Question about Konica Minolta magicolor 2300DL Laser Printer
I have replaced the toner but am still getting the replace toner message.
Why am I still getting the message? how do I resolve this?
  • I have the same problem even after refilling the magenta cartridge with toner, cleaning the cartridge contact points, reseting the metal tab on the cartridge, vacuuming out the printer slot for the cartridge. Still error "magenta cartridge not installed". HELP!
  • Chia-Yi Jan 07, 2009
    I met the same situation even after trying all the above solutions. Error message "Replace toner yellow" still showed up. With that error, I could not print b/w. Please help. Thanks.
    Problem Solver:
  • 7 Answers
My message error was sepcific for magenta after I removed it to refill it. After refilling, cleaning metal contact points, resetting the metal tab which prevents message of "low toner", I put the cartridge back in and received the "magenta toner not installed" message. I turned off the printer (safety first!) , I then pushed the button left of the hole where you slide the cartridge in, There is a squarish hole with a circular or cynlinder shaped button in that squarish hole. Use a small screw driver to push and hold it in. While the button is held in I gently rotated the cartridges so that my magenta cartridge was no longer in view, (rotate them counter clockwise). I released the button, shut the door, then turned on the printer.
Posted on Sep 28, 2008
Install Toner error message still displays even when replaced
If you are not using original manufacturer's replacement toner cartridges, this could be your problem, and it will not resolve. The printer and cartridge will not "talk" to each other, therefore giving you a false reading. If this is the case, you should still be able to print normally, but you will not know when you run out of ink until you actually run out, akin to a broken gas gauge in a car.
Jan 14, 2013 | Xerox Phaser Office Equipment & Supplies
C544dn printer - getting code: 941.02 service magenta TMC sensor
Please try the steps provided below.
Step Action 1
Power off the printer/MFP and open the toner access door. Reseat all of the toner cartridges. Power on the printer/MFP again and print a test page.
Did the error message return?
Yes: Continue to Step 2.
No: The error is resolved. 2
Power off the printer/MFP and remove the developer unit for the color specified in the error message, and then reseat it. Power on the printer/MFP again and print a test page.
Yes: Continue to Step 3.
No: The error is resolved. 3
It is possible that specified color's toner cartridge and developer unit are defective. If you have a replacement toner cartridge and developer, install them as a test and print a trial page.
Did the error message return?Yes: Continue to Contacting Lexmark.
No: The error is resolved. If the toner and/or developer were not near the end of their working life.
You can also refer to this link: http://bit.ly/kecjEM
Jun 07, 2011 | Lexmark C544dn Laser Printer
SCX-4521F All-In-One Laser Printer: toner empty after replacing new toner of samsung s...
Clear/reset the settings on the printer. Press in this order w/o pausing:
menu
193
start
If you do it correctly, the LED will say "Select Country, US", then you press "OK", then it will clear the settings and the error message should go away unless you have a dirty sensor or your toner is installed incorrectly.
Good luck-
May 18, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Error message OKIC3200n printer
I called the OKI help number, in the manual, and they told me that the second line of the error message, was just an additional reminder, to replace the magenta toner.
Sep 29, 2009 | OKI C3200n Led Printer
Toner empty message
I would try to unplug the printer and leave off for a few minutes. and see if that resolves the problem.
Jul 30, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Replace Transfer Roller Error Message Will Not Reset After Replac
The transfer roller on this machine comes as an assembly consisting of a waste toner tank and a transfer roller. The message you are getting pops up when this tank is full, regardless of the transfer roller's useable life. There is a window on the back that when blocked by toner, cuts off an optical sensor to tell the machine that the waste toner is full. Just unclip the roller from the side, pop it out, and dump the toner out. Careful though, it's a messy job and you might want to wrap the assembly inside a trash bag while emptying it out.
Jul 01, 2009 | Dell 5100cn Laser Printer
''TONER LIFE END'' MESSAGE
Toner probably isn't empty, but the machine shuts down at a specifc count on the cartridge regardless of actual consumption...don't you love it?
Your replacement cartridge was probably a remanufactured one and didn't have the toner reset lever properly set.
Mar 19, 2009 | Brother MFC-8460N All-In-One Printer
We re-filled the toner cartridge and re-installed it, but the red light indicating toner low keeps blinking, also the computor is telling us toner is low
Just refilling the cartridge may not resolve the low toner message. Many cartridges have a sensor chip that must be reset to clear the message. Due to this, many people opt to buy replacements or refurbished cartridges that have had the sensor chip reset.
Aug 15, 2008 | Computers & Internet
Replace Toner Message Will Not Clear
Are you sure that it is not asking for one of the colour toners?
Was it a genuine cart?
Did you replace it before machine instructed Replace Toner ie no message or Order Toner/Toner Low was displayed?
Nov 21, 2007 | Brother MFC-9420CN All-In-One Laser...
Konica Minolta magicolor 2300DL Laser Printer Logo
316 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
