Question about Brother IntelliFAX 4100 Laser Fax
Rebuilding the brother fuser for the intellifax 4100
Hi, I took the plunge, disassembled the machine and found the broken brown fuser gear.Scavenged an intact gear from a spare fuser assy from an old model 1240 printer.The first few prints were perfect, but then progressively bad double/repeat faint images.Is the red roller bad?Heating element?Thermistor?The red roller in the 4100 seemed to have a bigger diameter than that in the 1240 (indication it is bad?).Should they be the same? thanks
  • brokenfax Sep 10, 2008
    Wow, great advice! It turned out to be a defectively rebuilt drum/toner combo purchased from a local supplier!! As soon as I tried a (borrowed) original Brother drum/toner unit the prints look perfect. So the gear/fuser/heater/etc turned out okay - - well worth all the trouble of the total tear down and rebuild (plus it was actually a lot of fun doing it first time ever from the pdf download of the tech manual). Again, a BIG thank you!
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Brother Master
  • 1,362 Answers
Although it fit the broken fuser, it does not mean it's ok.
1-they must have the same number of teeth ( diif. gears have diff. amounts of teeth)
2-it must be the same diameter ( so they can mesh together, otherwise it's touching the tip of hte teeth and may be skipping.
But I'm not sure the double image is coming from there, it would jam the paper because the timing is off.
Anyway you need to eliminate the obvious then see what happens, I think you said you had another tonertry putting that in, if it doesn't work then change the gear for the correct one.
try precisionroller.com
Posted on Sep 09, 2008
Brother intellifax 4100 squeaks when printing faxes
THIS IS A HARD ONE, THE BEST THING THAT CAN TELL YOU IS TO LUBRICATE ALL THE GEARS IN THE MACHINE, THERE IS A SLIGHT POSIABLITY THAT IT IS COMING FROM THE FUSER MODULE
Jan 07, 2009 | Brother IntelliFAX 4100 Laser Fax
Fax machine not receiving
David Powell Loves Katie Stone!
Oct 08, 2008 | Brother IntelliFAX 4100 Laser Fax
Fuser unit
dont. the whole machine has to be taken apart. not worth the time and the fuser is 85.00 wholesale.
May 24, 2008 | Brother IntelliFAX 4100 Laser Fax
FUSER REPLACEMENT
A real big job. Completely remove all covers, doc feeder asm. Best to let a qualified tech do it for you. I charge $50.00 plus parts and will allow you to watch me do it. But i am in Florida.
Fuser & Scanner are not the problem
Either the laser unit is dirty or blocked. Or the drum cartridge.
May 19, 2008 | Brother IntelliFAX 4100 Laser Fax
Intellifax 4100 grinding noice
Probably caused by the toner cart. Only use genuine new Brother brand supplies. Remans fail quite often with Brother machines.
Possibly bad gears on fuser drive. But with the poor print quality, I suspect it is the toner.
May 02, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother Intellifax 4100 squeaky sheet feeder
The doc feed asm needs to be rebuilt. Only white lithium grease is used to lube the gears and avery light oil on the shafts. All parts are available from brother. I can get the parts if you have trouble obtaining them. It is relatively easy to rebuild and I charge in my area of Clearwater Florida, about 100.00 parts and labor.
Apr 19, 2007 | Brother IntelliFAX 4100 Laser Fax
Gears grinding with Brother Intellifax 4100
Does it only make the noise when printing. Do you hear the noise when sending out faxes? I have heard grinding noises onlt when using poor quality toner refills, or the fuser gear and or drive gear asm is stripped. First try a known good OEM toner.
Mar 22, 2007 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
150 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
