Question about Philips GOGEAR SA6045 MP3 Player
Still not working
I got the mp3 player 2 months ago and it is not working at all. It will not turn on or charge i held the volume + button and it still not working.
  • 8,596 Answers
Make sure hold is not engaged. If it is not, then the player's done. Call Philips as they have a minimum 90 day warranty.
Posted on Sep 09, 2008
M mp3 wont turn on!!! :(
You can try a reset by doing this: Slide the power button up for approximately 15 seconds, which is basically like a complete power down of your device. Once you do the reset, it should work like normaly, but the adjustments you made during the last operation of the player will be gone.
Apr 06, 2009 | SanDisk Sansa Clip MP3 Player
I have a Philips Gogear Mp3 player. suddenly I'm not able to switch on the power supply and i tried charging it for 4-5 hrs.no Use. It's just 4 months old. can u help me?
It's dead. The HDD models are basically obsolete - you may have purchased it 4 months ago, but it was manufactured 3 years ago. Here is the basic troubleshooting to be sure, but it won't work:
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Dec 12, 2008 | Philips GoGear HDD1830 MP3 Player
Not working
Disconnect the player from the PC, and make sure the mp3 player is turned off. Hold in the volume + button on the mp3 player, and reconnect the player to your pc while holding in the volume + button. Continue holding the volume + for 10-15 seconds until a "Found New Hardware Wizard" pops up. It should recover your device if there isn't anything internally wrong with the player. Warning: this procedure will result in your songs being erased off the player, so they will have to be reloaded.
Sep 03, 2008 | Philips GOGEAR SA6045 MP3 Player
Phillips 6045/37 - Charging
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If it fails to charge after 3-4 hrs, or fails to keep charge once unplugged, get the mp3 player replaced.
Aug 17, 2008 | Philips GOGEAR SA6045 MP3 Player
HELP!!!!! My zune's buttons are not working!!!!!
Make sure the hold/lock is not engaged
Make sure the OS is compatible
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Apr 12, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My Ilo MP3 will turn on but will only turn off after loading.
Sep 24, 2007 | iLO (2 GB) MP3 Player
I was wondering if i could contact ilo for problems with my ilo mp3 player
I am planig to register NGO For civil rights need contact
Jun 20, 2007 | iLO MP3 Player
Why won't it turn on!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Recovery Mode:
Jun 09, 2007 | SanDisk Sansa e260 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
