Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
Frigidaire dishwasher I have a 3 year old dishwasher, when I went to turn it on nothing happened. No lights on control panel or anything. My wires, breaker and power source are all good. Where should I look next? Thanks Stan
  • VeronicaM Sep 30, 2008
    We bought our dishwasher last year, now, after the windstorm that went through our area and caused an electric outage, our dishwaser won't even turn on. No lights, nothing. Anyone have any ideas?
  • christy509 Oct 12, 2008
    My dishwasher worked just fine yesterday morning when I turned it on, but when I tried to turn it on today, nothing happened. The lights wouldn't come on and the breaker has not been tripped.....
    Scholar:
  • 89 Answers
Next thing to look at--considering all the power is good--although that's what I'd check on again, would be the door switch. May have to remove the control panel cover or the door interior.
Try www.repairclinic.com if you need parts.
Posted on Oct 28, 2008
Frigidaire dishwasher normal wash light on and washing light but, nothing is happening
Make sure all hoses and filters are clean and clear. Make sure water is switched on. If no change ring service agent or contact Frigidaire.
Aug 13, 2014 | Frigidaire Dishwashers
My Frigidaire dishwasher won't start. I just moved into a condo and the dishwasher worked during inspection but now it's not...wondering if it's something I just don't know about. The model number is...
Did you ever get an answer to your problem.
I've got same issue where I turn the diswasher on and nothing happens ... the time just start going down but nothing is happening?
May 22, 2010 | Frigidaire 24 in. PLD2850 Built-in...
I have model # FDB431LFCO My house is 2 years old.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Nov 20, 2009 | Frigidaire Dishwashers
When trying to start the dishwasher the normal load light,heat light, and other lights blink and nothing happens.
take the control panel off and re-seat the ribbon cable back on the board if that does not change anything replace your control panel.
Feb 20, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire Dishwasher Energy Star blinking lights.
Hmmm...don't know why this worked, but it did. When the lights were flashing when I tried to start my Frigidaire dishwasher model#FDB1500LF, nothing would happen...just blinking lights, so I went to the house electrical panel, found the switch for the dishwasher, turned off & on again, and now the dishwasher works.
Go figure.
Feb 16, 2009 | Frigidaire 24 in. PLD2560LCC Energy...
Maytag dishwasher, no power, then flashing lights, now no power.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Jeff
Dec 23, 2008 | Maytag MDB7100AWB Dishwasher
Dishwasher won't start up
this could be a problem at the electrical hook up ,also could be a open door switch or if there is 115 volts to the control board and nothing happening then you need a board.
Nov 22, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher Heating element not working
rclay How old is your dish washer? It has up to five years limited (parts only) warranty on the electronic control. If it is within this period of time, then you can call Maytag and they will send you a new part. If you are not sure how old is it, you can find it with Maytag by the model and the serial numbers (on the door frame). The warranty for your dish washer you can get here: http://www.maytag.com/cust_serv/pdf_use_care_manual/6_915728.pdf Gendos...post back
Jan 31, 2007 | Maytag MDB9100A Dishwasher
Power going to dishwasher but nothing happens??
Gina, you probably blew a thermal fuse that sits on the control board. Easy fix. Have your husband first check the wiring to the dishwasher. Remove the toe panel and make sure the wire nut connections are good. If that is ok, he will have to remove the inner door screws to get to the control board. Lift out the inner door. Remove the control board cover, it just snaps off. He will see the thermal fuse on the upper right side. I will attach a photo of what it looks like...Catriver...post back
Nov 05, 2006 | Kenmore 24 in. 17602 / 17604 / 17609...
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
376 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
