Drain prob It fills with water, agitates, but won't go into the next cycle. The drain /pump doesn't make a sound. I read that it could be the lid switch. When trying to remove the lid switch, I can get to it, but can't remove the electrical from it. I get the ground off, but the wires that go into it won't come off.
  • hapaboy Sep 09, 2008
  • 749 Answers
Faulty sensors
Posted on Nov 05, 2008
No drainage, Sound in Spin/Rinse Cycle
You may have a broken pump belt, or belt may have fell off pump pulley. Another possibility is that you have a bad clog before the pump keeping water from draining. Your machine will agitate because this is a separate belt. Good Luck Friend.
Oct 13, 2017 | Kenmore 98702 Stacked Washer/Dryer
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Tip
How to fix a Washing Machine if it doesn't Drain
If your washing machine fills and agitates but does not drain, something is probably wrong with the drain hose or the pump. The fact that the washer fills and agitates tells you that the motor works and the belt is fine (though some units have a separate belt for the pump, and direct-drive washing machines don’t have belts.)
1) Be sure the drain hose isn’t kinked.
2) Check the tab on the lid that strikes the lid switch; if it is broken, the washer may stop during the drain cycle. Press and release the lid switch. If it doesn’t click each time you do this, it’s probably broken. If you’re experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repairperson.
3) The water pump may be broken or clogged with a small article of clothing, or the controls may be broken; call an appliance repairperson.
on Sep 03, 2010 | Washing Machines
Washer wont spin or drain
Yes, you can check the LID switch as it needs to activate the program to move forward. If the water fills up and there is no wash cycle, check if the motor hums, if so check the capacitor, check the friction on the spindle/drum. If the spindle does not agitate with movement the assembly must be reset.
Jan 23, 2013 | Washing Machines
Washing machine will not drain
Since you've already checked the pump, hoses and motor, here are some additional issues to look at:
1. Faulty timer: Does your machine fill with water and begin agitating, but the cycle never advances far enough to allow the water to drain? The timer that controls the cycles may be broken. Arrange for washing machine repair service.
2. Worn or loose belts: Are clothes still soaked at the end of a wash, even though the washing machine appears to go through the spin and drain cycles? The timer that controls the cycles may be broken. This is a job for the pros.
3. Faulty or jammed internal impeller on pump: When the spin cycle starts, do you hear a humming noise? The internal impeller that moves the water through the drain pump may be faulty or jammed. A grinding or grating sound is almost always an indication of a coin, button or other object colliding with the impeller. Have a washing machine repair expert determine if the impeller is jammed and can be cleared, or if the pump needs to be replaced.
For more troubleshooting steps, see Washing machine won't drain. I hope this helps!
Oct 08, 2012 | Washing Machines
Washer fills and agitates but wil not empty or spin. I tried to bypass the lid switch and still same problem. How do I check the timer.
Hello there and thank you for choosing fixya
OK first lets get back to the basics
First investigate these things fully
It doesn't drain dot_lineone.gif 1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
3. TIMER OR CYCLE SELECTOR
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. THERE IS NO REPAIR FOR THE TIMER
Aug 04, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Not sure if manifold is leaking
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
  1. Agitation problems and agitator dog repair aid info
  2. Automatic dispenser information
  3. Common problems with Inglis, Whirlpool, Kenmore direct drive style of washers
  4. Diagnostic Direct Drive washer chart from American appliance
  5. How a washer works, good to read this first
  6. Help for storing an appliance
  7. How does the agitator come off my washer ??
  8. How to prevent socks from getting into your pump
  9. Ohm test a common direct drive motor
  10. How to by-pass a lid switch for testing the washer
  11. Basic information: Inglis, Whirlpool, Kenmore Direct drive washers
  12. Inglis, Whirlpool, Kenmore Direct drive washers - How to take apart - Cabinet off, cabinet on, checking or replacing a lid switch, replace the pump, replace motor coupling or motor.
  13. Inglis, Whirlpool and Kenmore direct drive washer- useful parts breakdowns
  14. Important disclaimer
  15. My direct drive washer will fill ok, agitates ok but when it comes to the spin and drain cycle the washer comes to a screeching halt...no spin, no draining and the timer stops, what's up?
  16. My clothes have a whiting on them that looks like lint.
  17. My washer has a funky odor
  18. Noises
  19. Ohm meter testing a motor capacitor
  20. Slow water fills
  21. The wash tubs on my direct drive washer are leaning to the right...why?
  22. Timer stalls or missing cycles
  23. Timer will not advance
  24. Tips on changing a common washer fill valve
  25. To learn more about washing machines, click here
  26. Washer Basics: Filling with water
  27. Washer leaks water
  28. Washer moves around to much
  29. Washer will not spin
  30. Washer sample wiring diagrams
  31. Washer spins and agitates at the same time
  32. Washer belts: If your belt on any washer looks like these, replace the belt(s).
  33. Washer runs but wont agitate or spin
  34. Washer won't run, agitate or spin
  35. What is that black power powder or filings under my washer??
Apr 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Won't go to spin cycle-water still in
sounds like your lid switch is defective. if it will fill and agitate but not drain/spin, the most common problem is the lid switch....your machine thinks the lid is open
Dec 29, 2008 | Roper RAX4232KQ Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
