Question about Electronics - Others
Radio small radio bought 6/2008 stopped working and new batteries hasn't helped.
  • henan1 Sep 08, 2008
    have had other radio shack racios that lasted for years
  • maguita_17_1 Sep 11, 2008
    mi radio de se prorect y despues pors pawer solo sale eso y no funciona q puedo aser
It just started working. Guess it had a short somewhere.
Posted on Sep 09, 2008
Sony icf sw7600gr won't power up on battery power and showing exhausted battery symbol,only on ac adapter will work
check the connection inside the radio, switch of AC-DC connector maybe loose contact.( leak diode more probability replace it)
Nov 09, 2015 | Sony ICF-SW7600 AM/FM/SW Radio
It's a 95 ford explorer and we bought a wiring harness for the new radio, the old radio worked fine and everything. We hooked up the new radio to the wiring harness and it powered on and everything, b
try hooking the radio power wires to the battery! To '' TEST'' twist red and yellow put on the poss. blk. on neg. ! take a speaker and test speaker wire out put! if don't work output is blown out! but will still work with rca jacks hook to small amp ! this to pull sound out of your radio for sure!!
Dec 27, 2012 | Cars & Trucks
My 12inch speakers work in my house but when I hook them back up to my truck they dont work . My amp used to have a red light on it but now it doesnt work i bought a new amp and speakers and still nothing...
Could be a number of things. Check all the fuses (the power wire, the amp). Make sure your ground wire hasn't worked loose. Make sure your remote wire hasn't worked loose either (sometimes vibration causes loose crimped wires to come out behind the head unit). Happy Hunting
Aug 20, 2011 | Car Audio & Video
Samsung pl201 the zoom isn't working and stopping the camera from working normally. it says to take out the battery and try again. this hasn't worked.
Jul 17, 2011 | Samsung PL120 Digital Camera
Hi, My Ibanez AEL 20 has a preamp - tuner 5AEQ45F. Tuner works but there is no signal in output jack. Guitar is quite new, and the preamp hasn't been used before. Can I get a PCB schematic diagram...
Remember that while in tuner mode, the audio output is disabled. Try additional presses of the tuner button to see if the audio comes back on. Also verify the volume and EQ gains are turned up. Verify the battery is new.
May 30, 2011 | Ibanez Ael20e AcousticElectric Guitar with...
I have a CTP8600 Cordless phone made by Coby in 2003. The battery pack for the handset is apparently no longer charging. Coby has stopped making (or supporting) this product. I would like to replace the...
Try taking the battery pack to your local radio shack store. They can usually match the original battery pack with a new, compatible one even if they no longer make the EXACT one that came with the phone. This recently happened to me with a panasonic phone bought around 2002. phone stopped charging, no longer make the phone, etc. I went down to radio shack and they fixed me up with a new battery (not exact brand/part number as original) and it worked. Hope this helps you.
May 20, 2011 | Coby CT-P8600 Cordless Phone (CTP8600)
On idle radio cuts out,new alt. bought didn't fix prob.
If car cuts off when battery disconnected alternator/regulator is not working.
A/C could be low freon level.
Jul 23, 2010 | 1989 Mercedes-Benz 300-Class
Microtalks won't charge
I have the Cobra Microtalk 4100 FRS radios with charging base. After changing the batteries with new nimh rechargables the charge light would not illuminate and the unit would not charge. I noticed the original batteries had a metal band around one end. This band makes a small connection inside the battery compartment on the first battery. Seems to be a cheap way to ensure you dont try to recharge the unit with non-rechargable batteries installed. I rapped a small piece of tinfoil around one end of the first battery in the new set then popped it back in and now they will charge correctly again. Dont try this with non-rechargable batteries! I would recomend buying original replacement batteries.
Nov 28, 2008 | Cobra Microtalk 100 FRS Walkie Talkie...
did you check the fuse on the back of the radio. it should be a small maxi fuse that might be rated any where from 5 to 20 amps. most of the time it might be helpful to unplug the radio harness and re plug it after 1 minute.
May 27, 2008 | JVC Arsenal KD-AR3000 CD Player
Electronics - Others Logo
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
