Question about Sony KDF-E50A10 50 in. LCD HDTV
Sony kdf-e50a10 No picture or sound. I replaced the XL2400 lamp and no change
  • 2 more comments
  • canif Oct 29, 2008
    When I turn on the TV, the green power/stanby light comes on and thats it. No click, no picture and no sound.
  • family2e Mar 20, 2009
    When the power is turned on the green light comes on and stays on but no picture and no sound, nothing.
  • s_mini Apr 11, 2009
    How do you change the lamp driver, and where do you find it? Same problem, changed the bulb, green light flashes for about 30sec and then the red light blinks 5 times. I hear the fans go on and checked the door switch, those are working.
  • trueplayer01 May 01, 2009
    my tv is doing the exact same thing. should i call someone?
It is either a lamp sensor problem or a lamp driver problem.
Posted on Oct 13, 2008
I have a sony kdf-e42a10 that will work for about 2 or 3 miutes at a time then losesound and picture for about a minute. green powerlight will flash while not working.
Hello, the lamp is going bad, use only a genuine Sony lamp in that set to keep from damaging the ballast. the part # is XL-2200U....tks
Aug 02, 2014 | Sony XL2400 LAMP - TV KDF-E42A10,...
Sony Kdf-e50a10 keeps shutting off and on.......Power/standby blinks during this time.....No Lamp Light
The blinking light is typical of a failed lamp and they last commonly between 2-5 years tops in these sets. You should replace the lamp. The link below is to the lamp for your set.
Replacement Lamp: Sony KDF E50A10 KDFE50A10 Lamp with Housing XL2400
Jan 24, 2014 | Sony Televison & Video
I have no picture. I have sound, but you can not increase or decrease the volume. I can change channel theu the cable box but still no picture. The lamp indicator light is not on. Sony...
Hi:
Just because your lamp indicator is not on does not mean that its not time to replace the lamp. This light only comes on if the lamp shatters in its housing, but if the lamp is worn or faulty it will not light the lamp light just no picture symptoms replace your lamp first.
Mar 27, 2011 | Sony KDF-E50A10 50 in. LCD HDTV
I am in a 220C.50 Hz country Are all the XL2400 lamps the same, or different models for various voltages and frequencies
XL2400 lamp are same every where and can be used in Sony tv either in 110V 60Hz or 220V 50Hz
Hope this will help.
Thanks.
Mar 17, 2011 | Sony (XL-2400) Projector Lamp for...
My Sony Grand Vega (KDF-E50A10) LCD just made a loud pop sound and now there is no picture. The only sounds are a loud buzzing coming from the back....is this a burned out lamp??
Yes, loud pop sound was broken lamp in tv, replacement of lamp will fix tv problem.
Lamp replacement procedure is easy and would be written in user manual.
Please buy Sony original lamp for good picture in tv.
Thanks.
Nov 02, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
(XL-2400) Projector Lamp for KDF-E42A10, KDF-E50A10: I have a KDF-E50A10. 4 years old. Lamp went out af...
This is by far the best xl2400 site ive come across so far. Has all the details as well as replacement guide and a direct link to amazon.com for purchasing...definitely check it out if you have any questions or concerns.
May 18, 2010 | Sony (XL-2400) Projector Lamp for...
Sony KDF-E50A10
If the lamp is new it could be the ballast the one is supply high voltage for the lamp you can order that ballast from Sony
Check the lamp if is not damage any where
Cheers
Dec 11, 2008 | Sony (XL-2400) Projector Lamp for...
Sony KDF-E50A10
Replace the lamp, sounds like a weak or old lamp. Use an original Sony, the replacement lamps are unreliable
Jul 10, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Sony KDF-E50A10
You may want to have the optical block checked out. Usually when you see spots or blotches of color it's due to a malfunction of the Opt. Block assembly.
Feb 22, 2008 | Sony (XL-2400) Projector Lamp for...
Sony KDF-E50A10 50 in. LCD HDTV Logo
324 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
