Question about Microsoft Xbox 360 Console
Strange problem with XBOX-360 games
I started playing the PES5 and my TV is ?squeezing? the picture- the whole picture is smaller. I?m not using a computer monitor. Did anyone encounter this and know how to fix it?
    Novelist:
  • 196 Answers
Try changing the display settings of the XBOX 360 or the TV. Also make sure you possess the latest updates for the Media Center Edition: http://www.microsoft.com/downloads/results.aspx?pocId=38DF6AB1-13D4-409C-9
Posted on Feb 22, 2006
SOURCE:
While playing my xbox 360 the screen turned green and my tv is fine. after i turned it off now the xbox starts but no picture comes on my tv screne
you can take your xbox to nearby repair shop or you can do it by your own..... you can use repair guide to fix this problem easily by your own,,,,
hence go to this link to get repair guide,,click here.
Oct 07, 2010 | Microsoft Xbox 360 Console
Game wont read says put disc in xbox 360 but i am using xbox 360 also it says its a dvd not game just wont let me play no more
If you have recently tried to mod your Xbox 360 then you did not get the drive key installed correctly. Otherwise the laser lens is either dirty/ starting to weaken. You can either replace the laser lens in the disc drive, try to clean it, try the POT tweak or replace the whole disc drive. Keep in mind if you replace the disc drive you will need to swap the PCBs or the drive keys. Hope this helps.
GATpro
May 21, 2010 | Microsoft Fable 2 for Xbox 360
Our XBOX 360 sometimes the games won't work and sometimes they do. Brand new games sometimes just won't play
This is a strange one sounds like you may be getting the start of the DVD sensors on the back of the drive overheating and once this happens it will not play your games however you only mention sometimes.
If it stops all together you will need to send it in or repair it yourself
Dec 03, 2009 | Microsoft Xbox 360 Console
The picture doesnt show but I hear the sound.
Don't worry the HD feed from the xbox 360 has a gain limiter
So the chances are more likely that either your Friends xbox has
the HD setting off or the TV has defaulted to standard video in.
If you get a black screen or a mesage that says no single .
But if your getting strange color on your set with the HD on
then we need to investigate this " Microsoft is liable!" for
damages caused by their console. Ill look in to this and
follow up. The xbox has broken connection under the poorly
soldered G.P.U. and will need to be re-flowed to the main
board to corrects this problem but that's a secondary priority
right now.
I'll check this out for you and follow up.
Rob
Oct 03, 2009 | Microsoft Xbox 360 Console
In-game graphic breakdown
Sounds like an issue with the graphics card in the system. Call up Xbox 360 Support, or return it for a new one.
Apr 15, 2009 | Microsoft Xbox 360 Console
Xbox 360 thinks it`s an Xbox and won`t register a 360 game
Hey,
Strange Issue, but I think its a possible solution to it. I would say the drive and/or laser needs to be changed.
Apr 14, 2009 | Microsoft Xbox 360 Console
Xbox 360 Console, Faulty, NO DISPLAY!!??
What do you mean, no display? Is is game-related display issues? Have you checked the AV cable connection? Or is it about the settings? Is this the first time that you are going to connect your xbox console?
To determine whether the display issues are specific to a particular game, try playing a different game to see whether the same symptom occurs. Reminder, some Xbox original games that were released for the original Xbox console may show some display issues when you play them on the Xbox 360 console.
Next, make sure that AV cable is connected correctly to the Xbox 360 console and to the TV. To verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, you can disconnect the AV cable and then reconnect the AV cable to both devices. Note: If you are using composite cables, do not try to set any HDTV settings. If you try to set HDTV settings, you may lose the picture.
You might also want to check your TV's settings because some display issues can be caused by how the TV is set up. To make sure that this is not the case, please check your TV's settings.
In your TV's settings, you should check the following:
- Make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
- If your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- If your TV has a type of picture compensation enabled, disable it
- If your TV's settings are correct, you may want to try using a different TV, if you have one available. Try connecting your Xbox 360 console to another TV to see whether the same display issues occur
Next, reset your Xbox 360 console. To reset the display settings to the default settings, follow these steps:
1. Remove any discs from the disc tray.
2. Turn off the console.
3. Turn on the console.
4. As the console starts, press and hold the Y button, and then pull the right trigger at the same time.
Mar 09, 2009 | Microsoft Xbox 360 Elite Console
Problems with picture quality
if it shows up on multiple games then there is a problem with either your cord or your tv. Trying cleaning the connectors that room from the xbox to the tv. Do you have an old tv or a newer one?
Feb 20, 2009 | Buck Legendary: The Box for Xbox 360
Plays dvds on xbox 360 fine, but no picture for games/dashboard
already solved it. thanks. i couldn't see the xbox settings blade because of the blank screen so switched my component cable to the tv setting instead of the hdtv setting, then i could see the dashboard in non-hd and switched the resolution to 720p while simultaneously switching the component cable back to the hdtv setting. that worked.
Jan 02, 2009 | Sharp Televison & Video
Microsoft Xbox 360 Console Logo
69 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
