Question about SanDisk Sansa c200 MP3 Player
Sansa c200 wont delete songs in anyways
Hi IM new here but i got a major problem my Sansa C200 does not delete songs at all i tried everything it said on the site of Sansa.com but it does not work at all can someone please help me.
Just plug it in to your computer go to start then computer go down until it tells you that its there then go to that go to music then delete the songs you don't want
Posted on Oct 18, 2008
Hello, Am using Sansa c200 . am unable to delete songs which i hav copied into player. and even i cant see any songs on computer(my music folder was showing empty) .i even tried to format the disk ..but...
See this tip posted here on this site. It may explain what is going on. copy this address into a new window -- http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem
If that does not work go here and download the Sandisk utility. http://kb.sandisk.com/app/answers/detail/a_id/156
Jan 16, 2010 | SanDisk Sansa c200 MP3 Player
PLEASE Help with my sansa c200 mp3 player!
The Sansa c200 has 2 versions, version 1 and 2.
Check the version of the player:
Go to Settings > System Info.
Information for the firmware version and SD cards support:
For 01.xx.xx firmware (c200 version 1) - up to 2GB microSD cards
For 03.xx.xx firmware (c200 version 2) - up to 4GB microSDHC cards
Note: Firmware is not interchangeable.
Manual for c200 series:
http://mp3support.sandisk.com/downloads/um/c200-ug-eng.pdf
Manual for c200v2 series:
http://mp3support.sandisk.com/downloads/um/c200v2-um-eng.pdf
For deleting files connect your player with the computer.
When running Windows Media Player 11:
1. Check the automatic SYNC routine for your player.
How to get to the SET UP SYNC
When viewing WMP11 in full mode select SYNC or LIBRARY in the top of WMP11, seeing the Sansa player listed on the left.
Right click on the player and select SET UP SYNC... to go to the SYNC options.
When "Sync this device automatically" is selected, all playlist in the computers' Library will be transferred to the player again, even the previous deleted files. Disable this function to prevent unwanted SYNC.
2. Remove playlists from the library in set up sync, to get the playlists you would like to keep on the player.
Need more help ? Just post a comment.
Dec 10, 2009 | SanDisk Sansa c200 MP3 Player
I have a problem with my SamDisk Sansa c200 (1GB MP3 player) I am trying to delete all the songs from the player, and it tells me that there is no songs of data on the player, and yet it tells me how much...
Deleting Files,Pictures,etc from MP3 Player
Hook up your mp3 player to your computer Go to your desktop and double left click on "My Computer" When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there. Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible. Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete" Now you mp3 player should be clear of the files/songs you do not want. Good Luck, I hope this helps
Nov 29, 2009 | SanDisk Sansa c200 MP3 Player
My Sansa c200 says memory full
some times their is not enough space in phone memory! if you hav any pic or video in phone memory! move memory card or pc! then you can download songs! actually one songs is 3mb! check phone memory
Jun 30, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Removing songs
You can remove the song through buy sansa c200 software or you can remove directly by connecting through system.
Feb 23, 2008 | SanDisk Sansa c200 MP3 Player
Cant load songs
the best way for that is to read your manual.
MINIMUM SYSTEM REQUIREMENTS
Windows XP SP1
Windows Media Player 10
Intel Pentium class PC or higher
CD-ROM drive
USB 2.0 port required for hi-speed transfer
CONNECTING AND TRANSFERRING
Connect to your Computer
1. Connect the small USB Cable Connector to the USB port on your computer, and then plug the larger
Cable Dock Connector in to your Sansa c200 port.
2. Once connected to computer, it should be detected by the operating system automatically and is
shown as an additional drive called “Sansa c200”.
SANSA MEDIA CONVERTER
You will need to use Sansa Media Converter to transfer photos to your Sansa c200. Insert your SanDisk
CD and select Sansa Media Converter to install it to your PC. Then you can load your personal photos
onto your Sansa c200 by using Sansa Media Converter.
TRANSFER MUSIC
To transfer music to your Sansa c200:
1. Connect Sansa c200 to the computer.
2. Drag and drop files from your computer to Sansa c200 by using a variety of music software
programs to transfer/synchronize your files.
3. In MTP mode as long as the files are WMA or MP3, they can be dragged into the Media folder.
Otherwise, they can be dragged into the Data folder (these files will not appear on the player).
4. In MSC mode, files/folders can be dragged/copied to the device.
Jan 27, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Opening Files/Importing Songs
Sandisk provides "how-to" videos for everything Sansa related
http://www.sandisk.com/Retail/Default.aspx?CatID=1468
Additionally, try transferring songs using winamp
Jan 09, 2008 | SanDisk Sansa c200 MP3 Player
Deleting the same song, with a different name
the reason it doesn't show the track version is because you changed the ID3 tag (which is something inside the music file, not the actual file name).
Try using winamp to delete your songs, it will read all the ID3 tags properly and show you the track version names
Jan 05, 2008 | SanDisk Sansa c200 MP3 Player
Connection problems Sansa c200
You should check out the sansa community forums, they are very helpful
Very helpful Sansa user Forum
Offical Sandisk Sansa user Forum
Oct 28, 2007 | SanDisk Sansa c200 MP3 Player
Sandisk sansa c200(2gb)
Do you use windows media player 10 or 11 to sync music into the mp3 player? and have you updated firmware? Go to sansa.com and download a firmware updater and then try formatting the mp3 player, use WM and click on the arrow below sync and go to format.
Jun 10, 2007 | SanDisk Sansa c200 MP3 Player
SanDisk Sansa  c200 MP3 Player Logo
81 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
