Question about Sony Xplod XM-1652Z Car Audio Amplifier
Sony amp 1000w
I just got this amp and dual subs. but now i hooked everything up and they barely work. ive heard them from like seconds before i installed them and they sounded great but now when installed them all in my car they barely push or anything. ill turn it down and get very very little bass but when i turned them up they cut out and pop. i rewired it 4 times, fixed up the grounds and everything.i still get power and everything but i just doesnt produce bass
  • 631 Answers
Check the wiring of the speakers (both inside the box and between the box and the amp). It sounds like one speaker is wired incorrectly at one connection point.
Posted on Sep 11, 2008
800 watt mono block sony xplod amp blowing my dual coil 1500 watt subs
if the wiring to the sub is correct, then you have something wrong with the amp itself... something is power surging to the subs which is causing them to blow
Aug 25, 2012 | Car Audio & Video
I haave a sony xplod 600w 3and4 channel amp. all wires are correctly installed and it works for like half a second then the protector light comes on (goes green to red) and stays red. ive checked the...
Well as far as getting a different amp depends on what kind of subs or speakers you are trying to push. Also it depends on how much you are asking the amp to do. If you are asking a 600w amp to try and do 1000w job its just not gonna work and it will shut down.
Jan 04, 2011 | Car Audio & Video
What is wrong with my 1000w sony xplod amp?
need repairs on the inside usually when u see that fuse melt something else probably melted on the inside. something is grounding out the amp on the inside . get it checked
Jun 05, 2010 | Car Audio & Video
Subs not working
has everything been hook up correctly more specifically the RCA,s.make sure theres a source. If u sure everything is fine check ur subs with a dmm
Apr 27, 2010 | Car Audio & Video
I hooked my Hifonics BXi 1610 Brutus series amplifier up to my 2 12" Kicker Solo Baric L7 subs. Everything turns on on the amp but its barely pushing my subs. Ive tried tuning it and it still doesn't push...
wire the subs if thair dual 4 ohm . in parallel. red to red and black to black. giving it a 2ohm load. do the other sub the same. and conect it on the amp . turn your gain about 12oclock and db level less than 12oclock and your frequnecy around 80-100. and that should work
Feb 18, 2010 | Hifonics BXi1608D Car Amp
Sony Xplod Amplifier Problem
First make sure you are using at least a 12 guage speaker wire for sub connections. Second make sure you have plenty of breathing room in your mounting position, these things need air badly. Third of all, Xplods are not very friendly if they are cranked all the way up on your dB boost knob. Only crank it about 3/4 of the way up, then use your equalizer settings to tweak the thump.
Oct 20, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Sub cutting out
Check the 12v wire running from the battery to the amplifier. Also the sony explode is a garbage subwoofer compared to the Alpine.. sony (they say 1200w max but its more like 100w to power the thing) Amp could be going. Is the amplifier hot when running. If there is a burnt smell comming from the amp, its the amplifier
Mar 27, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
One speaker is working more than the other
I would replace the wire your sub is hooked up to and try hooking up the sub that was sparked to the opposite channel on the amp to make sure the amp is not the culprit. Also switch RCA cables L to R, R to L
Feb 02, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony xplode 1000w amp has green light puts out no power to subs
may haveto turn sub on through the stereo itself if rca cables are good.
Jan 08, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Compatible amp for subs
hi there. yes it should work providing you have the correct wiring it for it, if you buy the LV 416 enquire about a wiring kit to fit, most will. theyre normally around 20pounds. most amps will be compatible with most subs. i run both my 12inch 1000w off one 1200amp at half power, they kick lovely and i have no problems.
any other quiries please ask
adam
Nov 10, 2007 | Legacy 2CH 1000W AMP Car Audio Amplifier
Sony Xplod XM-1652Z Car Audio Amplifier Logo
106 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
