Question about Texas Instruments TI-84 Plus Calculator
CANNOT ACCESS MEMORY ON TI-84
I CANNOT ACCESS THE MEMORY ON MY TI-84 PLUS SILVER
PLEASE SOMEONE HELS
WHEN I PRESS 2ND AND + I TDOES NOT DO ANYTHING
DOES ANYONE KNOW WHAT IT IS?
PLEASE HELP
  • 32 Answers
Yes i know exactly what that is. This happens when you are in mirage OS and you set that option. What you need to do is take out the batteries when its on or go to mode and press alpha and s (LN) and then it should ask for self check say yes and press enter for like ever. I prefer to take out the batteries Then quickly go to memory and delete the avtar. It should do the trick.
Posted on Sep 13, 2008
That is MirageOS options. If you have the apps Krolypto or Omnicalc, then it could be the options that were set.
Posted on Sep 22, 2008
Cant find ! button
There is no such thing as a TI89 Plus Silver Edition.
If you mean the TI-89 or TI-89 Titanium, press diamond / (the diamond key below the 2ND key, then the divide key).
If you mean the TI-83 Plus Silver Edition or the TI-84 Plus Silver Edition, press MATH left-arrow 4 .
Dec 15, 2013 | Texas Instruments TI-84 Plus Silver...
I have a TI 84 plus silver edition. Won't turn
The problem may be due a screen that is too light to see anything on it. Adjust the screen darkness.
  1. Press [2nd] key and release it.
  2. Press and HOLD the [UpArrow] to draken screen.
  3. Release the [UpArrow] when screen is dark enough.
You can also connect it to the computer to see if TI Connect finds it. If it does, update the OS to version 2.53MP.
You change the backup battery if the calculator tells you RAM CLEARED each time you turn it ON.
Dec 16, 2009 | Texas Instruments TI-84 Plus Silver...
When i press most buttons it gives me the message ERR:MEMORY i cant access memory so i cant reset ram or delete . also i can not connect to my cpu it says TI-84 plus Silver Edition detected, but couldn't...
From the TI knowledge base and FAQ
How do I correct ERR: MEMORY on a TI-83 family or TI-84 Plus family graphing calculator?
An ERR: MEMORY is given when there is not enough memory to perform the instruction or function. To increase available memory by deleting the contents of any variable (real or complex number, list, matrix, Y= variable, program, Apps, AppVars, picture, graph database, or string), follow these steps. • Press [2nd] [MEM] to display the MEMORY menu.
• Press 2: Mem Mgmt/Del.
• Select a variable or data that needs to be deleted and press [ENTER].
• Use the arrow keys to move the cursor next to the item, and then press [DEL]. The variable or data should now be deleted from the memory.
When deleting programs or Apps, a message asking for confirmation will appear. Select 2:Yes to continue. To leave any variable screen without deleting anything, press [2nd] [MODE].
Notes:
With the exemption of programs and Apps, no warning will be given to verify the deletion.Some system variables, such as the last-answer variable Ans and the statistical variable RegEQ, cannot be deleted.
Hope it helps.
Oct 06, 2009 | Texas Instruments TI-84 Plus Silver...
Reset
First, turn it on. Once the calculator is on, press the "2ND" key (I believe it is a blue key in the ti-84 plus silver edition). Now press the plus key (+). A little above that key, you should see the word "mem." When you see the screen titled MEMORY, move the cursor all the way down to the option that says "Reset." From here, you can choose to reset either the RAM memory, or the factory settings. The factory settings are the "Defaults" option. I hope this helps.
Thanks.
May 23, 2009 | Texas Instruments TI-84 Plus Calculator
Ti-84 plus silver edition will not graph
try going into the memory men (2ND - +), and selecting option 2.  Delete some stuff you know you don't need.  If the problem persists, 2ND - +, this time option 7.  Reset the defaults.  You won't lose anything, it will just reset the settings that may be causing this issue.
Jan 25, 2009 | Texas Instruments TI-84 Plus Silver...
Waiting Please Install Operating System Now.
i finally fixed my calculator~
1. if you have a ti 84 plus silver, plus, or just ti 84, find a friend who has either a ti 84 plus silver, plus, or just ti 84. (as long as the number is the same)
2. link the two calculators together
3. using your friends calculator, press the [2nd] and the one next to alpha [x,t,o,n]
4. go all the way down to [send os]
5. send it to the other calculator and your problem should be fixed
Aug 27, 2008 | Texas Instruments TI-84 Plus Silver...
"Err: Data Type" - Not Allowing Me to Graph
Jul 25, 2008 | Texas Instruments TI-84 Plus Silver...
press 2nd and then the down arrow over and over until the contrast is adjusted. Did you read the manual?
Apr 15, 2008 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Calculator Logo
258 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
