2011 Victory Cross Roads Logo
A
Anonymous Posted on Aug 31, 2017
Just bought a 2011 Victory Cross Roads. I also bought a Roadlok wheel lock. Put is on and strtched the brake line tight. Found out I needed a 2 inch longer line. Bought a universal line, but the banjo fittings on the OEM line are fixed, the new line is set up for threaded fittings. I am trying to figure out what size banjo fittings I need, I am thinking 10mm but not sure.
1 Related Answer
Anonymous
  • 107 Answers
  • Posted on Jun 14, 2011
SOURCE: I have a 2011 victory
Before you cut into the harness, look under the seat in front of the rear fender for a 4 flat trailer connector. I had a Victory in my shop last winter w/ a trailer hitch, and it looked to me like it was part of the factory harness. You'll need to build a whip long enough to get to the trailer-this one was wired through and stored in the left bag. If it's not there, contact me back and I'll look up the wire diagram for you. Good luck!
Where is the reverse lever on a victory 2014
On the ground, push it with your feet LOL. Electric reverse is an option.
2answers
Anti-lock system light on
Anti-Lock Braking System (ABS)
Purpose Anti-lock brake systems (ABS) - generally also referred to as anti-lock
systems (ALS) - are designed to prevent the vehicle wheels from locking
as a result of the service brake being applied with too much force, especially
on slippery road surfaces.
The idea is to maintain cornering forces on braked wheels to ensure that
the vehicle or vehicle combination retains its driving stability and manoeuvrability
as far as physically possible. The available power transmission
or grip between tyres and carriageway should also be utilised as
far as possible to minimise the braking distance and maximise vehicle
deceleration.
Why ABS? Although today commercial vehicle brakes are designed to a very high
technical standard, braking on slippery roads often results in potentially
dangerous situations. During full or even partial braking on a slippery
road it may no longer be possible to fully transfer the braking force onto
the road due to the low coefficient of friction (friction coefficient (k)) between
the tyres and the carriageway. The braking force is excessive and
the wheels lock up. Locked wheels no longer provide any grip on the
road and are almost incapable of transferring any cornering forces
(steering and tracking forces). This often has dangerous consequences:
- The vehicle becomes unsteerable
- The vehicle breaks away in spite of countersteering, and starts to
swerve.
- The braking distance is significantly increased
- Tractor-trailer combinations or semitrailer trains may break away or
jackknife.
Load sensing valve influence On dry roads today's load sensing valves (ALB) alone are often capable
of preventing the wheels from locking if the vehicle is unladen; they also
help the driver to effectively grade the braking process on wet road surfaces,
but they are unable to prevent locking as such (no slip monitoring).
In addition, they are unable to counteract any overreactions on the
part of the driver, or any variances in frictional or adhesion coefficients
which may apply to different sides of the vehicle, or indeed to its different
axles (?-split road surfaces).
Benefits of ABS: Only the Anti-Lock Brake System (ABS)
- guarantees stable braking characteristics on all road surfaces.
- maintains steerability and generally reduces the braking distance
- prevents vehicle combinations from jackknifing
- reduces tyre wear.
Limits of ABS Although ABS is an effective safety device, it can not suspend the limits
defined by driving physics. Even a vehicle fitted with ABS will become
uncontrollable if driven too fast around a corner.
So ABS is not a licence for a maladjusted style of driving or failure to observe
the correct safety distance.
ABS Training Anti-Slip Regulation (ASR)
Why ASR? Increasing the engine output (accelerating) on a slippery road surface
can easily lead to the maximum adhesion on one or all powered wheels
being exceeded causing them to spin, especially if the vehicle is unladen
or partially laden.
Spinning wheels when driving off or accelerating represent a safety risk
just like locked wheel do when braking.
Reasons - Wheels that spin transfer just as little cornering force as locked
wheels.
- They also no longer transfer any tractive power onto the road.
Consequences - Vehicles that do not move or get stuck.
- Vehicles that can no longer be steered, jackknife on uphill uphill
gradients, or swerve in corners.
Benefits of ASR ASR prevents the powered wheel from spinning and provides the following
benefits:
- Tractive power and cornering forces are maintained.
- Stable driving behaviour is ensured when moving off, accelerating
and negotiating corners on slippery roads.
- The indicator lamp (if installed) is used to warn the driver of slippery
road conditions.
- Tyre wear is reduced to a minimum, and the motor vehicle's drive
train protected
- The risk of accidents is further reduced.
ASR and ABS: ASR represents a worthwhile addition to an ABS-controlled braking system.
All that is required to turn ABS control into full ABS/ASR control is
an ECU with the additional ASR function and a few additional components
for controlling the differential brake and the engine. This why ASR
is only available in combination with ABS.
Even a differential lock for off-road use and ASR do not exclude but complement
each other.
Limits of ASR The traction capacity of an all-wheel driven commercial vehicle can not
be achieved by a motor vehicle with only one driving axle - not even with
optimal ASR.
2helpful
2answers
My 2011 cross country came with what appears to be a lock for the front fork my key fits and turns it and there is a hole in the front top tree in which this fits. any imput ? and why would'nt they...
IT IS A SAFTY ISSUE HOW COULD YOU POSSIBLY PUT THAT IN AND RIDE IT AND FALL WITHIN DOT GUIDE LINE`s liabilaty issue`s with the manufacter and DOT. CHECK WITH THE DEALER SHIP being 2011 you had to have bought this brand new. EMAIL ME BACK IF YOU DON`T MIND AFTER YOU CHECK THE DEALER SHIP [email protected]
I have a VIN descriptor page from an older Victory Manual that tells me my new 2011 Victory Cross Roads has a chassis from a Hammer 8-Ball. Do you know if Victory has amended their VIN designations in the...
A Victory Dealership can read the VIN and tell you what is legally attached too so can Instavin but the dealership is free.
There are also VIN decoders on line that give you a vague idea of the vehicle and origin etc.
http://www.doityourself.com/stry/how-to-decode-motorcycle-engine-serial-numbers
I have a 2011 victory cross country and want to hook up a trailer hitch what color wires do I tie into for the brakes, running lights and turn signals
Polaris rmk mtn bike or victory vegas low mtn bike. Which is a better buy found them both for around the same price
The Polaris RMK and Victory Vegas Low are the exact same bike with different colors and names.
They are made by Ming Cycle in Taiwan and are distributed by an American company-----Cycle Force Group.
The Polaris and Victory are Ming's top of the line dual suspension mountain bike, they have upgraded wheels, front disk brakes and 19" frame. If color doesn't matter to you, then the Victory Vegas Low is usually the better deal.-------Can be found on Amazon, Wall mart, Miejer.
The Polaris and Victory generally have the best reviews and ratings of any dual suspension mountain bikes priced below $250
Top Victory Experts
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Paula Hamilton
Are you a Victory Expert? Answer questions, earn points and help others
