Question about Toshiba 55H70 55" Rear Projection Television
Pop, gas like release sound, worked for short time, now dead
We bought our 55H70 in 2001. In 2003, we had ??? replaced for $400. We turned it on this weekend and t made a popping sound, followed by a release sound, kind of like a gas leak. It worked for a few minutes, then died. The red light blinks on the front, but that it it. We had it repaired in 2003 for a ???? for $375. Any idea what is wrong? I wonder if it would be better to just buy a new one rather than putting in another $400 in repairs.Any help is appreciated!
  • 84 Answers
Sounds like high voltage flyback is bad
Posted on Oct 20, 2008
Trunk release, power windows, turn signals, wipers, radio all stopped working at the same time on 86 chrysler fifth ave
Hi! This doesn't sound like a shorted wire, because a short would usually blow a fuse. Since you're having trouble with the starter, I'm thinking that the ignition switch needs replacement. Depending on the year/make/model, you may be able to change just the electrical part of the ignition switch.
Oct 28, 2013 | 1986 Chrysler Fifth Avenue
My 1994 lexus ls 400 wont move
I have the same problem - did you find a solution yetI bought a used on ls400 ECU from a junk yard but it eeds to be "RESET" how do I do that?
Oct 14, 2012 | 1994 Lexus LS 400
My compressor will start and run well but when it turns off it will turn but not run stalls and kicks the breaker
It sounds like the small valve that releases the pressure out of the main pipe that runs between the compressor and tank is not working once the tank is full and the motor automatically cuts off. You know this valve is working by the sound of a short spurt if air being released when the motor cuts off. Releasing this pressure means that the motor is able to restart easily because there is no load. If the valve is not releasing this air, the compressor is trying to start under full load which the motor is not capable of doing, hence the humming and popping of breakers due to a current overload as the motor tries to start. Motor burnout is possible if it keeps recurring.
This small release valve is attached to the Pressure control switch that switches the motor On & Off and usually has a small pipe going to it or is incorporated inside the Pressure Control Switch.
Sep 17, 2010 | Porter Cable Cable 20 Gal 150PSI Oil Lube...
My 36' RCA TV JUST QUIT WORKING. TURNED ON POWER
A shorted horizontal output transistor or shorted flyback. If the flyback is shorted replace also its HOT.
Apr 05, 2009 | RCA F36650 36" TV
Carver M-400 popping and no audio
Sizable sparks at a cap~ base?? That sounds like there may be a dead short somewhere and/or catastrophic failure of the caps~ (not always visible on the components, use a multimeter to check the terminals if they are shorted.) If there is noting else that has failed in the amplifier other than the power supply* (*if applicable), it is repairable. Otherwise good luck finding the other fault(s)*.
Jan 23, 2009 | Audio Players & Recorders
Trunk lid
i think oiling the mechanism should proove usefull sounds like rust or simmilar
Nov 10, 2008 | 2003 Suzuki AN 400 Burgman
Turning on grill blows fuse on Electrolux EOG7330WN
get i an accredited electrician to check the grill element and fitting
there is a dead short in that area
Apr 23, 2017 | Electrolux EOG7330WN Gas Double Oven
Frigidaire code F1
Rainbow, F1 could be one of three things. The loud pop doesn't sound good. 1. Shorted keypad-replace the control. 2. The control sensed a runaway oven temp. In this case you would have to ohm out the temp probe. 3. The control itself may have a shorted relay-replace the control. The temp probe should ohm at approx 1100 ohms at room temp. Unplug the oven for one minute, if the code returns, first ohm the temp sensor (probe) if that checks ok, replace the control..Catriver
Nov 30, 2007 | Frigidaire FEF355 Electric Kitchen Range
Mpio HD-400 is stuck on loading screen windows doesnt recognize it
alotita, I have an MPIO HD-200. Does Windows play the sound like you have something attached when you plug it in? Or does Windows not regognize it al all? Either way, I've had to play with mine after I've dropped it a couple of times. I charge the battery all the way, then just keep plugging and unplugging from the USB wire. The last time, it took 20+ times before Windows would recognize it.
Nov 14, 2006 | Mpio HD-400 MP3 Player
Toshiba 55H70 55" Rear Projection Television Logo
59 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
