Question about Epson Stylus Photo RX700 All-In-One InkJet Printer
Error message - no ink
I have just put all new (non Epsom) ink cartridges in as and when needed, but they are all fullish and now, suddenly, an error message won't allow me to use the printer at all. It claims i need to replace all the inks. I am on a mac and can't download the programme to resolve this and live in the wilds and need my printer. Please help! Will buying Epsom cartridges resolve this and why has it been working ok on others up til now? Thanks, Maria
  • mariarty Sep 09, 2008
    Thanks, I tried all that but no joy. The LCD reading still says all the inks are out, although it also will tell me (before this comes up and freezes everything) that the ink levels are fine.
    Very frustrating. I have even opened new cartridges and tried them, same problem.
    Hi Thanks for this...in the meantime I rang the ink suppliers and they told me to take out the cartridges one by one and then replace one by one. In this way we found that one of them was not working correctly and causing the whole problem. It had been working but wasn't now. Anyway, I replaced that cartridge with a new one (Epsom compatible) and since then all well. The company are sending me a replacement cartridge.
    I will bear in mind your instructions if I have problems again I can't resolve in this way.
    Thanks for the support - very appreciated.
    Problem Solver:
  • 9 Answers
Hi Maria,
Try removing all of the ink cartridges again. Open the cover and remove all of the inks. Close the cover and turn the printer off. Leave it off for about 30 to 45 secs. Turn it back on. Install again the ink cartridges. Check if it will charge after closing the cover.
If it still says that ink need replacement, check your lcd panel. Usually it will tell you what ink cartridge needs replacement. This might be a faulty ink cartridge.
Posted on Sep 09, 2008
  • Rey Romero
    Rey Romero Sep 09, 2008
    Hi Maria,
    This is an issue regarding inks that is not being recognize by your printer. Epson inks has an embedded green circuit board on it. That circuit board connects on the pins located inside your the printer. You can actually clean that pins using a cottons buds, lighter fluid then an alcohol.
    After removing all of the ink cartridges, turn the printer off and unplug it from the outlet. You will have to use a flash light so that you could locate those pins inside then use a cotton buds (used for clearing ears) to clean it. Put a little bit of fluid on it. Rub it gently 4 to 5 times on every pins. Make sure that you don't rub it too hard because cottons might get into those pins. Do this in all of the pins inside the printer, left panel and right panel. Then follow it up with an alcohol on the cottons buds. Same steps above.
    Once your done, let it dry for a couple of hours. 2 to 3 hours will be enough. Turn the printer on. Install the inks then close the cover.
    If it won't still recognize the ink cartridges, this is already a hardware issue.
  • Rey Romero
    Your welcome Maria. Thanks for the rating too.
Refilled my ink cartridges on hp 309g gets error message
Yes it does work on HP C309g-m if you place a cartridge one by one as follow:
1- open the cover
2- replace an original hp cartridge by the compatble non hp cartridge
3-unplug the printer
4- close the cover
5-plug printer back on
6- press ok to all messages
7-repeat from step 1 to 6 above for each new non hp cartridge
Et Voila.
Many Thanks
Oct 09, 2012 | HP Photosmart Premium C309g multifunction...
Epson 515W Error message showed paper jam - switch off and clear paper. When the printer is now switched on it indicates error has occured switch off etc. So loop is swittch off / switch on. Some use has...
Yes, that would have caused the error,
But first try to inspect the printer, locate any obstructions,torn paper, on the printer's paper path.
If all is well, try using other cartridge, Original ones if you may have or may borrow from others, for this step, you can check if that has been the issue, for Epson strictly says to use original inks cartridges, for using non-genuine ones, causes several troubles such as this one.
If still the problem is there, a call or visit from an Epson repair center would be the best thing to do, there maybe some parts damaged from the insides of the printer, that in no reason a user can repair by himself.
Hope this helps thank you for using Fixya
Jan 16, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Error code comes up on my new never Epsom printer reads paper jam
If this is brand new, it needs to have its ink cartridges installed and paper in its tray. It won't be happy until it's completely ready to go.
May 16, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Printer giving 'incompatible ink cartridge' message
replace your cartridge with a new one or refill others old
check here how you can do it your self
utube.png You-Tube video "sOriLrbuBao" placeholder (do not delete) utube.png
utube.png You-Tube video "II9gpIXs_lE&feature=related" placeholder (do not delete) utube.png
Apr 16, 2010 | HP Officejet 5610 All-In-One InkJet...
I have a kodak 5500 aio printer. I replaced the
Try the following:
1. Open the printer access door.
2. Put out both ink cartridges and the printhead.
3. Let the printer access door open.
4. Put out all paper.
5. Pull out the ac adapter at the back of the printer.
6. Wait 60 sec.
7. Pull in AC adapter.
8. Wait 30 sec. then turn on the printer
9: Wait for the error message: Printer access door open.
10. Close the printer access door.
11. Wait for the error message: Printhead is missing.
12. Open the access door and put in only the printhead and the close the access door.
13. Wait for the error message: both ink cartridges are missing.
14. Open access door, put in only the black ink cartridge, then close the acess door.
15. Wait for the error message: Color ink cartridge is missing.
16. Open access door, put in the color ink cartridge and then close the access door.
If the error is solved, do a firmwareupdate right now.
You can find it here.
Sep 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Dell 944 all in one - used NON-Dell Print Cartriges - Cheaper
Hi there
Your error message is coming from the Dell Series 5 ink Cartridge. To reset the error message, unplug the printer from the wall. Now remove the power brick from the back of the printer. Wait 60 seconds and then plug everything back in. This usually resets any error messages on the printer. Make sure the Dell Series 5 ink cartridges are intalled correctly by removing them and re-seating them .
Black in left or black side, color in right side or color side
If using a photo cartridge...
Photo cartridge in the black side(left) and color in the color side(right)
Dell Series 5 ink cartridges have a sensor in them that cannot be reset
It is also possible to get a new ink cartridge with a bad sensor. Please take it to the place of purchase for a refund or a replacement one.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Sep 13, 2009 | Dell A940 All-In-One InkJet Printer
HELP..."ink cartridge not compatible" error message.
I had the same problem and solution was change the cartridge for a new one (My printer is a HP PSC 1315)
May 11, 2009 | Office Equipment & Supplies
Epsom Rx620 states use originals for ink cartridges
Try to hold down both 'stop' and 'B&W' button when you press the 'on' button to start the printer machine. This should erase the error message and let you print.
Regards.
Gordon
Sep 25, 2008 | Epson RX620 All-In-One InkJet Photo...
Paper jam error message
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
Apr 21, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
Epson Stylus Photo RX700 All-In-One InkJet Printer Logo
219 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
