Question about Maytag Atlantis MDE7400AY Electric Dryer
My maytag dryer doesnt work
My dryer stopped mid load and the light will not evne come on but the timer does work--nothing else
  • pshreves Sep 18, 2008
    the timer works so i assuem there is power to the dryer
    are you saying there is a fuse in the dryer i shoudl check??
  • 943 Answers
Hi thanks for the question i would check the power coming into the dryer a fuse couldbave blown
Posted on Sep 18, 2008
  • john gagnon
    john gagnon Sep 18, 2008
    hi there is also a thermal fuse located in the front of the dryer on the air duct you must remove the front to get to it small plastic part 2 smaller wires go to this part this fuse fails often the cause poor venting to the outside look at that thanks the appliance doc
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ... > ... > Home Improvement
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
Maytag MED5700TQ Electric Dryer lost all power
Hopefully you still have your manual-if not dwn load this one and go to page 23
Download 20W10150608A.pdf initiated. If download did not start, click here to try again.
Dec 29, 2012 | Maytag MED5700TQ Electric Dryer
Stopped in mid cycle.
The timer went bad. If you move the timer manually to spin will it pump the water out? if it works that way then the timer is bad for sure
Nov 12, 2009 | Maytag Bravos MTW6600T Top Load Washer
Our dryer stopped working mid cycle. light
with no light it tells me you have lost L1 check your outlet, and your wire connections
Sep 30, 2009 | Maytag HYE3658AY Electric Dryer
The Dryer stopped and will not start again
Just had a similar problem with our Maytag Electric Dryer. The dryer shut off mid-cycle and wouldn't start again, but the timer kept running. We purchased a "Thermal fuse replacement kit" at a local appliance parts store for $38 and replaced the fuse ourselves. The dryer is running great! Here's a couple of website links that were helpful in figuring out out how to replace the fuse:
Hope this helps!
Jul 09, 2009 | Maytag PYE2300AY Electric Dryer
Dryer just stopped working in mid cycle.
Verify there is still power at the wall and check the thermal fuse.
Jul 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My dryer has been difficult to start lately especially if stopped mid cycle. The lights are all on but it won't start up. Today I only used it 2 times and it was very difficult to start after pressing many...
You may be experiencing "Heat Retention" by stopping your dryer mid-cycle, which you should NOT ever have to do! If you have a minor vent restriction or if you open the dryer mid-cycle when the heat is on, this will cause a disruption in the airflow and rising temperatures can keep the dryer from restarting until it has been cooled long enough.
Check your vent all the way to the outside for restrictions/obstructions every 6 months. Clean your lint filter after each load and DO NOT stop the dryer mid-cycle!
Note: Stopping the dryer mid-cycle can also cause severe burns and even melt polyester fibers.
Jul 05, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Won't run
ensure your door switch is working then move into timer.
May 05, 2009 | Roper RES7646KQ Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
95 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
