Question about Xerox WorkCentre 4150 All-In-One Laser Printer
Toner installation error
Changed toner cartridge now it's saying it is not installed correctly Workcentre 4150
  • 550 Answers
Take it out and try again, there are often adhesive tabs protecting certain areas of cartridges, that need to be removed, and that are not obvious
Not a guarantee, just something to try
Posted on Sep 09, 2008
Xerox workcentre m24 replace toner even if the toner is new
There is no need to worry a lot what you can do is that, just open the toner access door located at the front of the printer and then you can scroll down the list of cartridges until you find the one which is giving you the message of Replacing toner.
Then press the button "1" to reset the display toner settings. If still you find any of the difficulties then we have a best place available which can actually sort out your issue and they are Micro Toner Supplies and their official website is where you can find a lot of things is https://www.microtonersupplies.com.au/toner/xerox-toner-cartridges
Basically these guys(Xerox Toner Cartridges) are famous for supplying cartridges at a specific cost and to your mentioned area but in this site there is a contact option available where you can contact them and can solve you issue. Hope this may work to you and if still you find any difficult even after accessing the prescribed website then there are many other websites where you can find better solutions.
Aug 30, 2014 | Xerox Office Equipment & Supplies
Code 09-700 xerox 4150
09-700 Toner Supplying Error RAP
The toner module has stopped supplying toner to the xerographic module.
Procedure
WARNING
Switch off the electricity to the machine. Disconnect the power cord from the customer
supply while performing tasks that do not need electricity. Electricity can cause death or
injury. Moving parts can cause injury.
1. Check that the tape seal has been removed from the xerographic module, PL 9.10 Item 1.
2. Remove the toner module, PL 9.10 Item 2. Check that the locking lever opens and closes
the toner shutter.
3. Install new components as necessary:
• Toner module, PL 9.10 Item 2.
• Xerographic module, PL 9.10 Item 1.
Jul 27, 2011 | Xerox WorkCentre 4150 Black and White...
How do I change the toner cartridge on a 4150 workcentre. Where is it?
Open the front access cover and find the toner cartridge unit on the left, next to the drum. Unlatch it and slide out the toner.
See the attached diagram
Nov 17, 2010 | Xerox WorkCentre 4150 Black and White...
I need to change my Xerox workcentre 4150 toner cartridge. The old cartridge is stuck and I cannot get it out. Any ideas? Thank you. Russ thornock
You have to twist them clockwise and then counter clockwise. There is a locating pin they stick on in back, All I can say is twist and pull.
You can try opening the right side door and sliding a thin bladed screwdriver in there to assist in lostening it .
That is not uncommon and is frustraiting.
Jul 03, 2010 | Xerox WorkCentre 4150 Black and White...
I have a Xerox 4150 printer, I install a new cartridge and get a message,"The toner cartridge is not for this machice, install the correct cartridge", I also want to add that want I took out the toner...
There are a couple of different cartridges for those machines. One is a "sold" the other "metered" if the cartridge part number is different it will give you that message.
Also remove the cartridge and shine a falshlight into the machine . Look all the way to the back and locate the springs, they make contact with the cartridge. Try gently stretching them to see if they area making good contact.
Feb 07, 2010 | Xerox WorkCentre 4150 All-In-One Laser...
Xerox workcentre 4150 printer cartridge not installed correctly
i'm going to try to explain this in english even tought is not my native language, i had the same problem with my xerox 4150, when i bought a new cartridge it worked perfectly but at some point it stoped working, and it says in the screen something like "remove toner cartridge and reinstall", the problem was that the chip (is like a sticker under the toner) was in bad position from factory, a men who worked in xerox told me that there was a lot of toner cartridge that came with this problem, and this chip is ultrasonic or something like that because it never make contact with the printer circuit, so the fact is that you only have to remove and re-paste the chip in the correct position, but you have to do it several times until it works, that's how i repaired it...
Aug 26, 2009 | Xerox Office Equipment & Supplies
J3 error On Xerox WorkCentre Pro - 215
A J3 means the toner cartridge is not compatible. That is the what the J3 message means.
Make sure the correct cartridge has been installed. For example, a Pro16 Toner Cartridge looks very similar and will fit in the machine, but it will display a J3 fault. Install a known correct Toner Cartridge if you suspect the cartridge in the machine is the problem. If the wrong Toner Cartridge has been used, the correct cartridge needs to be ordered and installed in the machine
It is possible the chip on the back of the cartridge is bad. Have you tried reseating the cartridge? Maybe it is just loose.
Dec 19, 2008 | Xerox WorkCentre PRO-215 All-In-One Laser...
I am using the workcentre 4150 and the printer keeps giving me an error saying. "toner supply failed, remove seal tape from toner cartridge and reinstall" I can't find any tape on toner...
The seal tape might be inside the cartridge, attached to a pull-tab.
I am only specifically familiar with the HP toner cartridges, which have a colored plastic pull-tab attached to the tape which seals the toner drum during transit. You have to pull on the tab which in turns yanks the sealing tape out after it.
Each HP cartridge has a small instruction sheet included which shows the location of the pull-tab. Perhaps your Xerox cartridge came with a similar diagram sheet?
Apr 03, 2008 | Office Equipment & Supplies
SMART KIT DRUM CARTRIDGE
Call 1-800-821-2797. Thats a machine software issue..
Here is the note on it.
Problem:
The DRUM and TONER cartridges are not installed correctly. Web page indicates replace %0 empty cartridges. The Machine doesn't copy. Cause:
Firmware and work-process problem. . Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Don t worry about cartridges. They are safe. Upgrade firmware. The message goes away and machine copies
Mar 07, 2008 | Xerox WorkCentre 4150 All-In-One Laser...
Xerox WorkCentre  4150 All-In-One Laser Printer Logo
274 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
