Question about Kenmore 46462 Front Load Washer
Door won't unlock
My washer door won't release. It keeps saying door locked without any clothes in it or without washing. It also gives an error message of f 21 i think it is. please help, i love my washer and miss it working properly!
Hold the drain/spin button for 4 seconds until it unlocks
Posted on Oct 16, 2008
    Genius:
  • 1,028 Answers
Remove bottom panel reach up to lock area pull down on small tab to release door if tub has water in it remove pump filter aacess by turning counterclockwise (have towels handy dip out as much water as possible first)
Posted on Sep 09, 2008
Edgestar e30
E30 is a door locking failure. The unit attempted to lock the door several times without success. First, make sure your door is closed firmly. Check for anything that may be blocking the door latch. Check that the latch is aligned to the door lock. Unplug the unit for 30 minutes to reset the electronics. If the unit still does not lock, please contact Edgestar at 800-297-6076.
Dec 06, 2013 | EdgeStar 2.0 Cu. Ft. Ventless Washer Dryer...
F22 error (in any washer setting) will not start, and cannot get door open. What "electrical "problem is this? Also, how do I get my clothes out short of using a crow bar on the front door!
F 22 is door lock error most likely need door lock but check door strike on door..To get clothes out remove lower kick panal reach up inside washer //at the bottom of door latch there is a small round tab pull down on it to release door..while you have the kick panal of there is a tech sheet inside washer try putting in die test/////but I would say door lock..Hope this helped If it did please vote...If you need more help please ask...Good luck
Feb 02, 2011 | Kenmore HE2 Plus Front Load Washer
Whirlpool washer doesn't unlock the door at the
Hi There
I have found this for you to read. it's door unlock error. Hope this helpful and let me know how it goes.
F/dU Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error.
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you for writing to fix ya.
Best Regards Richard
Dec 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
It won;t power up at all, clothes... Solve It won;t power up at all, clothes are locked inside, no lights on the panel. Plug in is working, I... (More) It won;t power up at all, clothes are locked inside,...
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 04, 2009 | Kenmore HE2 Plus Front Load Washer
Washer will not drain or stat new cycle, no error message
What is the make, mode # of your washer? Do you have dial or, a keyboardl controls
Apr 26, 2009 | Whirlpool Washing Machines
Philips Whirlpool 400 AWG 370 door is locked
take the kick panel off and reach up the right side where the door lock is. there is a release pull down that releases the door.
Jan 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GE Energy Star WBVH5200 Front Load Washer
My GE Energy Star Front Load Washer is reading 5.9 instead of 59 minutes and not washing clothes. We cleaned the filter and still no luck. Please help.
Jul 30, 2008 | GE Energy Star WCVH6260F Front Load Washer
WHIRLPOOL DUET WASHER 9150 DOOR LOCK DOES NOT UNLOCK
Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken or removed from the Door
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
replace door lock and ccu sorry
Jul 26, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Don't properly spin out clothed leaves them soakng wet-Now it just keeps pausing and locking door and unlocking door without washing
sounds like there is a pumping/blockage problem. check the filter and all drain hoses/outlets. if all clear the pump may be faulty. is the drum turning at all?
Feb 16, 2008 | GE WSXH208A Front Load Washer
Not drain
DL is the fault code for door lock error and occurs if the CCU (Cental Control Unit)"recognize" that door is unlocked. Potential reasons for it: - Door Lock/Switch Assembly Failure - In this case it should be replaced. - Door Lock unit is broken or removed from the door. - Look for disconnected wires to the door Lock/Switch unit and to the CCU. - Door Lock/Switch unit Failure
Jul 21, 2007 | Kenmore 43142 Front Load Washer
Kenmore 46462 Front Load Washer Logo
128 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
