Question about Rowenta Powerglide DE011 Iron with Auto Shut-off
Rowenta iron with blinking light
On my iron, the blinking light indicates that auto-off is engaged. If you haven't given up on it yet, have you tried smacking it really hard to see if you can free the ball? The only thing that seems to get mine going again is to take it apart and put it back together again. I don't know why, but I guess all that shaking frees the ball and it works again...for a while. Once it starts working, if I leave it upright it keeps working. Good luck!
  • 1 more comment
  • maryschultz5 Sep 11, 2008
    I assume the auto shut-off keeps shutting the iron off and on. This is my second Rowenta. I love the iron but it should last longer than this.
  • Anonymous Dec 07, 2008
    Same issue. I'll try hitting it to "free"
  • ma_stevenson Mar 06, 2009
    Yep...same for me, only it got to where smacking did not work either. Only thing that worked was to take it apart and re-assemble. For some reason that almost always got the ball free...at least until it was plugged in and the ball switch activated the "cut-off" timer again.
    My final "brute force" fix was to bypass the control unit entirely. The thermostat is in the base element, so it still works fine. I even rewired one light to show when the element is on. The only loss is that there is no safety shutoff now...but at least it irons! Good luck & best to you.
SOURCE: Rowenta Steam Iron Leak
Yes, my rowenta model DX6700 is also leaking from the heal. I bought this iron after having a GE for ten years because I thought it would iron my clothes better. I've had it less than two years. How frustrating!!!!!!
Posted on Aug 01, 2008
wizzard8955
  • 18 Answers
SOURCE: My Rowenta iron will not heat up. The yellow light
Inside the iron is a piece of thermal metal the is supposed to make contact with a small ceramic pin with a metal cap on it. I think this was intended to be a safety device but they fail and the iron will not heat up. The part does not seem to be available so easiest way to fix is to put a small bead of glue on the housing that forces this to make contact.
Posted on Mar 06, 2009
wizzard8955
  • 18 Answers
SOURCE: Rowenta DM880 Auto shutoff - Shuts off too frequently
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
  • 109 Answers
SOURCE: need to know how to clean a rowenta iron plate
As long as it's not a coated surface - plain steel - get 0000 steelwool to rub it with. It will take some elbow grease but it will work to clean and (almost) polish the surface.
Posted on Mar 26, 2009
  • 2976 Answers
SOURCE: Iron spits out rusty water. The iron is a Rowenta
Fill it with a mix of 50% white vinegar and 50% water. Let it set for 30 minutes and steam it out for about 2 minutes. Unplug it and dump it. After it cools colpletely, fill it with water and steam it out. The rust is coming from your water supply, not the iron.
Posted on Oct 06, 2009
I was given a Rowenta Effective with no instruction booklet and I can't get it to work properly. When I turn it on it gets hot but soon after that bottom light goes out and the auto off light blinks
If you start ironing with it, does it come back on? It usually doesn't take long for auto-shut-off irons to turn themselves off--a few minutes in the upright postion, and about 30 seconds if left sitting in the down position. Once you start the ironing motion, it should come back on.
Oct 14, 2014 | Rowenta Effective DX1900 Iron with Auto...
Rowenta dz5160 light blinking
this is indicator the power cord is faulty, test it with VOM and replace.
2) see if thermal fuse inside is loose and resolder very well, and proof again.
God bless you
Jul 23, 2012 | Irons
Indicator button -red light blinks off and on
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Apr 01, 2011 | Rowenta Effective DX1900 Iron with Auto...
I have a Rowenta DX1700. The iron will only stay
The problem is with the iron's thermostat which controls the temperature of the iron
Feb 07, 2010 | Rowenta Effective DX1700 Iron with Auto...
Red light keeps blinking and iron shuts off
Sounds as if the cable may be damaged or a loose connection. May be cheaper to buy a new one from wallmart or similar store.
Jul 31, 2009 | Rowenta Effective DX1900 Iron with Auto...
I have a Rowenta Pro. Iron, model DE-86.1A with auto shut-off. It sticks on auto shut-off. I have to move it around for it to heat up, as indicated by the sensor light on the top.
I believe that is how the safety feature works.
Once the iron detects no movement for a certain period of time (the iron assumes you have finished ironing) the iron will shut of the heating element.
One you have moved it around, the timer should prevent it from auto shutting down for a period of time.
Jul 22, 2009 | Rowenta Irons
Jan 06, 2009 | Rowenta Professional Luxe DM880 Iron
My rowenta effective will not heat up.
Dec 15, 2008 | Rowenta DG5030 Iron
The light is on...but no heat at all?
Aug 10, 2008 | Rowenta Powerglide DE011 Iron with Auto...
Rowenta Powerglide DE011 Iron with Auto Shut-off Logo
605 people viewed this question
Top Rowenta Irons Experts
Shehu Pro
Shehu Pro
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
