Question about Garden
Removing rear wheels on older simplicity mower
Simplicity
4 Suggested Answers
panilling9
  • 284 Answers
SOURCE: Need to remove rear wheels to replace tires on MTD riding mower.
most likely rust has taken over
find some liquid wrench or pb blaster and spray the axles liberally and let it penetrate the axles and wheel hubs where the axle goes through.
use a 2x4 and a hammer to tap against the wheel hub to try to move it down the axle then tap in back on to try to free it up as the penetrating oil works in, spin the wheel and tap in different areas of it
the worst case cenario would be to use a torch and heat the axle and hub up and drive it off, but it sounds as though you are moving it some and with some patience they eventually should come off
when you put them back be sure to coat the axle with some grease and do not forget to reinstall the key stock in each wheel, if they have it
the bolt in the center of the axle is all you need to remove and note where the washers came from and where they go back.
hope this helps you some
Posted on Jun 14, 2009
mickey813
  • 472 Answers
SOURCE: I have an older Snapper lawn mower that just stopped moving.
your trans axel has striped out in side you will need to get that in to the shop let me know if this helps you or if you need to find a shop
Posted on Oct 04, 2009
  • 89 Answers
SOURCE: Removed bolt but still can't remove rear wheel on
they sometimes are very haed to get off some wheels have two holes on the rim you have to use a gear puller
Posted on Nov 05, 2009
Simplicity citation 52" deck front rollers tear yard when making turns
you need to find the grease fittings for the front rollers or wheels and grease them. this needs to be done often in the cutting seasons.
May 14, 2014 | Simplicity Citation 61" 28HP Zero Turn...
Simplicity
The key on the shaft may be sheared. Remove the wheel and check the keyway.
Oct 20, 2012 | Simplicity Coronet 13.5/30 Riding Mower
How to remove rear drive wheels on old MTD 21
Daren Ingold's suggestion works only for the right rear wheel on my 19+ year old MTD Yardman 21" self propelled mower. The ratchet spur on rear left wheel is held on by a bolt in the center of the axle and a spline. Remove the center bolt and washer. Pry the ratchet spur off the spline by using three medium blade screwdrivers wedged between the wheel and the spur gently tapping the three screwdrivers in succession until the spur is half off the spline. It will come off easily after that. Remove the spur, noting direction, and remove the wheel and replace it with one of the front wheels (they're all the same design) if it is in better condition and use the rear wheel for the front. Good luck ever finding a new replacement for this particular wheel. My mower is 19+ years old but runs perfectly otherwise. Stored in dry basement.
Sep 23, 2012 | Mtd Yard - Man 160cc, 21" Self - Propelled...
I just received a simplicity 3110 electric start mower year 1979. I need to replace the back tire but it's missing the e-clip and I don't know how to get the wheel off. How do I remove the wheel?
well if the clip is missing and the wheel is stuck on then its rusted on and you will damage the wheel and the axle seal if you try and heat it up i just pry the beads off on the mower jack it up and change the tire with the wheel on the mower sounds hard put its not to bad
Aug 01, 2012 | Garden
Simplicity mower won't roll
if its a hydo drive you need to pull the release on the rear of the mower to push it around
May 10, 2012 | Garden
Simplicity rear engine riding mower model #1691537, S/N 5231, 10REG Type, 20 yr old. need front wheel assy #1679712. Do not want any of the bearings , tire, or innertube. Just wheel. My hub welded...
You can order one from this website http://www.partstree.com/parts/?lc=simplicity&mn=1691551+-+3108E+Rear-Engine+Rider&dn=12261
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
Aug 05, 2011 | Garden
I bought a 2008 Simplicity Riding mower that has no manual. I'm trying to find where I can get one. I found a web sight but you have to have a model number and and I don't know where to find it on the...
the sticker with the model and serial number on my simplicity is riveted to the outside of the frame, just behind the right front wheel.
May 03, 2011 | Garden
How to set timing on a push mower with a tecumseh
if it is an older machine, yes, the points are underneath the flywheel---it can be removed without a puller---just a little patience will get it off
May 12, 2010 | Craftsman Push Rear Bag Lawn Mower w High...
Soft steering 2007 Simplicity Prestige 27hp tractor.
have you checked your fluid level
Aug 13, 2009 | Garden
Garden Logo
227 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
