranty I took the insides apart and found only a few cherry pits. (Lesson learned, always scrape your dishes before loading.) We covered out ears for a few minutes and the bad, bad noise went away. But the noise came back, it didn't stay away.. So here's what I found with more tinkering.
1. Problem: Small hard things can get lodged in the food mill/grinder assembly at the bottom of the dishwasher tub. It's there to cut up the big chus of organic matter I presume.Today I found a thin piece of plastic about an 1" long that got caught and was resisting being ground(even though we know resistance is futile) by the grinder thing. Anyway, I took the offending piece out, put it back together and the machine is working fine. I have a hunch that the first instance may have been one of those stray cherry pits that broke up enough to get caught.
2. Solution: take apart inside assemblies to get down to the "foodmill" like thingie and see if there's something hard organic or unorganic causing the noise. Discard. Put back together and hope that solves it. (It did for our machine)
3. What's needed? Good knees or a decent knee pad and a few simple tools as follows:
A. 1- medium flat blade screwdriver
B. 2- TORX screwdrivers, # T-15 and T-20, or equivalent bits for a portable electric drill/screwdriver.
C. Small pair of regular pliers or simialr tool.
D. Muttering under your breath like Fred Flintstone, or not.
4. Process:
Take out the water jet assembly. It is held by a clip at the back and top. Use the screwdriver to pry the tabs away from the clips, then pull the assembly out at the bottom where it connects. It's a simple slide in/out fit. The bottom whirlygig water jet is fastened with a threaded cap that can be removed with the pliers. (BTW, this can get clogged with gunk. while you have it of check for gunk. Then, keeping track, remove the remaining hardware with the TORX #T-20 screwdriver until you get to a round black piece. The black piece has to come off before you can remove the piece with the filter and grinding screen. Use the #T-15 bit for removal of the black piece. Then remove the rest 'till you see a "blade". Hopefully in that process, whatever was causing "the noise" will fall out and you can discard it. Observe how gross it is in there, shudder, and begin the process in reverse.
I do have some pictures of the process in stages if you want. E-mail me at: gpfn47atyahoo.ca (note: please use the "@" symbol to replace the "at")
Well, that's it. I hope it helps someone.
Have a Blessed New Year!
Greg F-N
Posted on Jan 06, 2009
  • 401 Answers
SOURCE: ther top spray arm fell off the dishwasher
THERE IS PROBABLY A BIG PLASTIC NUT THAT IS STILL SCREWED ON THE UPPER TUB.THIS WILL UNSCREW AND WILL COME AS ONE PIECE IN A KIT.
Posted on Mar 01, 2010
heatman101
  • 43501 Answers
SOURCE: diswasher doesnt clean and leaves
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
Posted on Sep 30, 2010
  • 3 Answers
SOURCE: the top water spinner arm fell off, how to get it
This just happened to me. The spinner arm fell off. It left behind two pieces of plastic attached to the roof of the machine: a grey sunburst shape, and within that, a white circle with two prongs. It looks like the spinner arm should snap onto the white circle with prongs . . . but you can't just press it back on, because there is no resistance on the other side and the white circle just becomes displaced instead of snapping together.
But the good news is that the grey sunburst screws on and off! Unscrew it until it comes free from the roof of your machine. Now snap the white circle and the spinner arm together, with the grey sunburst between them. Give it a test spin to make sure it's all together and working, and then screw the whole assembly back onto the roof of your dishwasher.
Apologies for the lack of pictures . . . this must sound crazy to anyone who's not looking at what I'm looking at--but it worked!
Posted on Nov 03, 2010
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
My Emerson Portable Ice Maker started makeing a loud grinding sound when pumping water -why?
Probably the bearing in the pump is shot depending on how old it is try getting it covered under warranty
Oct 29, 2012 | Emerson Im90 Portable Ice Maker
When washer is started make loud grinding noise
Very likely the bearings in the motor have begun to fail. You can replace the motor, but for a 15 year old DW, sometimes it makes better sense to just buy a new one. Depends on the features the old DW has, vs new, vs motor replacement cost.
Reply back and we can you more.
Dec 13, 2009 | Dishwashers
Kenmore Ultrawash Quiet Guard 5 making buzzing/grinding noise
I have a very similar dishwasher, with a very similar problem. I fixed it by removing debris from the water evacuator pump located towards the front of the bottom of the machine (the last motor before the drain hose. In my case, grape stems had clogged it up. Once emptied, it purrs once again. NOTE: don't disassemble the motor, just flush it out, there is an o-ring gasket that is a bear to re-install.
Jun 22, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore Elite 137889, grinding noise
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the tub.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
The drum bearing is replaced by accessing the bottom side of the washer, and is a not a simple repair.
May 05, 2009 | Kenmore 13789 / 13782 Dishwasher
Load grinding noise, like the engine is working too hard.
Most likely the motor/pump assembly is worn out and grinding. If the machine is less than five years old it is under warranty. If over five years old, the repair part alone is about $150 not including labor.
Apr 17, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
Jan 25, 2009 | Whirlpool GU3600XTSY Stainless Steel...
Dishwasher making loud noise
Newer washers are designed with a food grinder inside to help grind up large pieces of food. What you are hearing is the grinder doing its job. You do not need to worry about the noise. It should go away after a while as the food particle is ground up.
Jan 10, 2009 | Amana 24 in. ADB2500AW Built-in Dishwasher
Kenmore elite dishwasher noise
I had the same problem where rubber gasket that seals the motor bearings leaked water into the bearing and rusted out the bearing.
I scrapped the motor into every little pieces and extracted the bearing and just replace it. Now it is quiet as a mouse.
You need a bearing puller to get the bearing out for about $20 and the bearing is $6.
During the repair i slightly bent the shaft and i didn't straightened it properly so it wobbles a bit. But it works and if really quiet.
May 13, 2008 | Dishwashers
My Energy Star/Built-in
Me to....My dishwasher is about 7 months old. It use to be extremely quiet. Now it is LOUD. but still works fine. HELP!
Oct 18, 2007 | KitchenAid 24 in. KUDI01ILBS Stainless...
Maytag 24 in. MDB8600AW Jetclean II Built-in Dishwasher Logo
345 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
